chain rub w/ FSA compact crank
Old 08-10-04 | 06:20 PM
labman's Avatar
20 Anniversary
Bikes: Merckx Alu Cross, Cannondale Super V 900.
Just installed an FSA compact crankset, and when the chain is in the front 34 ring, and rear 12 cog there is a very slight rubbing of the chain against the inside of the 50 ring. I have adjusted everything possible, and can't get rid of it. I am using a Shimano HG chain. Should I try a different chain, or just learn to live with it? Any ideas?
labman is offline
Reply
Old 08-10-04 | 06:27 PM
20 Anniversary
Bikes: Peugeot Hybrid, Minelli Hybrid
Maybe if you put a spacer under your drive side BB it will reduce the angle enough to eliminate the rub. You will have to watch for clearance between your left crank and chainstay. Otherwise you will need a wider BB.
AndrewP is offline
Reply
Old 08-10-04 | 06:44 PM
labman's Avatar
20 Anniversary
I could try a BB for a triple, but I don't think the drivetrain will line up correctly. I have been looking around the web, and it seems to be a common issue, and many people had said that you are not supposed to use the smallest rear cog while in the 34 ring.
labman is offline
Reply
Old 08-10-04 | 07:01 PM
Shadco's Avatar
Old and in the way
Titanium Club Membership
20 Anniversary
Community Builder
Bikes: Look 765 Optimum, Spesh Aethos
Normal, mine does the same on the 2 smallest cogs on the cassette. Just don't use those as you should be on the big ring before then anyway.
Shad, Kitted up half wavin m’fer.
Shadco is offline
Reply
Old 08-10-04 | 07:34 PM
sydney's Avatar
20 Anniversary
Just stay out of the small cogs when in the 34! A narrower chain could work but is not the correct solution.. It even happens on many bikes with 39/53 rings depending on chainstay length.and chainline.
sydney is offline
Reply
Old 08-10-04 | 07:36 PM
sydney's Avatar
20 Anniversary
They are RIGHT!
sydney is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
