"spin up" is a myth
"spin up" is a myth
You know how some people claim that increased weight on the wheel rims causes you to accellerate slower? It's actually so small that you'll never feel it.
Here's an article explaining it.
Also, I just noticed. The chart says its for 5 seconds. Over th course of a long race that lasts an hour or hours, that 1% could add up to minutes of advantage, potentially....right?
Weight does matter on a climb, that's why. If you want 1 wheelset that is fast on the flats and no penalty on the climbs, you get light and aero.
You spend very little time accelerating; if you are accelerating 1% faster, and it takes you 5 seconds to accelerate, then you've shaved off a whopping 0.05 seconds. If the article is off by a factor of 5, then the acceleration is 0.25s faster. There is no way a human being could detect that based on feel.
So let's say it takes 5 seconds to go from 0 to 20. If you accelerate 200 times in the course of a ride, you've "gained" 10 seconds. Under optimal conditions. On paper.
In real world usage, I seriously doubt such infinitesimal differences actually make any difference whatsoever. If you lose a time trial by 5 seconds, or get spit out the back of your weekly club ride, I doubt anyone wil believe it's because your wheels weighed 100g more than the lightest wheels on the market.
You do see that to get to a 1% difference they had to increase the rim mass by 400g. The actual difference in combined rim weight of your 2000g wheelset and your DTs is probably less than half of that.
i'm not sure, but, it think that unless a pedal stroke is perfectly uniform and of equal force through it's entirety, the bike is in a constant state of acceleration or deceleration when it is not coasting.
okay then go do a test yourself. get a set of light wheels and a set of heavy wheels, then sprint up to lets say 35 mph from about below 10 mph. measure how long it takes for each wheel. when you notice no difference, remember that all the marketing behind bike parts are overstated beyond belief.
if a rider is getting dropped on any ride, lightening his bike by even 10 lbs wouldn't help him enough, especially if he wasn't dropped on a pure climbing race.
The article looked at acceleration from 25 to 30MPH. In that case the acceleration is quite low because much of the power you put down goes into overcoming wind resistance and very little goes into acceleration. Lighter wheels are more noticeable when you're noodling around in a parking lot or starting from a dead stop. Less so when it matters in a race.
Bikes: Seven Axiom Ti, Trek 620, Masi cylocross (steel). Masi Souleville 8spd, Fat Chance Mtn. (steel), Schwinn Triple Bar cruiser, Mazi Speciale Fix/single, Schwinn Typhoon
I had the Alpha 340s on my rain bike that day instead of my daily-driver wheelset.
Bikes: Time ADH01, Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
When I switched to a set of Rolf Vector Pros in 2001, I noticed a .75mph average increase in my speed over my Mavic Open Pro wheels - or so said my cyclometer. So aero does count and this was not under race or timed conditions, just me riding the same route and looking at what the speedo average said. It was early evening so no wind was involved. This was consistent for nearly every ride with them. As for light weight, my 1200 gram wheels sure feel like they getup go (****n' git) faster than my 1800 gram wheels do. And climbing is where the clearly noticeable. Should you spend bigger bucks for a set of wheels that get up to speed faster? I don't know, it depends on what the speed is and what you determine to be faster is. Should you spend more money for aero wheels? They do make a difference. For climbing wheels? They do make a difference. But also as was posted, none of this will over come less fitness on the part of the rider of said bike. They will help.
SO, does any one wish to debate aero seat posts or handle bars
How does the author come up with his numbers? They just magically appear as a percentage of his effort.
If you read the comments it may be that his 1% saving is actually 3% even with his magic math.
If I'm doing 200 accelerations in an hour I'll take 3% in a heat beat.
I'd like to get lighter rims on my sports car. I've heard it makes a noticeable difference accelerating, especially when weight is removed from the outer perimeter of the rim.
It seems the effect of a lighter bike rim would be noticeable especially when taking off from a dead stop. However, my heavy bike rims don't bother me a bit because I'm slow anyway!
Here is another attempt at testing wheel mass and aero effects. It only deals with whole wheel weight as opposed to rim weight, though:
https://biketechreview.com/reviews/wh...el-performance
And here is the mass section from everyone's favorite great wheel test:
https://www.rouesartisanales.com/article-15988284.html
Both have flaws, but they do explain where their numbers come from.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
I am resistant but want to talk with physic-geek friends to make sure the data/methods are sound. That's beyond my pay grade.
