How Far To Bend An NR Caliper Arm?
Old 10-13-13 | 03:56 PM
fender1's Avatar
20 Anniversary
Bikes: I hate bikes!
Just put a set of Kool Stop, salmon (Campy replacement pads) on a set of NR brake calipers. These are on a Ritchey touring bike w/ VO Raid rims. I had a set of Dia Compe Grey Matter pads on there previously. They stopping power was nothing to right home about. I have a set of the Kool Stop's on another bike, same brakes & same rims. No problems.
The new set howl like crazy on the frnt. I cleaned the rim walls w/ a green scrubby and some Simple Green to make sure there was nothing on the rim. I also cleaned the pads. Still squealing. I know you can bend a brake arm to add some toe but was unsure if there was a specific amount of "adjustment" that should be used?
fender1 is offline
Reply
Old 10-13-13 | 05:24 PM
15 Anniversary
Community Builder
Secret- Bend the mount bolt a tad, enough to produce a 2° twist to the left. Squeal gone.
repechage is offline
Reply
Old 10-13-13 | 05:27 PM
fender1's Avatar
20 Anniversary
On the pad holder, right?
fender1 is offline
Reply
Old 10-13-13 | 05:34 PM
miamijim's Avatar
Sheldon Brown Memorial - Donating
20 Anniversary
I buzz the pads on a bench grinder or file toe into them when I have calipers I'd rather not bend. Make sure there's no excess center bolt play.
miamijim is offline
Reply
Old 10-13-13 | 05:52 PM
1, 2, 3 and to the 4X
Titanium Club Membership
15 Anniversary
You can also sand the rim.
Wheels Of Steel is offline
Reply
Old 10-13-13 | 09:27 PM
15 Anniversary
Community Builder
No, the mounting bolt for the whole caliper. I learned this by having a bike where the fork brake mount hole was off. That bike never squealed from the front brake. As a test, I took another bike that did squeal and whacked the mounting bolt, (yes, you have to tear down the brake) voila, no more squealing. All were Campagnolo Record brakes, very few bikes without.
Reply
Old 10-14-13 | 05:42 AM
rootboy's Avatar
Now that, is very interesting.
rootboy is offline
Reply
Old 10-14-13 | 07:53 AM
Pars's Avatar
15 Anniversary
Bikes: '73 Raleigh RRA, 1986 Trek 500 commuter
^ Yes it is. So one pad winds up toed out a bit?
Pars is offline
Reply
Old 10-14-13 | 08:04 AM
15 Anniversary
Community Builder
Yes, that is the implication. Counterintuitive to standard practice.
Reply
Old 10-14-13 | 08:17 AM
miamijim's Avatar
20 Anniversary
Yes but if the fork hole is straight all it'll do is over toe one side and under toe the other.
miamijim is offline
Reply
Old 10-14-13 | 10:03 AM
3alarmer's Avatar
Bikes: old ones
.......when it breaks, wherever you were a little bit before that.
3alarmer is offline
Reply
Old 10-14-13 | 10:46 AM
onespeedbiker's Avatar
Retro Grouch
Bikes: Yes
After bending the brake arms with limited success, I tried and succeeded with a very thin washer cut in half and mounted under the rear of the brake shoe, against the mounting bolt (to make this easier coat the washer with some sticky grease so it will stay put). Pads are perfectly toed in with no bending, grinding or sanding.
onespeedbiker is offline
Reply
Old 10-14-13 | 10:58 AM
fender1's Avatar
20 Anniversary
That is usually how I figure things out......
fender1 is offline
Reply
Old 10-14-13 | 11:46 AM
Michael Angelo's Avatar
15 Anniversary
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
Now, if someone made a tapered washer.....
Michael Angelo is offline
Reply
Old 10-14-13 | 12:10 PM
Kactus's Avatar
Bikes: 1962 Schwinn Paramount P12, 1971 Schwinn Paramount P13-9
Those would come in VERY handy! But absent that, I may try the half washer.
Kactus is offline
Reply
Old 10-14-13 | 12:39 PM
due ruote's Avatar
15 Anniversary
I agree. I'm guessing that the vibration on one side cancels out the other side, or some such.
https://sheldonbrown.com/brandt/brake-squeal.html
due ruote is offline
Reply
Old 10-14-13 | 01:45 PM
15 Anniversary
Community Builder
Yes, it does toe one side in and the other out but it works.
Reply
Old 10-14-13 | 01:55 PM
ColonelJLloyd's Avatar
Seems like a pretty half-assed solution.
ColonelJLloyd is offline
Reply
Old 10-14-13 | 02:41 PM
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Believe it or not, but one French company did it right in the 80's. Mafac/Spidel, actually designed their pad holders for their sidepulls to be canted couple of degrees in relationship to their caliper arms to produce the required toe-in out of the box. They even beveled the edges of the brake blocks in their molds so you don't have to do any sort of grinding before you mount them on.
One of the reasons I love my LS2 Spidel sidepulls. It had been a plug-and-play on all of the ones I put on my bikes since the 80's.....no judders, no squeals right out of the box!
Chombi is offline
Reply
Old 10-14-13 | 02:42 PM
Old Yeller's Avatar
Bikes: 1987 Trek 1500, 1989 Pinarello Montello, 1998 Trek 7000 MTB
I had some of those finned aluminum Mathauser brake shoes back in the eighties and they came with tapered rectangular washer/shims to adjust toe in. I don't have them anymore but they still might exist somewhere in the world.
Old Yeller is offline
Reply
Old 10-14-13 | 02:46 PM
15 Anniversary
Community Builder
But without fear of cracking things. Fortunately we are discussing Campagnolo brakes, if you try to bend a Universal brand arm... you bend the mount bolt or better than 50/50 the aluminum will fracture. Your kindly editorial comments thankfully precede your frequent attitude toward things.
Reply
Old 10-14-13 | 03:29 PM
rootboy's Avatar
I'm interested in the physics of it. Should all bikes have had a slightly off-center bore through their fork crowns?
I'm no Einstein but it seems like one pad slightly toed in and one slightly out might just work. The infernal squeal might be because pads are too perfectly aligned parallel to the rim.
How's that for a half-assed theory?
rootboy is offline
Reply
Old 10-14-13 | 05:27 PM
Road Fan's Avatar
20 Anniversary
Kinda strange, I've never had a NR caliper squeal, at least if the pivot fit the arms properly and teh bolt was drawn up correctly. But I've always used original Campy shoes on them.
Road Fan is offline
Reply
Old 10-14-13 | 05:32 PM
Bikes: 8
I slipped in KS (black) pads, in the Campag holders, and I too have no squeal .
fietsbob is offline
Reply
Old 10-14-13 | 07:43 PM
fender1's Avatar
20 Anniversary
The squeal is gone, I did the following:
Very light sand to the rims with 100 grit paper, very slight bend to the right brake arm and tightened down the mounting bolt. The mounting bolt was pretty loose, like Jim had mentioned and I am guessing that may have been the main culprit. I did the other stuff first. Works well now.
fender1 is offline
Reply
P!N20
Classic & Vintage
32
06-22-19 11:11 AM
jyl
Bicycle Mechanics
24
08-18-15 01:23 PM
Phil_gretz
Bicycle Mechanics
5
04-21-15 07:37 AM
reggieob
Classic & Vintage
36
01-07-15 12:10 PM
dddd
Classic & Vintage
8
04-09-12 06:23 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
