Compact Double - Lowest gear ?
Old 07-19-05 | 06:06 AM
Corsaire's Avatar
Dancing on the Pedals
20 Anniversary
All these threads about double and triples, have made me wonder about something:
What's the LOWEST attainable gear you can have with a Compact Double ?
(say, is it a 34x28 or 32?)
Right now, I have an Ultegra triple which bails me out on the steepest climbs after long summer rides at a hard pace, where most of the time find myself in my 30x21.
Corsaire
Corsaire is offline
Reply
Old 07-19-05 | 06:38 AM
Grasschopper's Avatar
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
I run a 50/34 with a 12-27 cassette which replaced a 52/42/30 triple with a 12-25 cassette. When you compare the 34-27 combo with the 30-25 combo you can see that it is pretty close but not quite as low. If you look at Sheldon Brown's gear calculator and compare the two set ups it looks like this:
30-21 = 37.5 gear inches 34-24 = 37.2 gear inches
30-23 = 34.3 gear inches 34-27 = 33.1 gear inches
30-25 = 31.5 gear inches
These numbers are generated with a 700x23 wheel/tire and a 172.5 crank for both combos. As you can see the 30-21 is nearly identical to 34-24 and the 34-27 is in between the 30-23 and 30-25. I have about 400 miles on my compact setup now and have found it to be very nice and the low gears are plenty low even to get over a big steep climb at the end of a long ride. Persoanlly I like the compact double better than the triple.
The views expressed by this poster do not reflect the views of BikeForums.net.
Grasschopper is offline
Reply
Old 07-19-05 | 06:41 AM
53-11_alltheway's Avatar
"Great One"
From: Might as well be underwater because I make less drag than a torpedoE (no aero bars here though)
34-27 which is a pretty darn low gear. That's something like a 39-30/31.
If you have Campy you would have a 34-29.
53-11_alltheway is offline
Reply
Old 07-19-05 | 06:51 AM
sydney's Avatar
20 Anniversary
Originally Posted by Ben Cousins
Depends on the sizing limits on the chainset and your rear mech.
I'm sure you could get 34:34 if you got the right Shimano rear mech.
Try a 33 small ring on a 110 crank,then go get a freewheel with a 38 cog.
sydney is offline
Reply
Old 07-19-05 | 10:17 AM
20 Anniversary
The lowest double I have seen is a 28/38 using a Stronglight Escapade crankset. You can't get that low using a typical compact double.
MichaelW is offline
Reply
Old 07-19-05 | 10:58 AM
Fox Farm's Avatar
20 Anniversary
Bikes: Time ADH01, Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
I used a 34 / 29 up Mt. Washington once and that was fine. Anything less and I would feel like I was moving faster in circles than forward.
Fox Farm is offline
Reply
Old 07-19-05 | 02:50 PM
ggg300's Avatar
Burnin' and Lootin'
34/34 with ATB cog set in back is about as low as you can get without getting some odd front ring or odd free wheel, but you'll need an ATB rear derl. That is the most practical way to get a lower gear for the compact. What is kinda cool about that set up is in regards to the 50t up front with the second cog down from that cog set. That gear is a cross chr. with a standard road cog set like the 12-26 but can be used with the 50 big ring and is nice for short rolling hills with a good grade at the top.
ggg300 is offline
Reply
Old 07-19-05 | 03:02 PM
OB1's Avatar
OB1
I have this setup on one of my bikes and could not agree more. Rarely do I need the 29. For most of my longer climbs 0.5-1m 6%grad (long where I live), the 34/23 works perfectly well.
OB1 is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
