Clicking noises after skidding?
Old 05-26-09 | 09:38 PM
Saberhead's Avatar
Bikes hella booty!
Bikes: 725TR Leader
I was out riding this evening and was practicing skidding down a steep hill from my house. I usually brake the whole way down this on my way to work, but wanted to try skidding since I'm not too great at it. After maybe 20 minutes of doing this back and forth for practice I'm hearing a clicking noise when I ride on flat road.
Normal? Everything feels ok, just a click that wasn't there before.
EDIT: The bike is clicking, not my knees
Saberhead is offline
Reply
Old 05-26-09 | 09:40 PM
i heard skidding can be hard on your knees. have you checked your knees? maybe you should see a doctor.
piane is offline
Reply
Old 05-26-09 | 09:48 PM
hammerdown48/13's Avatar
Ill-Town Rock.
Bikes: Waterford - Reynolds 853; Shimano 105 Head Set, Velocity Deep V Rims, Shimano Ultegra Crank, Milwaukee Bicycle Co. Front Hub, ENO Adjustable Rear Hub, Michelin Carbon Tires, Dimension Stem, 42/13 Ratio
where is it coming from? can you pinpoint the noise? does it happen only when riding? or will it happen if you turn your bike over and give it a spin?
hammerdown48/13 is offline
Reply
Old 05-26-09 | 10:00 PM
Saberhead's Avatar
Bikes hella booty!
Bikes: 725TR Leader
It's definitly coming from the rear wheel. Isn't as loud when the bike is over and I give it a spin but it's there. Something maybe with the rear cog? I have no clue
Reply
Old 05-26-09 | 10:14 PM
Ill-Town Rock.
chain look okay? check your lock ring... still tight? pull your chain.... any tooth damage on your rear cog? (looks like a sharkfin) also give it a spin off chain...
if you are sure it is you rear ignore this... but a loose chainring will cause a clicking noise... check your bolts...
Reply
Old 05-26-09 | 10:16 PM
Most likely your lock ring is the source of the problem. If you keep hearing more clicking or feel sudden jolts while you skid, its definitely your lockring. It's coming off, shredding your threads on your rear axel. Definitely take it to a shop right away and stop skidding before you're left with two threads to work with on your rear axel... like me.
auddie is offline
Reply
Old 05-26-09 | 10:20 PM
prawza's Avatar
Bikes: Avanti ventura, Fuga Track Bike
could be a loose spoke too..
prawza is offline
Reply
Old 05-26-09 | 10:24 PM
Ill-Town Rock.
tousche.
Reply
sp00ki's Avatar
partly metal, partly real
Bikes: Hummer H2
it's probably your chain. going back and forth snaps the slack one way or the other.
sp00ki is offline
Reply
Old 05-26-09 | 10:27 PM
Ill-Town Rock.
this is happening when she rides on a flat road... so there technically should be no back and forth...
Reply
Old 05-26-09 | 10:58 PM
Saberhead's Avatar
Bikes hella booty!
Bikes: 725TR Leader
Chain seems ok, there is slight slack but barely noticable. Cog seems ok...but I was worried that the it might be the lockring.
EDIT: A couple months ago I went to someones house to change my rear cog to a different size. What ended up happening was we couldnt get the original cog off at all. The guy that was switching the cog out was worried he was going to strip my threads so we just left it on (happy now that I didnt switch it out), but Im wondering if maybe it did strip a little, is this possible? I wasn't skidding at that point which I am a lot more now. Don't know if this is the reason.
Reply
Old 05-26-09 | 11:11 PM
cblaster's Avatar
Bikes: 199X Bicycle Corporation of America Rival Road Bike, 1970s Auto-Mini Junior, 2009 Windsor Hour
I had the same problem and it was one of my chainring bolts. It might not hurt to check them to make sure they are tight.
cblaster is offline
Reply
Old 05-26-09 | 11:54 PM
ride dirty
check your rear tire. I know it sounds funny, but just yesterday I kept hearing a weird clicking noise from my rear tire after skidding a bunch and it turned out to be sharp-ish pebbles jammed into the rubber. every time they'd rotate around..clickclick. just scraped them off.
beanswuah is offline
Reply
Old 05-27-09 | 12:09 AM
Saberhead's Avatar
Bikes hella booty!
Bikes: 725TR Leader
ha thats kinda funny, Ill see if thats the case. I have a feeling it's got something to do with cog/lockring/hubs,..I seriously hope it's a simple case of pebbles in my tire lol
You're from Seattle aswell?
Reply
Old 05-27-09 | 12:30 AM
ride dirty
yup. I ride around the u-district almost every day cause i'm a student, so if you see a dude on a bronze-ish converted fuji, holler. all I can say is if it's NOT the pebbles, go and get it looked at in the shop soon!
Reply
Old 05-27-09 | 01:28 AM
Well since its just clicking noises and no jolting motions or anything, shouldn't be your lockring. If your lockring is coming loose or stripping threads off your axel, then you'd feel a couple of big jolts before you go freewheel. Clicking noises would probably come from your chain/cog or hub.
auddie is offline
Reply
Old 05-27-09 | 01:41 AM
steveymcdubs's Avatar
christ. there are so many udistrict kids here.
steveymcdubs is offline
Reply
Old 05-27-09 | 03:14 AM
sickz's Avatar
i second what someone said above... when you skid your tire tends to pick up whatever's on the road, and if it's sharp enough it'll embed into your tire... hopefully it's small pieces of granite that you can just rub off w/ your hand.
sickz is offline
Reply
Old 05-27-09 | 03:46 AM
erichsia's Avatar
thread derailleur
Bikes: 82 Bianchi ECO Pista, Pake, Kilo TT, some *** bmx i found underneath an old house
She hears it when she's got the bike turned over, so it can't be her tire. Chainring bolts and loose spoke seem to be more likely.
erichsia is offline
Reply
Old 05-27-09 | 09:24 AM
jaggd's Avatar
My most recent experience with clicking noises turned out to be improperly tensioned spokes. Earlier, I had checked everything else I could think of (chain, chainring, chainring bolts, cog, lockring, bb, cranks) and it all looked fine. I brought it into the shop, and to my surprise, they said it was the spokes on my rear wheel.
jaggd is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
