How easy to get diff. length crank arms on each side?
How hard is it to get a crank-arm for one side that's longer than the other? What would it cost? Can I keep my current chainset/crank and just swap out the left-side crankarm? Can you even buy one crankarm, or do I have to buy an entire chainset?
(And just out of curiosity, how many here have diff. length crank arms?)
Over the hill
Bikes: Pinarello Nytro, Momentum Transend
Why do you want different length cranks? I know one leg is longer than the other, but I didn't think it would affect pedalling circimfrance much. Just toyed around with shimming cleats. Curious to know what makes people desire this setup?
my bike page - my journal
Current Stable: Trek Emonda SL - Trek Top Fuel 8 - Scattante XRL - Jamis Dakar Expert - Trek 9700 -AlpineStars Al Mega
You know you want to.
Bikes: Pinarello Prince, 1980's 531 steel fixie commuter, FrankenMTB
Originally Posted by cydewaze
If your leg length discrepancy is between your foot and knee, you need a cleat shim. If it's between your knee and hip, you want a different crank length. Adding shims to solve the latter problem will only make the problem worse.
Weather today: Hot. Humid. Potholes.
ou could try powercranks adjustable - they're expensive but "adjustable length crank which easily changes from 85mm to 220mm" and anything in between
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
Stop it.
Bikes: 2003 Specialized Hardrock Pro w/ slicks, flipped stem and HB, 2003 Colnago Dream with full Dura-Ace 7700 double, 2001 Bianchi XL Boron/Daytona, Mavic Open Pro/Campy Centaur/DT Champion built wheels.
I bet Indurain would be all over those.
To get wwhat you need, you may want to determine your crank/BB type, crank length you have and length you need.
Post in "For Trade" thread here (and potentially Classic & Vintage if you ride an older bike) and say something like the following, substituting appropriately:
"For trade my 175mm (square taper/Octalink/ISIS) left crank arm for your similar left crank arm with a length of 170."
Or, especially if you have a square taper BB, scour thrift stores and flea markets for a bike with the appropriate length cranks. It might be cheaper than buying a new crank arm. Especially if you aren't too concerned with an exact match of the appearance and model.
For the actual switch, a crank puller is the only special tool needed (and I hear there are a few cranks with self-extractors) it is a pretty straight forward operation, and a bike shop would do it for about what it would cost you to buy a crank puller if you aren't the DIY type.
Slow Ride Cyclists of NEPA
People do not seem to realize that their opinion of the world is also a confession of character.
- Ralph Waldo Emerson
Whether the OP wants to spring for a set is another story though.
At $1,000 for the adjustable power cranks ($1200 if you want a lockout to be able to use them like normal cranks) it would be more affordable to have a machinist custom fabricate a left side crank of the proper length... assuming the proper length is known.
If it is not known, then an adjustable crank would be the only way to ensure that buying one item gives the solution... But at the same cost as several attempts at cheaper solutions (unless the OP is using high end equipment).
The OP could shop around and buy a full middle range drivetrain group with a shorter crank length just to use the left crank and throw the rest away and still be less expensive than the powercrank. If the OP does this, please tell me where you are throwing the remaining components.
If he is riding a Trek 1000, it would be cheaper to buy another Trek 1000, get the cranks swapped by the LBS (for little or no cost) and then pull off the left crank for his current bike, and throw the rest of the bike away...
If there is no good information on how much shorter the crank needs to be, I would just go for buying a couple of left side cranks instead of full groups or bikes. If 168.2 is the proper size, then custom work or the adjustable cranks are the solutions that would allow that.
If someone is looking for a different length crank, I suggest that they just buy one... However, if someone also wants the features of the Powercrank, or adjustable length then my whole argument collapses... and I suggest that you buy one.
donrhummy, What crank components are on your bike now?
I thought they were like $600 max. Sheesh!
yeah I know - when you first see the price it's "they'ze HOW MUCH"
Over the hill
Just in case you're interested, there's some guy selling a set of ultegra cranks, right 172.5 and left 175 on ebay. Seperate auctions starting at $5 each. I was tempted but I really don't know if my length is in the shin or thigh, and I really don't have a problem with matched cranks anyway as long as the seat is set correctly.
ex frame builder
Human bodies are not precision machines and it is common to have slight differences in leg length. Having a longer crank one side is not going to help because this will make the one leg go higher at the top of the pedal stoke.
Unless the difference is so extreme that you need a build-up shoe on one foot to walk normally, (In which case you may need a build up cycling shoe.) don’t even worry about it. At the bottom of each pedal stroke on the short side your toe will point down a little further than the other side.
History, photos and tech articles on "Dave's Bike Blog." 'dave moulton' Registry including a Picture Gallery https://www.davemoultonregistry.com/
Originally Posted by johnny99
Your bike shop can order individual crankarms, but they are not cheap (usually more than half the price of a complete crankset).
