Anyone else get dizzy when they stand quickly?
Old 03-25-13 | 12:49 PM
jppe's Avatar
Let's do a Century
I've noticed this a lot more recently. After sitting or lying down for a while I get very lightheaded when I first stand up. My blood pressure is as good or better than ever. From what I found on the internet (of course it's never wrong) maybe my heart is getting stronger and my HR even slower. That could make sense with the increased exercise over the last several months. I also wonder how my dehydration plays in it.
I used not have the issue but I did really notice it while riding in the higher elevations of Colorado and leaning over to grab my water bottle. It really makes me wonder how bad it's going to be this summer.......
(btw, the scales were very kind to me this morning and only read 169. Just 4 more lbs to get to my all time low for over 20 years. Makes me wonder if I can get to 160???)
Here is one article that I found on a Sportsmedicine site:
If you exercise often and are in good shape you might occasionally experience dizziness and lightheadedness when you stand up quickly. This is generally nothing serious, and occurs due to a slow heart rate.
Cardiovascular exercise makes your heart stronger and a stronger heart has a larger stroke volume. That is, the amount of blood pumped out during each beat is greater, so the heart doesn't have to beat as often. A slow pulse rate is an indication of a strong, healthy heart. However, a slow heart rate can sometimes lead to dizziness when you change position.
When you stand up quickly gravity pulls blood from your brain towards your feet and blood doesn't return to the brain until the next heart beat. With a slow pulse, this takes a second or two and that is enough time to feel the lack of oxygen in the symptom of lightheadedness or dizziness. It is also related to something called postural hypotension. This results from a decrease in blood flow to the brain, due to a drop in blood pressure upon standing up.
As long as it occurs only occasionally, you don't really need to worry. If you have constant and severe dizziness with changing position you should see a doctor to rule out an underlying condition such as an irregular heartbeat.
Quick Tip: If you have a slow pulse (50 or less) and experience dizziness when standing up try getting up more slowly and see if that solves the problem.
Ride your Ride!!
jppe is offline
Reply
Old 03-25-13 | 12:54 PM
Nightshade's Avatar
Humvee of bikes =Worksman
20 Anniversary
Take this up with your doctor since there could be severe problems going on for you.
Oh yes, asking here is folly since only a doctor can help you not the jailhouse advice you'll get here.
My preferred bicycle brand is.......WORKSMAN CYCLES
I dislike clipless pedals on any city bike since I feel they are unsafe.
Originally Posted by krazygluon
Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred, which one would you rather have under your butt at 30mph?
Nightshade is offline
Reply
CommuteCommando's Avatar
Bikes: KHS Alite 500, Trek 7.2 FX , Masi Partenza, Masi Fixed Special, Masi Cran Criterium
I have been told by my docs that this is due to a drop in blood pressure. I have experienced it after topping a hill, or stopping at a light after a hard run, and my HR and BP recovery "overshoots". This got them to take me off one of the BP med's I was on.
CommuteCommando is offline
Reply
Old 03-25-13 | 12:55 PM
woodway's Avatar
Squeaky Wheel
15 Anniversary
I have the same issue. It started when I began riding my bike to work everyday, and my fitness level improved. Resting pulse is in the low 40's.
woodway is offline
Reply
Old 03-25-13 | 01:26 PM
David Bierbaum's Avatar
Bikes: 1992 Specialized Crossroads (red)
I don't have any problems getting up from lying down, but I do get dizzy getting up after having been bent over for any period of time.
David Bierbaum is offline
Reply
Old 03-25-13 | 02:05 PM
BlazingPedals's Avatar
20 Anniversary
This is not medical advice; but when I'm conditioned-up for the season, I also get light-headed if I stand too quickly. The symptom may indicate a problem or it may not.
BlazingPedals is offline
Reply
Old 03-25-13 | 02:22 PM
NOS88's Avatar
With all respect intended, I think there is a difference between asking for advice and taking it. I tend to view asking for information as the OP did is more of a "thinking things through" before talking with medical professionals. It can give you some language and concepts that may be useful when you have the discussion with medical personnel.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
NOS88 is offline
Reply
JohnDThompson's Avatar
Old fart
Titanium Club Membership
20 Anniversary
Community Builder
This is known as "orthostatic hypotension." It is not uncommon, and not generally dangerous as long as it resolves quickly and you don't lose consciousness. Certain medications, particularly blood pressure medications and cardiac rate control mediactions can exacerbate the problem, as can dehydration. If you have a sphygmomanometer (aka "blood pressure cuff") at home you can check orthostatic vitals signs by checking your blood pressure and heart rate while lying down, while sitting, and while standing. Allow a minute or so between position changes for your body to equilibrate. A drop of 20mmHg in blood pressure and/or increase of 20bpm heart rate can indicate enough of a problem to ask your doctor for advice.
JohnDThompson is offline
Reply
Old 03-25-13 | 02:32 PM
Rick@OCRR's Avatar
www.ocrebels.com
Bikes: Several bikes, Road, Mountain, Commute, etc.
I have that happen quite often but only once have I passed out because of it. Esp. after a challenging ride I get those symptoms but overall, no harm done.
I'm not on any meds, so it must be normal for me.
Just takes me a second or two to return to normal.
Rick / OCRR
Rick@OCRR is offline
Reply
Old 03-25-13 | 02:43 PM
10 Anniversary
Bikes: 2022 LiteSpeed CHEROHALA CITY, 2019 Canyon Roadlite 9.0 CF LTD, 2015 Giant FastRoad CoMax 1, 2001 Mongoose Pro Triomphe,
All the time... but it's a side effect of the meds I take for my CHF. I have learned to live with it. That said I have a reason for the problem. It sounds like you do not. Run... no walk.... no ride slowly to your doc. It's NOT a normal thing for most everybody.
Good luck.
DowneasTTer is offline
Reply
Old 03-25-13 | 03:01 PM
CraigB's Avatar
Starting over
Bikes: 1990 Trek 1500; 2006 Gary Fisher Marlin; 2011 Cannondale Synapse Alloy 105; 2012 Catrike Trail
That happened to me frequently after I started to lose weight but was still on my doctor's prescribed hypertension med. It was always worse within about 3-4 hours of having exercised. After coming this ---><--- close to passing out in a Home Depot the afternoon following a long morning ride, my doctor cut the meds in half, then ultimately took me off of them.
CraigB is offline
Reply
Old 03-25-13 | 03:09 PM
Looigi's Avatar
Yes. Started as long ago as I can remember, since 5 or 6 years old? Orthostatic hypotension. https://en.wikipedia.org/wiki/Orthostatic_hypotension
Looigi is offline
Reply
Old 03-25-13 | 04:59 PM
gif4445's Avatar
10 Anniversary
Bikes: 2018 Specialized Diverge Expert, 2018 Specialized Diverge Comp, Volagi Liscio, LHT
True, but doctors don't bat 1.000. You are your best advocate and any information, especially if it comes from someone with the same symptoms, has some value. I have a spinal condition that cycling brings pain relief to. Thought I was alone in that, but a recent post on this forum revealed a few people in the same situation. Of course the Dr. should be the final advice, but IMO there is some good stuff coming from these Forums. Just take it for what it's worth.
I have almost fainted while coaching basketball. Usually a combination of rising from the catchers type position I assume frequently in front of the bench, to a standing position. Combine this with the tension or what have you of the moment, and it can happen. There have been some college coaches in the past experience this. Thinking Duke Coach Mike Krzyzewski had an "episode" like this. Probably a lot different than in a physical exercise type moment. But take it for what it's worth!
gif4445 is offline
Reply
Old 03-25-13 | 05:32 PM
Bikey Mikey's Avatar
Bikes: Diamondback Edgewood LX; Giant Defy 1
Not had this issue, but see a doc.
Bikey Mikey is offline
Reply
Old 03-25-13 | 06:02 PM
GeorgeBMac's Avatar
Bikes: 2012 Trek DS 8.5 all weather hybrid, 2008 LeMond Poprad cyclocross, 1992 Cannondale R500 roadbike
+1 (Well Said!)
A physician is as much a detective as anything else: there can be a LOT of different things causing what you describe. Discussion here can provide some possibilities that you can test on yourself (i.e., "it only happens when I..."). The more high quality information you can give your physician the more likely it is that he will be able provide a correct diagnosis the first time.
GeorgeBMac is offline
Reply
Old 03-25-13 | 07:05 PM
rubic's Avatar
Slogging along
Bikes: Cannondale Synapse '06, Mongoose titanium road bike '00--my commuter. Yes, Mongoose once made a decent ti road bike.
In the past when I have been in the best condition of my life, I suffered with this stand up dizzy thing. My HR was in the 40s along with very low blood pressure. I used to consider this a condition of excellence. Now that I am old(er) and my HR and BP are more normal, I don't suffer from this anymore. So much for the old and slow set.
rubic is offline
Reply
Old 03-25-13 | 07:11 PM
10 Anniversary
In my forties (im 58 now) I had a job where bending down and working was the norm.When I stood straight up i became light headed for a moment.In my fifties I don't have this problem.The only med I take is Lipitor.And I didn't take it when I was in the forties SooI have no idea how this went away.maybe its riding a bike more I really don't know.
Shamrock is offline
Reply
Old 03-25-13 | 07:14 PM
wphamilton's Avatar
Bikes: Nashbar Road
Yes, in fact last fall I stood up quickly from my armchair made it to the kitchen and woke up a fraction of a second before hitting the floor face first. Thank goodness for that fraction and break-fall reactions. I was worried until I decided it was a low resting heart rate - under 40 when most of my life it was 70 or 80. I could be wrong and it's an actual problem but I don't think so. I'd just had a checkup including heart and everything was roses. Your milage may vary.
wphamilton is offline
Reply
Old 03-25-13 | 07:17 PM
15 Anniversary
Mine began after my first surgery in 2000, stuck with me ever since. My doctor schooled me on how to get up from both seated and lying prone to avoid meeting the floor more often. Only passed out 2 times, I flat killed an ironing board and scared our daughter half to death first time ( first renal failure and severe dehydration, ended up in ICU.) Not really serious, usually but as said be careful and let the doctor know what is going on. I have had a fairly low heart rate since I was a teenager, gave the flight surgeons and corpsmen fits until they talked to an FS Cardiologist. I am usually in the mid-low 50s and I only hit 100+/- when I am riding hard.
Bill
qcpmsame is offline
Reply
Old 03-26-13 | 05:39 AM
20 Anniversary
Bikes: '06 Bianchi Pista; '57 Maclean; '10 Scott CR1 Pro; 2005 Trek 2000 Tandem; '09 Comotion Macchiato Tandem; 199? Novara Road; '17 Circe Helios e-tandem:1994 Trek 2300
My resting HR is in the low 40s, but I don't get the dizziness problem. However, I don't train to exhaustion.
Be aware that low resting HR does not always mean fitness as it can be caused by a combination of fitness and a sinus (SA) node deterioration as we age. i.e the heart's electrical sytem is not giving the right signals. If the dizziness worries you, see a cardiologist.
Artmo is offline
Reply
Old 03-26-13 | 06:04 AM
donheff's Avatar
Bikes: Specialized Tricross Comp, Custom Steel Sport Touring, Specialized Turbo Vado 4.0 SL
I too have orthostatic hypotension but it isn't normally frequent or severe. Once in a while I have gotten a particularly bad case after riding hard for 10 or fifteen miles. I feel the symptoms coming on and have to stop and lay down for about 5 or 10 minutes. I keep hydrated and stopped Flomax (for BPH) which exacerbated the problem but I have not found any answers for how to avoid it entirely. It worries me that it might get worse as I age.
donheff is offline
Reply
Old 03-26-13 | 06:11 AM
missjean's Avatar
Bikes: A slate grey mountain bike & a grey road bike
Anemia can cause dizziness.
missjean is offline
Reply
Old 03-26-13 | 06:17 AM
Administrator
20 Anniversary
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Very well said. As others have said, forum input helps someone narrow down their specific problem and it helps hearing other experiences. Going to see a doctor involves a personal decision - you don't go for very single little issue and when you do, it's critical to maximum the time. Most appointments involve a ten minute personal conversation at the most.
StanSeven is offline
Reply
Old 03-26-13 | 07:04 AM
GeorgeBMac's Avatar
You may have orthostatic hypotension -- but the stuff you described is not. Talk to your physician about it when you see him next...
Reply
Old 03-26-13 | 08:19 AM
Blanchje's Avatar
Bikes: GT Carbon Grade, Jamis Nova Pro, Giant Sedona
Always check with your doctor on things like that to be sure there isn't another cause. My dizzyness issues are a bit the opposite. I can get very light headed after a high intensity workout. It's never when I'm working hard but after. I first noticed it while stretching after spin classes. I had a full cardiac workup as my doc discovered I have a left bundle branch block. That's really not the cause but it gave me the chance to discuss it with my cardiologist. He mainly hammered me on hydration and to make sure I was including electrolytes rather than just water. I've paid more attention to my hydration and have noticed it's made a big difference.
Blanchje is offline
Reply
