Click noise from my left crank/pedal/bb?
Old 04-29-09 | 05:08 PM
guaps's Avatar
I just finished building my bike, so all the parts (except for the frame) are new. Starting the first time I was on the bike, the left crank clicks. It clicks once when I start to pedal hard and then makes no noise at all until I backpedal to slow down, then it clicks again. I can't figure out what it is. It only happens on the left side and it is an italian threaded bottom bracket.
Things I've considered or tried to fix the problem: (i read a bunch of threads on here and got these ideas)
-I tightened the pedal and crank bolts. No change
-I read this (https://www.sheldonbrown.com/creaks.html), but nothing really sounds like the same problem I am having
- I don't think it's the bearings as many threads suggested since this is all brand new stuff.
Any ideas??? Thanks!
guaps is offline
Reply
Old 04-29-09 | 05:12 PM
carleton's Avatar
Elitist
Put these guys on the case. They are awesome: https://www.bikeforums.net/bicycle-mechanics/
carleton is offline
Reply
Old 04-29-09 | 05:17 PM
guaps's Avatar
Originally Posted by carleton
Put these guys on the case. They are awesome: https://www.bikeforums.net/forumdisplay.php?f=10
Good call - I should have thought of that forum first. They helped me fix the problem with my headset when I was building the bike. I'll go repost over there.
Thanks!
---- EDIT ----
Here's the thread in the mechanic forum for anyone that has input or finds this in a future search
https://www.bikeforums.net/showthread...61#post8824561
guaps is offline
Reply
Old 04-29-09 | 07:22 PM
the_don's Avatar
I had the same problem on my full suspension DH bike. Heavy pedaling made a clicking sound that seems to come from the crank arm, except I was getting it from both arms. I took it to shops and they said of could be one of many things, I tried tightening the pedals, cranks, BB, suspension linkage bearing nuts. And finally I had the idea of trying to regrease the threads of my pedals, so I took them off, applied a load of dura-ace grease and put them back on. Voilą!!!! Annoying clicking stopped!
the_don is offline
Reply
Old 04-29-09 | 09:26 PM
rrooster's Avatar
Bikes: Motobecane Messenger
I just started getting the same problem... I'll try greasing it.
rrooster is offline
Reply
Old 04-30-09 | 07:57 AM
jpdesjar
Guest
Posts: n/a
i am hearing some clicking too
i am going to try greasing the threads...thanks!
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
