Car driver tells me flashing headlight is too distracting
I was stopped by a nice guy today at a stoplight and asked if I could change my front headlight, a relatively cheap $20 led, to stop flashing as it is too distracting.
My thoughts are...mission successful. Yours?
Acts 2:38
Bikes: '10 Marin Lucas Valley, '13 Scott Speedster 20
Mission accomplished.
"Thanks! You proved my point that it's working."
If (s)he doesn't understand, end the conversation.
Bikes: Surly Long Haul Trucker, Salsa Mukluk, Riese & Muller Supercharger GT Rohloff (Forthcoming)
Quoted: 103 Post(s)
Liked 27 Times
I am inclined to agree, but maybe also think about the angle you have it pointed. Maybe a slight tilt down will do the trick and not annoy people whilst making yourself more visible.
Interesting response given this recent blog posting which suggests that use of a flashing light during the day.
Andrew
Andrew
biker
Visible is good. Blinding is bad. Blinding means a reduced capacity to gauge where things are. When that happens to me, and I have to keep moving, I pick a line on one side of the lane to follow. Usually it's the one that should result in a reduction of risk of hitting big objects that could hurt me, which may turn out poorly for pedestrians and cyclists.
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
i've heard a flashing light makes it harder to determine the location of an object. but I always run with my lights on flash.
I do tilt the headlight down a bit so as not to blind drivers
actually, this got me thinking ...
when I have to ride on the street (i.e. no segregated bike path), almost all of the streets are segregated with a subway/surface line in between. meaning that a driver couldn't physically stop and say that my headlight is distracting, nor could the driver be distracted (at least by a headlight) and hit me.
i do run the rear on flash, but it seems that most other bikers run them on solid. in fact most riders have dynamos, integrated rear rack/lights with a sunlight sensor to turn the light on automatically. i'm probably one of the few people with a blinky, so maybe i'll convert it solid tonight
thoughts?
thoughts?
Quoted: 19 Post(s)
Liked 7 Times
Some strobe lights are "attracting" but others have such a low frequency that they leave big gaps of darkness, long enough for a driver to glance, see nothing and pull out in front of you from the side.
Flashing lights can be noticed but it is very difficult to estimate distance, esp it it is so dark, all you can see is the light.
Flashing lights should be used in poor daylight or dusk where you can be seen if someone looks. In the dark, switch to solid beam.
Some people run 2 flashing lights at different frequencies, much too hypnotic. Run one solid and one flashing.
"You saw my light? Well then it worked--too many cyclists and pedestrians get killed or hurt because drivers 'don't see them'."
I moved my 250 lumen light from my helmet to my handlebars because I was hearing nasty comments from pedestrians...
Two lights, front and rear, brightest on steady, less powerful light set to blinking.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
I have a flashlight holder on my bars. I use both a flashing LED lamp, and a strong beam LED headlight that stays constantly on. It is a winning combination for me. During daylight, the flashing LED grabs drivers' attention and they don't pull in front of me. Perhaps they can't judge my speed (it's hard even with a steady light, since bike has a very narrow profile), but they SEE me coming. That's good enough for me.
Just to stress once more that it's hard for the human eye to judge your speed if you're coming toward the beholder, not moving laterally. So light on steady, or flashing doesn't make much difference. With cars it's easy, we subconsciously measure the visible distance between the two front headlights (about 1,5 meters) and by how big it appears and how it increases, we judge speed. With bikes that have lights too narrowly (one, or two mostly 50 cm apart), that's not possible.
Quoted: 32 Post(s)
Interesting thread.
Personally: I run both front lights on solid. However, there are two areas on the commute HOME that has delayed green lights (which are so stupid to be honest) and in the rain/dark I will use the blinky on the front if I feel the need.
For the back lights, Planet bike blinkies work great for me. I do run two different back lights. One solid and one blinkie.
I would say that if a driver said it was too distracting then it is working however as some say, perhaps point it down a little.
Bikes: Trek Mtn Bike
Quoted: 282 Post(s)
Liked 2,644 Times
Part of driving is dealing with distractions. If you can't see well enough to judge whether to move into the bikers lane then wait. Cuss the rider but wait.
That said I ride with the front light solid, rears blinking.
In many jurisdictions, flashing (headlights or taillights) are a code violation. Further, as others have mentioned there is some evidence that they increase the likelihood of collision. On top of that, a flashing HEADLIGHT, reduces a headlights primary purpose--to allow one to see ahead of one. Headlights are not, primarily, about being seen, but about seeing.
And I will note, that by your (OP) own admission, the driver was polite and simply conveying what they believed to be relevent information (which as others have pointed out has some factual basis) and your instinctual response was sarcasm? Very civilized behavior/instincts you have.
Bikes: Fuji Cross Comp, BMC SR02, Surly Krampas
Quoted: 7 Post(s)
I run two MagicShines on the front - steady on the bars, and flashing on the helmet. 2-3 flashers and a solid on the back. Frankly, I don't care if I distract or irritate a driver with my lights - at least they can see me. And I still have two right hooks in the past two days...
Certified Bike Brat
Quoted: 5 Post(s)
Liked 6 Times
BRIGHT lights are CRITICAL when driving in traffic and sharing roads with motor vehicles. Properly adjusted, 'bright' doesn't have to mean 'blinding' for oncoming traffic.
"Per Ardua ad Surly"
Bikes: Bianchi Specialissima, Mongoose Hilltopper ATB, Surly Cross-Check, Norco City Glide
+2. I often leave my cheap Cat Eye 3LED light on flash and then use a Light and Motion Stella on solid. I find the Stella is a little too bright on flash when it's really dark out. I reserve its flash for misty and low light conditions. When it's really dark I augment both with my old BLT halogen helmet light. That really brigthens things! The other day I was complimented by a driver who nearly clipped a wrong way ninja earlier that evening.
Old, but not really wise
Bikes: 2010 Kona Dew Drop (the daily driver),'07 Specialized Roubaix (the sports car), '99 ish Kona NuNu MTB (the SUV), Schwinn High Plains (circa 1992?) (the beater)
Bikes: 05 Trek 5200, 07 Trek 520, 99 GT Karakoram, 08 Surly 1X1
You said he was a nice guy. I would have asked what he meant by distracted..
“Annoyed”or “Blinded”. Big difference in your safety and his.
Thank him for letting you know. Make adjustments on your light angle if necessary.
To respond all snarky as some have suggested is contrary to the respect y’all scream about lacking on the road.
The Recumbent Quant
I do most of my riding during light hours. At these times, I flash both front and back. When it is dark out, I do have a (supposedly) >1000 lumin flash light on front that I turn on solid.
Cheers,
Charles
The Recumbent Quant
Cheers,
Charles
Bikes: 2012 Trek Allant, 2016 Bianchi Volpe Disc
I don't see the point of running the front light on flash. Drivers on the other side of the road aren't going to hit you, and you risk distracting them. It doesn't help you see the road at all.
Is the reasoning for front flash to help prevent people pulling out from side streets? I think a bright headlight would do the same coupled with riding farther away from the curb.
