Info on a 2 speed FG
Old 12-15-04 | 10:28 AM
Cynikal's Avatar
Titanium Club Membership
20 Anniversary
Bikes: Too Many
I just got an email from Val Kleitz from Bikesmith in Seattle. He is starting to build 2 speed FG hubs again dur to demand. Here is the email.
"Chris: Finally, a note to let you know that I hve begun producing 2 speed fixed hubs again. They will be $200.00, and will come with instructions and all necessary hardware to attach to the shifter of your choice. Let me know what you think. Val Kletiz"
You can drop him an email for more info instigator@thebikesmith.com
Thought I would share.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
Old 12-15-04 | 01:11 PM
20 Anniversary
Uh, I think you mean "double sided"???
peligro is offline
Old 12-15-04 | 01:47 PM
SSSasky's Avatar
Mo' Senior
I could be wrong, but I'm pretty sure he actually means 2 speed fixed hubs. They work like most internally geared hubs, only without the coasting. I'm too lazy to look up the link, but Sheldon Brown has extensive info about them. I think it was Strumey Archer that used to make a three speed version. It's a great idea. I wouldn't mind checking one out.
Anyways ...
SSSasky is offline
Old 12-15-04 | 02:56 PM
formulaben's Avatar
Bikes: Felt F2C, Scott Spark 40, and Custom Fixie
Sheldon Brown's Sturmy-Archer 3 speed fixed gear hub webpage
formulaben is offline
Old 12-15-04 | 04:38 PM
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
yup..Bikesmith takes a bendix 2 or 3 speed internal hub and converts it to a fixed gear hub. Comes with a 18 tooth cog and a 1 to 1 gear with the second a 30% drop. here is a link if you want to DIY https://www.63xc.com/lewisc/diy2fg.htm
Really cool idea for those who live in hilly areas.
Cynikal is offline
Old 12-16-04 | 01:15 AM
Bikes: Rudge Sports, Robin Hood 3 speed, Hercules touring, a fleet of big black lugged city bikes
Sturmey Archer had 2 and 3 speed fixed gear hubs and a flip flop with two fixed internal gears and a freewheel on the other side, most of the hubs were built before the WW2, the 3 speed ASC hub was built in the 40s and 50s. In the fixed gear gallery there is a Hercules with a 2 speed fixed gear made out of an AW hub, I'm guessing he used the modifications shown on Sheldon Brown's site.
Is Bikesmith still around? I heard they went out of business.
Rudgey is offline
Old 12-16-04 | 11:52 AM
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
Yeah, sadly Bikesmith is out of business.
Cynikal is offline
Old 12-16-04 | 12:34 PM
I happen to have a Bendix that would work perfect for the 2 speed fixie. Has anyone else tried this loctite/JBweld like the 63xc article outlines with success?
michiganmogo is offline
Old 12-16-04 | 01:54 PM
i havent tried the jb weld on the bendix, but as i had a few sturmey archer 3speed hubs sitting around, i thought id try jb welding them... so far ive got to run left hand drive and the second gear isnt working... but im still tinkering with it... i hope i can get it to work, but fear that i wont in which case ill need to find myself a bendix to fix
invisible is offline
Old 12-16-04 | 04:19 PM
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
is there a good source for bendix hubs? I haven't had any luck finding one.
Cynikal is offline
Old 12-16-04 | 04:27 PM
ink1373's Avatar
nothing: lasts forever
this is for when we're old old men...
good ol' fixed is fine with me.
ink1373 is offline
Old 12-16-04 | 05:20 PM
HereNT's Avatar
無くなった
20 Anniversary
Bikes: I built the Bianchi track bike back up today.
Or if you move away from here and find yourself amongst hills and don't want to coast...
HereNT is offline
Old 12-16-04 | 06:57 PM
i havent been able to find a source for bedixes but i did get my s/a to work...i only had to run lhd, but it goes and its fun! theres a bit of slop in the system, so im not sure ill stick to it, but itll be good fun for a while
Old 12-17-04 | 11:10 AM
Double yeah, after Supergo opened up about 4 blocks away. The story I heard was that they offered Val a job and he declined. I've seen his 2 speed conversion and it's worth considering if you absolutely need the range.
Just to reminisce, over the years I must have acquired at least three frames that I fixed at Bikesmith. Val could also be counted on for a complete assortment of cheap cogs from 14 to 24. That and the enormous pile of old Winnings and Bicycle Guides made it a cool place to hang out.
Marron is offline
Old 12-17-04 | 11:37 AM
Cynikal's Avatar
20 Anniversary
Bikes: Too Many
I got in there once or twice while living in Seattle. Sadly this was way before I found the way of the fixed.
Cynikal is offline
Old 03-03-13 | 06:30 PM
hey a friend of mine told me to go put my idea up on a forum, i am currently making this TRUE fixed 2 speed with a 2 speed front crank. what i am using is a modified tensioner and a clutch type mechanism. i am using a thumb push shift to move the front derailer, and for my "clutch" i am usng an old style road bike brake lever, i am putting a parking break style lock (idea came form atv parking break) to keep tension in chain when i am on the lower gear. im sure you cant imagine what i am doin till u see pics, but i am currently in the middle of gathering up parts and starting to put my hand drawn designs into effect. when i get some pics together ill post them.
haro85x is offline
Old 03-03-13 | 06:51 PM
Bat56's Avatar
Originally Posted by haro85x
...im sure you cant imagine what i am doin...
pretty much
Bat56 is offline
Old 03-03-13 | 08:00 PM
Dannihilator's Avatar
Still kicking.
Sheldon Brown Memorial - Registered
20 Anniversary
Bikes: Bike Count: Rising.
Tensioner will fail.
9 year old thread is closed.
Appreciate the old bikes more than the new.
Dannihilator is offline
Thumpic
Classic & Vintage
11
09-13-16 09:35 AM
Sirrus Rider
Bicycle Mechanics
7
07-20-12 11:19 AM
me and my bike
Singlespeed & Fixed Gear
17
05-15-12 07:01 PM
dolphin62
Commuting
3
08-20-11 11:57 AM
Tony Pham
Bicycle Mechanics
6
11-21-10 01:14 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
