Snapped my chain!!! Less than 100 miles...
got the climbing bug
Bikes: one for everything
looks like one of those KMC superlite chains. I just run their normal X10 chains for all my bikes except for the singlespeed, that gets a SRAM 8spd. Their regular chains last a LONG time before having shifting issues and never broke one.
You can carry a sram 10speed power link if you want to keep running the light weight stuff but I'm sure you busted a nut or knee on your stem when it broke
Rule #10 // It never gets easier, you just go faster.
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
I got to the bridge and the bikepath was closed due to construction. So I turned around and was going to head down to Marble Hill and cross over onto Broadway then just shoot over to the West side bike path to continue my trek to Gowanus... I was stopped at an intersection, I got the green, got on it pretty gently, on the inner ring and all that, and my crank just spun out underneath me and I thought I dropped the chain...I looked again and realized...I have no chain! I looked behind me and it was lying in the road so I fetched it.
I coasted down the 2 mile hill I just climbed, a good small LBS at the base, and they weren't open, even though it was noon and the sign said they open at 1130am.
I called my shop in BK, told them what happened, and I just hopped on the Subway (Station was right there...) and did the walk of shame. Of course I didn't roll my steed along, but hefted it upon my shoulder as manly vanity and pride demand...
Seemed to be a perfect storm combination having to do with apparently I'd stretched the FD cable and a possible manufacturer's defect with the chain. No cracks on the outside, etc... It just popped open. Ultegra 10 spd.
Then I hauled ass back from Brooklyn to duh Bronx and made it just before sundown, so I didn't have to kill any zombies.
Cat 5 field stuffer
Bikes: Wabi Lightning RE, Wabi Classic
just pedal
Bikes: Surly Disc Trucker, trek 560
Getting older and slower!
Bikes: Trek Domane 6 series Project One, Bike Friday Pocket Rocket, Trek XO1, Specialized Turbo Vado 6.0
Yes, it was certainly a defective chain. New chains don't break from hard riding. In my many years of riding (over 40) and usually doing more than 3,000 miles a year, I have only needed a chain tool out on a ride once. I don't even carry one with me any longer. (I do regularily check my chain for wear and it is almost always properly lined.)
Bikes: More than 1, but, less than S-1
I used to carry a multi-tool that included a chain tool. But, I've down sized to a Lezyne RAp-6 which does not. However, I still carry a spare quick link. Enough wiggling and bending will see a determined cyclist get the other end of the outer plate off the other pin. Then it's a matter of getting the pin through the inner half link. Between rocks and fences and the occassional leatherman or pliers from a passing motorist or farm, I will find a way to get the pin extracted from the remaining inner half link. I have little doubt. My will to ride home instead of walk is that strong.
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
Cat 5 field stuffer
Hook 'Em Horns
Bikes: Mine: Paul Taylor Custom 66cm, Rivendell custom 68cm, '75 Eisentraut Touring 69cm, 68cm track frame of indeterminate origin, '92 Cannondale M500. Ours: '93 Burley Duet tandem XL. Hers: L Mercier Sora thingy
You really need a chain breaker, like a Park CT=5 https://www.parktool.com/product/mini...hain-tool-ct-5 plenty of other makes also available. You would need to remove the rivets & outer plates so you have both ends which terminate with inner plate, then you can then join them with a masterlink. SRAM, KMC & Connex make these, make sure you use the correct one for your chain speed.
Bikes: Borealis Echo, Ground Up Designs Ti Cross bike, Xtracycle, GT mod trials bike, pixie race machine
This is filled with win.
Thread Killer
Thread Killer
Klaatu..Verata..Necktie?
I never broke a chain, but I once broke a rear derailleur cable 8 miles from home in the pre-cell phone era. Luckily the multitool I had included a chain tool, so I opened the chain, pulled it off the rear der, and rewrapped it onto the small ring and the largest cog I thought I could push on the hills I needed to climb,removed the necessary links and road home as a single speed. Now I always carry a chain tool in my bag.
But now I also always carry a cell phone, too.
Thread Killer
just pedal
or remove the cable and slip it though the rear der without the housing so the cable end/stop that would be in the shifter is in the barrel adjuster, lock the cable in the tension bolt as normal and then you can adjust the barrel till the chain sits in the gear you want it to be in... very crude way of a SS... or at least a VERY wide 2 speed/3 speed if you've got front gears... I imagine you could also use a string in a real bind
The way you'd expect - lack of preventive maintenance! I'd ridden that bike through a wet winter and not redone the cables since it was new.
Man! You're tough on chains! There are so many little nicks in that chain that it is hard to believe that it only has 100 miles on it. It looks well and long used.
Another recommendation for the Park CT-5 and a SRAM quick link. Keep in mind about big-big until you can verify the chain length.
Thanks for this, I'll add it to the onboard kit...
I figure the KMC "Missing Link" will do the trick?:
