Tires: Mix or Match?
Old 01-04-05 | 04:19 PM
Drive the Bicycle.
20 Anniversary
Bikes: Three-speed modified for comfort.
-- I commute mainly on the road with occasional short detours through dirt paths and sandy patches. Is there any advantage to combining a slick tire and a treaded tire (not a knobby) on a road bike? Which one should go on the rear? (My tires are 27 x 1-1/4)
77Univega is offline
Reply
Old 01-04-05 | 04:27 PM
jeff williams's Avatar
I couldn't car less.
20 Anniversary
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
The treaded front = dirt, sand.
You need the front traction steering, keep the rear fast.
jeff williams is offline
Reply
Old 01-04-05 | 04:56 PM
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
I don't know how much of an advantage you will gain by running a tire with basically grooves in a slick. You say you don't want a knobby. I think only a knobby would gain you an advantage in dirt or gravel.
Portis is offline
Reply
Old 01-04-05 | 05:38 PM
Wonder if it is Sheldon Brown or Jobst Brand that 'kill' the treaded tires in a article. Declaring that it is either slicks or knobby tires that are the choices. Grooves in a tire are only good for water and the risk of becoming a hydroplan is non-existant with a bike so grooves are useless... (on a bike that is, they are very useful on a car).
Berodesign is offline
Reply
Old 01-04-05 | 05:40 PM
phantomcow2's Avatar
la vache fantôme
I think thats sheldon brown. But yea if your going through dirt paths for 500 feet evry so often dont even bother with knobbies. If your going often and for a bit more extended times it might not be a bad move.
phantomcow2 is offline
Reply
Old 01-04-05 | 05:45 PM
Actually it was Jobst Brand...
https://yarchive.net/bike/slicks.html
Reply
Old 01-04-05 | 06:17 PM
geoduck's Avatar
20 Anniversary
...and Sheldon Brown concurs.
https://sheldonbrown.com/tires.html
:smiley:
geoduck is offline
Reply
Old 01-05-05 | 01:11 PM
Bikes: M- 2000 Trek 7000zx ____ R- 1990 Trek 1000
i feel that a knobby in the rear/slick in the front config. absolutely enhances your pedaling.
there is more kick in your rear wheel (legs) and the road is gripped where it counts through all sorts of terrain.
theres gravel only sometimes yes, but sand is all over the road. so i say its not a bad idea in that regard.
Front tires should be slick and fast for fine steering, which is the point of the front wheel, unless you need to hook up. a slick in the front is fine in everything but mud, because its your rear wheel via your legsthat hauls everything so it needs more grip.
With this mix, Your ride will also not be as smooth unless your tires are pumped at high presh, then there really is no difference in ride quality. just a more reliable tire that does not mess around.
goodluck
it all depends on the situation.
simplest
-=solewheelin is offline
Reply
Old 01-05-05 | 01:41 PM
powers2b's Avatar
Listen to me
It is far better to have more tread on the front.
Especially in snow...trust me on this one.
powers2b is offline
Reply
Old 01-05-05 | 02:16 PM
sure, just back up your statement.
in fact a sharper road tire slices into snow more efficiently then a wider knobby.
what are you riding?
Reply
Old 01-05-05 | 02:25 PM
powers2b's Avatar
Listen to me
700 x 38 cyclocross tires both front and back
Back is worn except for tread on the sides
Front is new.
I have found that the back tire gets loaded with snow and slips more when their is tread present (on ice you slip no matter what).
I have also determined through trial and much error that tread on the front tire helps to reduce sideways slipping during turns
powers2b is offline
Reply
Old 01-05-05 | 02:49 PM
Front is new. I have found that the back tire gets loaded with snow and slips more when their is tread present (on ice you slip no matter what).
Thanks, im just trying to understand how snow got introduced in this thread, but i agree with your tread comments.
On ice you need studded tires which i dont think they make for 700c CX (or do they?).
Rear tires last half or a third the time of fronts.. same with break shoes. of course thats common knowledge.
im using a Geax Revert semi slick in the front now on my mtb, with knobs only on the edge, so i know what you mean about the cornering feeling safer, but ive seen the hardest fastest dip turns done on slicks.
so cornering thats judged by shape/roundness of the tire as well as air pressure. the argument is, does tread cause less friction when cornering? i guess it depends
-=stevey
Reply
Old 01-05-05 | 04:22 PM
bostontrevor's Avatar
Retrogrouch in Training
And do you steer with your rear tire as well? Because otherwise I'll put maintaining control over acceleration any day.
The only conditions in which a knobby rear will "grip" the road are exactly the conditions under which you should instead have a knobby front for control. Only put the treaded tire on the back if you're interested in powering through your front-end wash-out.
Oh, and be aware that putting a knobby up front will sacrifice handling on hard surfaces.
bostontrevor is offline
Reply
Old 01-05-05 | 05:56 PM
Drive the Bicycle.
20 Anniversary
-- Speaking as the one who started this thread, I got my answer to put the treaded tire in the front. This is not a knobby, nor is it a "reverse tread" rain tire, but just a regular bike tire with a modest tread like what used to come stock on road bikes.
The only spills I have taken were in patches of sand on the road and I was mining all the expertise out there to see if anyone else mixed tires on a road bike with good results through sand.
Reply
Old 01-05-05 | 06:16 PM
20 Anniversary
As I said front, the idea is that a rear washout can be corrected by weight shift >or if the bike goes down, not as severe a wipeout as having the front steering tire lose traction (faceplant).
This also falls in the tire swap arena as a balder tire is to be put rear. Similar reasons.
I don't ride skinnies, but this seems logical.
Reply
Old 01-05-05 | 06:52 PM
-- This is not a knobby, nor is it a "reverse tread" rain tire, but just a regular bike tire with a modest tread like what used to come stock on road bikes.
The tire with "modest tread" which you describe won't do diddly to help you in sand.
Portis is offline
Reply
Old 01-05-05 | 09:13 PM
No, my leg power translates into my rear tire, not my steering. I find grip has everything to do with control, because as the real wheel is being powered, the front wheel is merely being pushed along (think about this) so if i have to "control" myself out of an occasional sand patch or a minor wet bog, you know im going to want some tread in the rear to help me kick out of there.
Yes but were talking about road cycling with some minor dirt and sand paths here no?
He runs a CX steed but isnt trying to do much CX riding, in which case he would need to hook up with a knob in the front.
and as you call it "powering through your front-end wash-out" im speaking from a touring point of view, and sometimes, "powering through your front-end wash-out" will save your ass.
Its a personal balance between speed/friction/pressure/smoothness/grip/stability. also the terrain you plan to hit is also a big factor.
have fun
-=stevey
Reply
Old 01-05-05 | 10:11 PM
im surprised that im the only one who seems to feel this way..
im just a cyclist who has put in 10,000 miles riding in WA, OR, CA, PA, and NYC in the past 3 years..
and the knobby in the back has saved my ass out of sh*t more than a handful of times, but a 1.5" specialized nimbus in the front has given me more than enough traction. even in the woods. (how much weight do you put on the front wheel anyway?)
Now, I notice the idea of more sand coming into play in this thread.. it really depends on what your dealing with. Those balloon beach tires are a good extensive example of this.. Its surface area that matters, sand is too loose to grip, so you gotta just roll over it fast. Because running the knobbys also means a slower, more buzzy ride when you ARE on the road (which is probably 95% of the time on your CX bike anyway). Sand will also eat/wreck your drive train if you use oil-based chain lube.
but unless your touring the sand dunes of Oregon, or somewhere comparable, you need not worry about washing out in minor sand patches on the road.
-=stevey
Reply
Old 01-05-05 | 10:37 PM
20 Anniversary
Run xc tires both. Problem solved.
Eat granola, get a cool tattoo on your calf, shun Starbucks and tell everyone you've decided to become a triathalete.
Reply
Old 01-05-05 | 11:03 PM
"I love lamp"
20 Anniversary
Bikes: 06 Fuji Track with upgrades, 06 Redline Flight Monocog, 01 Trek XO1, 2003 Cervelo P3, 2006 Bianchi San Jose monstercross
Avocet cross, inverted tread very useful in my opinion.
sbeatonNJ is offline
Reply
Old 01-05-05 | 11:27 PM
20 Anniversary
I could bother..but post a link. Your claim.
Reply
Old 01-05-05 | 11:39 PM
catatonic's Avatar
Chairman of the Bored
20 Anniversary
Bikes: 2004 Raleigh Talus, 2001 Motobecane Vent Noir (Custom build for heavy riders)
I dont worry bout it and just run slicks. I do end up doing dirt riding sometimes, and trust me on this....if you ever learned how to keep control on slippery mountain bike trails by using your feet....that applies to using 20c slicks in sandy dirt. It's also why I have my roadie's seat alightly lower than it should be, so I can throw it around with my feet if I have to.
catatonic is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
