What's your favorite Carbon Fiber Fork
Old 04-22-05 | 02:16 PM
JeStOnE's Avatar
Its already fixed
Bikes: 1990 Ciocc Pista, 1972 Schwinn Paramount P10, Fuji Track, KHS Flite 100, Cannondale M400, Raleigh Twenty, 2004 Bianchi Pista, 2005 Bianchi Pista
Im planning on getting a carbon fork when my taxes come in. My question is what if any would be the most reliable to deal with street riding as well as lightness?
JeStOnE is offline
Reply
Old 04-22-05 | 02:49 PM
Jose R's Avatar
20 Anniversary
Bikes: Custom DeanUSA El Diente CTI, Rich Adams Track, Johnny Coast Fixed, Argon18 Gallium Pro
Er, what bike will you be using the fork with? Reynolds has a good reputation. True Temper Alpha Q forks are very good too. Advanced composites Wound-Up are nice too.
Reynolds forks: 372mm crown to axle length, 1"-1 1/8" steerers, 37.5mm - 50mm rake
True Temper: 374mm crown to axle length, 1" - 1 1/8" steerers, 38mm - 50mm rake
Advanced Comp: 366mm crown to axle length, 1" - 1 1/8" steerers, 35mm - 48mm rake
Measure your current fork for both length and rake. Figure out your head tube angle. Use this site to figure out trail.
Read this page to understand the effects of switching out your current fork with a carbon fork.
Pick one of the above forks that doesn't affect steering in a negative way.
Personally, I use TT Alpha Q forks. Love 'em.
Jose R is offline
Reply
Old 04-22-05 | 03:25 PM
Bikeophile's Avatar
BIG RING
The Columbus forks are nice too. My road bike has a Columbus Tusk Road fork and love it. My fixie has an EVO Carbon fork. Its not so light for carbon but has been perfect for 3 full years of 4season commuting (100+miles per week).
Cheers
Bikeophile is offline
Reply
Old 04-22-05 | 04:08 PM
JeStOnE's Avatar
Its already fixed
05 bianchi pista
JeStOnE is offline
Reply
Old 04-22-05 | 04:42 PM
Jose R's Avatar
20 Anniversary
Originally Posted by JeStOnE
05 bianchi pista
Ok, the 2005 pista has a 74/74.5 degree head tube angle, one inch threadless headset, and 28mm of fork rake. (When you get the chance, measure the top of the crown to center of the axle of the fork.) I will assume its ~368mm.
Using one of the standard carbon forks like reynolds or TT will raise your front end just bit and slacken your angles. Using the Advanced composite fork might lower your front end and steepen your angles. Maybe not enough for you to notice, but then again maybe so.
Your fork rake is 28mm. I would try to get as close to this as possible.
Going with a carbon fork with a rake of 40mm or more will cause your bike to be way too twitchy. Most available carbon forks come in rakes of 44, 45mm. Depending on the height of the fork and how its affect your head tube angle, your end result trail might go as low as 5.0cms or lower. This is dangerous territory.
Your current trail is 6.6-6.9cm, depending on what size frame you ride. A very stable ride.
Then there is the problem of your 1" threadless steerer. Most manufacturers of carbon forks will only have forks with rakes in the 45mm range with 1" steerers. The wider range of forks come in 1 1/8" steerers.
This leaves your with one good safe option: the Advance Composites fork in 1" steerer with 35mm of rake.
Because of the height of the fork, it should not affect head angles too much, if at all. It will give you more neutral handling, 5.9-6.2cm of trail, and you will be able to run a front brake confidently.
The fork is $295 retail for a steel steerer. $375 for a carbon steerer. These forks are a little heavier than some of the other carbon forks. Btw 470gms-510gms.
Jose R is offline
Reply
Old 04-22-05 | 07:11 PM
auk
Coasting makes you grumpy
20 Anniversary
Bikes: Specialized Stumpjumper M2Comp; Habanero Ti-Team; Slingshot Road; 1962 converted Raliegh fixer aka: The Beast
I have a Wound Up on two of my bikes. Habanero Ti Team Pro and my converted Slingshot. Absolutely love teh ride of the fork and the performance. The Slingshot has a steel steerer while the Habby has the carbon. As Jose R points out, they are not the lightest of the bunch, but they are real close. The Alpha Q requires a sleeve insert in the carbon steerer which brings the weight up by about 50 grams, while the Wound Up does not require that same insert.
I love the looks of the Wound Up and the Alpha Q, but my nod goes to the Wound Up in the looks department due to the polished crown and cammo carbon legs.
auk is offline
Reply
Old 04-23-05 | 12:21 AM
hella's Avatar
polishing my grill
Bikes: Croll
Word up Wound Up.
hella is offline
Reply
Old 04-23-05 | 03:59 PM
JeStOnE's Avatar
Its already fixed
Glad to hear you guys recomend the wound up, thats what I was thinking as my final choice. I figure that combined with some bull horns would prolly drop some weight off the bike.
JeStOnE is offline
Reply
Old 04-23-05 | 04:01 PM
hella's Avatar
polishing my grill
Bikes: Croll
Yeah it's awesome. You just have to be prepared to part with an enormous chunk of change.
hella is offline
Reply
Old 04-23-05 | 04:09 PM
flythebike's Avatar
Wher'd u Get That Jacket?
Bikes: Calfee Dragonfly, Lemond Poprad, Airborne Manhatten Project, Calfee Luna Fixie
I have Alpha Qs...love 'em. Reynolds is a bit more solid, but heavier. Alpha Q seems to handle better.
Listen to Jose R about the technical aspect. You have to understand what you're doing there or you'll screw it up.
flythebike is offline
Reply
Old 04-24-05 | 07:57 AM
current member
Bikes: some- variety is good..
the colnago
any day.. it comes in 1" too.. and it has very good manners i love it, but on a track bike? ride a track fork. me tinks..
or make a conversion bike as a commuter, and ride your track bike for special occasions, or..? just ride.
cphfxt is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
