Can you hone out a seat tube?
Old 01-19-08 | 03:03 PM
15 Anniversary
Bikes: Early Cannondale tandem, '99 S&S Frezoni Audax, '65 Moulton Stowaway, '52 Claud Butler, TSR30, Brompton
Originally Posted by HillRider
... unless the builder brazes in a 0.1mm shim to allow a 27.2 mm seat post.
There is usually enough heat distortion to require builders to ream the seat tubes out to 27.2 mm.
LWaB is offline
Reply
Old 01-19-08 | 03:20 PM
well biked's Avatar
Titanium Club Membership
20 Anniversary
Hey Sheldon, this brings up a question I've had in my mind for some time. Could an old Schwinn fork steerer tube be reamed out from the Schwinn-standard 21.15mm to 22.2mm to increase the options for usable stems, or would that be too much material to remove with a hand reamer? Say, for example, an old Tange fork on a Schwinn. The outside diameter of the steerer tube is the same as a "standard" Tange fork from the same time period, in fact everything is apparently the same, it's just that the inside diameter of the steerer is smaller, to give thicker walls, at the expense of a smaller diameter quill on the stem. Any input appreciated-
well biked is offline
Reply
Old 01-19-08 | 03:27 PM
Sheldon Brown's Avatar
Gone, but not forgotten
Sheldon Brown Memorial - Titanium
20 Anniversary
Bikes: See: https://sheldonbrown.org/bicycles
This should be doable. As long as you don't run the reamer too far into the steerer, to the butted section at the bottom, it should be just fine, but prepare to do a lot of sweating to remove that much material.
Sheldon "Reamer" Brown
Sheldon Brown is offline
Reply
Old 01-19-08 | 03:34 PM
well biked's Avatar
20 Anniversary
Thanks, Sheldon-
Reply
Old 01-19-08 | 03:36 PM
My point was that a frame that uses a 27 mm seatpost is not built with "thin wall tubing." ;-)
Sheldon "Numbers" Brown
Point taken.
HillRider is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
