Contemplating Shimano->Campy
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
I'm contemplating a move to Campy. I've currently got the following on my bike:
[1] FSA crank (double) and chainrings mated to Shimano Dura-Ace BB (splined)
[2] Mavic Ksyrium wheels laced to Mavic FTS hubs
[3] The rest of the relevant parts are all Shimano Dura-Ace
My question becomes, what are the minimum number of things I could get away with substituting in order to get me Campy Record-10? I was thinking I'd need the following:
[1] Both left and right brifters
[2] FD
[3] RD
[4] Cassette - My mechanic runs a Shimano 9sp cassette with his Campy drivetrain because Shimano cassettes are cheaper for one thing. I wonder if the new 10sp Shimano cassette will work with Record.
[5] Chain
Now... points of question:
[1] Will I need to replace my crank and BB? I know Shimano and Campy spindle lengths are different but I wonder if there's a way to adjust my chainline without having to replace the whole crankset.
[2] Will I need a new rear wheel/hub? Can I replace the freehub body and mount a 10sp cassette? If I can use a Shimano 10sp cassette, will it fit on my current freehub body that's already Shimano 9sp compatible?
[3] Will Ergo levers pull the right amount of cable for Shimano Dura-Ace brake calipers? I know the Campy rear brake is a single-pivot and the front is dual-pivot and Dura-Ace are both dual-pivot. If I stick with the Shimano calipers, will there be an issue with the rear or both front and rear?
I think those are all the issues. Have I missed anything?
[2] FD
[3] RD
[5] Chain
1999 K2 OzM
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
2001 Aegis Aro Svelte"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
feros ferio
This sounds like a high-ticket total rebuild to me. For example, the cranks and BBs are incompatible, and Shimano cogsets have traditiionally been incompatible with Campag. indexing. Although I am a Campag. fan, I would hesitate to spend the money necessary for your makeover.
Can you priortize your wants and needs? Do you covet Campag. because of crank flex, because of shifting response, because of bearing hardness, because of reliability, because of repairability, because of image, or all of the above? Do you expect Campag. cranks to be stiffer than Shimanos?
If you want to try a halfway conversion, keep your brake calipers, crankset and BB and replace your derailleurs, brake lever/shifters, hubs, and cogs. Otherwise, "if it ain't broke, don't fix it."
DEADBEEF
1999 K2 OzM
1999 K2 OzM
I'm not positive of the mechanicals on the Ksyriums versus the latest crop of Ksyriums, but I would expect the Mavic M-10 cassette to fit it:
https://www.mavic.com/servlet/srt/mav...itsid=90&lg=uk
As you can see, two of the kits come with extra cogs for customization, and can be spaced for 9sp or 10sp.
I think your crankset is fine as-is, unless it's just that the chainrings are too worn to reliably accept a new chain at this point in their life. The positioning shouldn't be an issue... the chainline ought to line up just the same as on a Campy/Campy combo, or close enough to make no difference.
The brake-lever question is interesting. When I build up my road frameset someday, I'd like a Shimano drivetrain but Campagnolo brakes (I like the orbital pad adjustment on Campy). I have no idea if the brake levers now have different cable-pull ratios for the differential brakes or not. Personally, I'm probably just going for the Centuar brake calipers anyway, which are dual-pivot on both front and rear. Since Centuar is 10sp, you could even consider Centuar levers, which are definitely designed for dual-pivot calipers. Just some ideas, HTH
MechBgon,
Did Campy change back to dual-pivot front and rear, again? My year-old Record brakes are only single-pivot in back. I believe this was done for two reasons: 1) lighter weight and 2) reduce the braking power in the back to reduce the likelihood of locking up the rear wheel.
The second thing I'd like to point out is that you may not need to replace the front derailleur. I've been using a Dura-Ace fr. der. on my bike with both 80's era Campy NR cranks and downtube friction shifters, as well as with the Campy 9-spd Racing-T for quite a while now with no problems. Because of the degree of trimming that the Campy brifters provide, they seem to be pretty adaptable to different fr. derailleurs.
Originally posted by SteveE
MechBgon,
MechBgon,
With the tunability of Ergopower... yeah.Chorus and Record have the single-pivot brake in the rear for reduced weight, while Centuar is sticking with dual-pivot. I haven't kept up on the year-by-year changes with Campy's lineup very well, but someone around here will have a ready answer as to when they adopted the single-pivot rear brakes :confused:
you dont need to buy new hubs to use a campy 10 speed system.
Wheels MFG makes a kit that'll allow you to use campy shifters/deraillers on a shimano style freehub. the only exceptions are:
spinergy spox
chris king
shimano factory wheels
check out the "accelerator 10 speed" at https://www.wheelsmfg.com/technology.html
any bike shop should be able to order it for you.
spinergy spox
chris king
I don't recall if it is Lennard Zinn at www.velonews.com or Uncle Al at www.roadbikerider.com, but one of them has an entire section on cross compatibility between Campy and Shimano gear. Go to either site and search and you will be rewarded. It is quite extensive and should answer all of your questions. If not, then both LZ and U.Al are very good at getting back to folks who send them e-mail questions.
https://www.sheldonbrown.com/harris/kits.html
DEADBEEF
Originally posted by RacerX
If the only reason you like Campy is the ergo levers, just buy Ergo levers and keep the rest of it Shimano.
1999 K2 OzM
1999 K2 OzM
Originally posted by FOG
You might have a problem with bake release- on campy the release is in the levers and in shimano it is on the brakes. Using shimano levers with campy brakes I am not sure how you could release the brakes.
No problem. You leave the Shimano brake release in its normal position. You just use the release on the Ergo lever. The cool thing about the Ergo system is that you still have full braking power, even if you forget to put the pin back into the normal position. You can even put the pin back into place while riding, if you're careful not to squeeze the levers too much.
FOG,
I stand corrected. It would be a problem. In that case, I think he should just bite the bullet and do the right thing --- Go all Campy!
Anyway, I think it was Khuon, not MechBgon, who wanted the upgrade. I really think that Khuon wants to be talked into going full Campy, 'tho.
DEADBEEF
1999 K2 OzM
1999 K2 OzM
Mavic, wheels manuf. and American classic all make 10sp cassette to fit on shimano splined hubs so that is not a real big concern they are more expensive though which is a drawback. Also would need RD, STI levers and possibly a new FD I would try with the shimano one first to save money if does not work go buy the campy one.
keep your sti shifters (and cranks if you ask me...), Then get campy deraileurs and a campy rear cluster, with a spacing kit for shimano (campy uses 2.8 mm resin spacers, while shimano uses 2.56 mm spacers, assuming you are using 9 speed...) then you would be more campy than shimano but it would not cost all that much.... otherwise you are looking at a pretty big investment to get a full campy groupo
https://www.gvhbikes.com
has some good prices on full groups
-VegasCyclist
"Daddy made whiskey and he made it well.... cost two dollars and it burned like hell...."
Register!
-VegasCyclist
Register!
Why don't you just get the Campagnolo Ergo levers? They cost about $180 for Chorus levers and alot less for Centaur. That's where you notice it the most, since that is the only component you touch. I can't think of a cheaper solution than that.
DEADBEEF
1999 K2 OzM
1999 K2 OzM
DEADBEEF
1999 K2 OzM
1999 K2 OzM
DEADBEEF
Great... I think I'll try just swapping out the brifters first. I do want to go full Campy at some point but it'd be great if it's like what Father Guido Sarducci says, "you too can be da pope but you don't have to buy everything at once... can start out with just da hat."
1999 K2 OzM
1999 K2 OzM
Do Campy shifters jive interchangeably with Shimano derailleurs these days, as far as indexing goes? I can see using Shimano and Campy 9sp cogs interchangeably, but was under the impression that you need either Shimano+Shimano or Campy+Campy when it comes to the rear shifter/derailleur combo, due to differing actuation ratios. That seems to be borne out by Sheldon Brown:
Campagnolo Ergo shifters are rebuildable and upgradeable. They use of different, opposite motions for upshifting and downshifting. This makes them more intuitive in use and reduces the risk of missing a shift. They don't have any free-floating cables to get in the way of your handlebar bag or other accessories.
The front (left) Ergo shifter is not indexed, so it works with any front derailer and any combination of chainring sizes.
The use of Campagnolo shifters requires a Campagnolo rear derailer.
you could do right ergo, rear mech, and then put a dura-ace downtube shifter on, the just use a campy aero lever on the left. voila, a lance bike, only campy!
If need be, you can just do this, then add the left ergo next. not sure why you wanna switch anyway...ok, that was a cheap shot.
don't want to start a war.
