Maintain that sexy (or not so sexy) track headset
Old 07-03-06 | 05:20 PM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
Bikes: Titus road, Fort CX
I know that there are a good number of people running non-cartridge headsets that might not know how to repack/maintain this piece of equipment. These instructions can be applied to most non-cartridge bearing headsets, like Tange, Shimano, Campy, etc.
Tools I used:
32mm wrench, toothbrush, grease, rags, beer, pencil, allen wrench set
1. Remove stem/handlebars set-up.
2. Remove top nut on headset (32mm wrench).
3. Remove spacers (if there are any) by hand.
4. Remove top bearing cup (32mm wrench)– note: do this slowly to prevent loss of loose bearings.
5. Slide fork down slowly out of headtube. Again, do this slowly as to not lose any bearings or damage the bearing cages.
6. Wipe grease off all four surfaces that contact the bearings. Run a pencil on these surfaces to check for pitting and wear.
If contact surface is pitted, you can continue to run the current headset until it is totally useless, or replace it. Your call.
7. Clean bearings and cages (I do not remove the bearings from the races).
Use a small glass or plastic tub. Place one cage/bearing set in at a time and coat with biodegradable degreaser and let sit for a few minutes.
Things to do during this time:
-Enjoy a beer or another favorite beverage.
-Call your significant other (If you do not have a significant other, weep quietly).
-Contemplate running for the presidency of a far-off nation.
-Plan next trip to oral surgeon.
-Start a whiny thread about IRO.
After soaking, brush ‘em up (careful not to dislodge a bearing or two…or more) gently with the toothbrush to get the grease out of the cage area.
*note – you can replace the bearings/races if you wish to do so. Make sure you obtain the correct parts as per your headset manufacturer’s instructions.
8. Brush dirt/grease from threads on steer tube. Regrease as you see fit.
9. Make sure everything is dry and pretty! Regrease top race and seat the bearings. Do the same on the fork race. Grease cups (loose and seated).
10. Install fork:
Re-install top cup. Replace spacer and top nut: Hand-tighten (do not fully tighten this yet!) everything back together.
11. Check for smoothness – if not that smooth, try a little more grease…or less. Depends on how much you initially applied!
12. Once it is nice and smooth, grab your wrenches and snug up your nuts! DO NOT OVER-TIGHTEN. This may induce pitting over time. The fork should spin freely.
(see next post in thread for final result...)
pitboss is offline
Reply
pitboss's Avatar
cxmagazine dot com
20 Anniversary
13. Re-install stem/bars and front wheel-ready to go!
Hope this is helpful!!!
pitboss is offline
Reply
Old 07-03-06 | 05:22 PM
onetwentyeight's Avatar
blah
oh cute, you and kyle have matching handlebar setups.
(good post, tho. i gotta do that soon)
onetwentyeight is offline
Reply
Old 07-03-06 | 05:23 PM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
yeah - i liked what he ran - diff grips though
pitboss is offline
Reply
Old 07-03-06 | 05:25 PM
dirtyphotons's Avatar
antisocialite
that's awesome, thanks 165
dirtyphotons is offline
Reply
Old 07-03-06 | 05:26 PM
Terror_in_pink's Avatar
Bikes: Custom Holland Ti road bike, Custom track bike I traded a painting for.
josh? time to get a job no?
ha! That's nice of you, nice and thorough too.
Ode to the after work nap ( ride your bike instead)
Ode to the nap
The evil, evil nap
It lures
you succumb
But only with good intent
Shortly I will rise
But you do not.
Do not succumb
To the evil, evil nap
Terror_in_pink is offline
Reply
Old 07-03-06 | 05:34 PM
SamHouston's Avatar
Good Afternoon!
Bikes: Various by application
That **** deserves webspace with the description & pics you made doing it. I've always wondered if the aheadset gen got confused by this sort of thing, went to the lbs each time or took the time to learn it somewhere (like your tutorial!) good work
SamHouston is offline
Reply
Old 07-03-06 | 05:42 PM
spud's Avatar
i am sure that i hate you
Bikes: 'Cha-ruzu Fosuta Orusan Kein' Fuji Track (2005), Schwinn Tank MTB (?), Fuji Royale (1979)
are you using the tennis ball to polish your front hub?
putting the pi back in pirate!
It’s an upstanding member of the solar system
Apply the laws of earth and make it a victim
Of Proposition 187
spud is offline
Reply
Old 07-03-06 | 05:47 PM
genericbikedude's Avatar
如果你能讀了這個你講中文
if that was a wiki, I would add something about considering switching to loose balls. grade 25 steel balls roll smoother and arent expensive. cages are easier to deal with but not quite so smooth. not that it ****ing matters in a headset. but still.
Don't leave that on bike forums, send it to FGG or something for the right bar.
genericbikedude is offline
Reply
Old 07-03-06 | 05:48 PM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
nice add-in, generic. I might try your suggestion!
pitboss is offline
Reply
Old 07-03-06 | 05:55 PM
HereNT's Avatar
無くなった
20 Anniversary
Bikes: I built the Bianchi track bike back up today.
I kind of did that on accident when I was packing my bike up to head over for the last MNG. I was really happy when the fork fell out and I found out I had caged bearings...
Really [165], what are you doing putting useful stuff on here? Isn't that against the rules?
HereNT is offline
Reply
Old 07-03-06 | 05:59 PM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
Wait until i get the BB one finished! I ran out of beer though...
pitboss is offline
Reply
Old 07-03-06 | 06:02 PM
visitordesign's Avatar
keep it pretend
Originally Posted by genericbikedude
if that was a wiki
forthcoming...
edit: not [165]'s article (unless he contributes it), something different, but it'll have the functionality GB mentioned. just wanted to clarify...
visitordesign is offline
Reply
Old 07-03-06 | 06:12 PM
HereNT's Avatar
無くなった
20 Anniversary
Crap! All I have are sealed ones now... I'd try to beat you to it...
I kind of doubt my 'here's how you use the blue loctite to keep the unit from unthreading after you partially strip the threads in your Itallian threaded frame' advice would be all that useful anyways. Or maybe it would...
HereNT is offline
Reply
Old 07-03-06 | 06:23 PM
I'm about to do my first cup and cone bottom bracket installation - a BB post like this one would be dope.
Döner kebap is offline
Reply
pitboss's Avatar
cxmagazine dot com
20 Anniversary
by tomorrow for sure.
pitboss is offline
Reply
Old 07-03-06 | 09:23 PM
koyman's Avatar
Good for Business
Bikes: Team Fooj
This is an awesome guide.
I second the send-to-fgg so that this can get the attention it deserves (as well as reaching/helping maximum people blahblah). First though; fine tuning here.
Above all: thanks man, this is totally "deck" (I'm hip, I'm cool).
koyman is offline
Reply
Old 07-03-06 | 09:30 PM
~stella's Avatar
worst luck ever
yeah man, that was super helpful, i am planning on doing this soon.
also, those answer riser bars, are those the 1" or 2" rise? those look really great.
~stella is offline
Reply
Old 07-03-06 | 10:15 PM
killsurfcity's Avatar
perspective distorts
165 lets see the rest of that bike.
great how to btw.
killsurfcity is offline
Reply
Old 07-03-06 | 10:18 PM
absntr's Avatar
Frankly, Mr. Shankly
20 Anniversary
Nice one J. Very helpful for many.
absntr is offline
Reply
Old 07-03-06 | 11:35 PM
Thanks! The BB tutorial would be very helpful. I got mine installed, but I need to know how to maintain it.
Sin-A-Matic is offline
Reply
Old 07-03-06 | 11:58 PM
TNCLR's Avatar
Bikes: Cinelli Supercorsa, Nagasawa Special, Moots Compact, Gunnar Roadie
[165] is the best!
TNCLR is offline
Reply
Old 07-04-06 | 12:17 AM
jciv03's Avatar
Nice DIY!
jciv03 is offline
Reply
Old 07-04-06 | 12:33 AM
pitboss's Avatar
cxmagazine dot com
20 Anniversary
1" rise. I HAD a set graciously donated by sloppy robot, but someone needed them more than me for the time being. So I saw juvi-kyle with a set of these and decided I wanted a set to cut down on my own. They are nice, but the grips are taking a long-ass time to decide to not slip anymore...
pitboss is offline
Reply
Old 07-04-06 | 01:58 AM
fixedpip's Avatar
asleep at the wheel
Bikes: Custom Richie Ditta Track Bike, Eddie Merckx Corsa, Marioni Custom Pista, Dolan Cyclocross
Great thread, I would personally though replace the bearings on each and every service.
Grade 25 bearings are pretty cheap from places like thethirdhand.com (Loose screws) and will prevent bearing wear from damaging your headset. Only downside is that its hard to find the right retainer bearings so you'll probably have to switch loose balls.
fixedpip is offline
Reply
