26.0 risers - who makes em'?
Old 08-23-06 | 01:09 PM
marqueemoon's Avatar
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
I feel nervous doing the Coke can shim on 25.4 bars and a proper shim would cost about the same as some cheap used risers anyway. Also, I'd like to be able to throw my Turbocat headlight on there every once in a while and it's set up to be mounted next to the stem on a 26.0 clamp.
marqueemoon is offline
Reply
Old 08-23-06 | 01:15 PM
LF for the accentdeprived
I don't think anyone makes a 26.0 riser. Get a new stem if you're really antagonistic to the coke can shim. BTW, yesterday I rode around with a 25.4 bar shimmed to a 26 stem with a long narrow slip of paper... no problem.
I find it hard to believe that the light would "notice" the 0.6mm difference.
LóFarkas is offline
Reply
Old 08-23-06 | 01:28 PM
20 Anniversary
trust the beer can. itll be fine.
stevo is offline
Reply
Old 08-23-06 | 01:34 PM
The light has a CNCed clamp, not an adjustable band. The light would probably be easy enough to shim with a piece of rubber but that's one more thing to keep track of.
I definitely don't want to get a new stem because I want to run the 26.0 Salsa I already have. If enough people chime in that Coke can shim is safe I'll give it a shot.
Reply
Old 08-23-06 | 01:51 PM
yo yo yo yo yo
aluminum can works ok on some bars, quite a bit worse on others.. you might want to look into a "real" shim, a la the nitto shim if the can doesn't work out and you still don't want to switch stems - https://cgi.ebay.com/Nitto-Handlebar-...QQcmdZViewItem
trons is offline
Reply
Old 08-23-06 | 04:51 PM
SirrusPackage's Avatar
Dirty White Boy
Bikes: 2004 Specialized Sirrus Comp, 1984 Raleigh Gran Prix fixed gear conversion
When the risers are too small, you must shim it. Shim it good.
SirrusPackage is offline
Reply
Old 08-23-06 | 07:34 PM
bonelesschicken's Avatar
Buy some material at the hardware store. flashing? Its gotta be cheaper than the nitto shim. Isnt it like 10 bux?
bonelesschicken is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
