Maybe expensive upgrades ARE worth it
Old 03-25-05 | 08:29 PM
Aluminium Crusader :-)
20 Anniversary
We've all read the threads that say something like: "it ain't worth it to upgrade the old steely; just get a new bike"
Well, since my Cervelo is busted I decided to put all my fancy stuff on the old (1989) 531c Raleigh because I couldn't wait to try my new Dura-Ace 180mm 10 speed cranks.
I gotta tell ya, with all the good stuff on the old bike, I can't notice much difference between it and the Superprodigy. I think much of it has to do with the Columbus Muscle fork.
What would be cheaper: putting a carbon fork, DA 9 speed and some new wheels on an old bike, or buying a new carbon or alu bike with Dura-Ace?
hmmmmmm
531Aussie is offline
Reply
Old 03-25-05 | 08:39 PM
JBar's Avatar
Bikes: Cannondale R1000, Marin Pine Mountain
Looks cool. How did everything fit up?
JBar is offline
Reply
Old 03-25-05 | 09:04 PM
20 Anniversary
Actually, surprisingly well. It's SMOOOOOOOOTH
I reduced the 9 speed hub spacing just a tiny bit to be on the safe side
Reply
Old 03-25-05 | 10:29 PM
sydney's Avatar
20 Anniversary
Well,there is old junkue steel, and there is stuff worth upgrading. Ya just need to know the difference.Too many think a Schwinn Varsity or old Hi-ten Kabuki is 'good' steel.
sydney is offline
Reply
Old 03-25-05 | 10:34 PM
20 Anniversary
aah, i thought you were always against upgrading old stuff.
By the way, I've had about five 531 frames over the years, and for some reason, this Raleigh shits on all the others
Reply
Old 03-25-05 | 10:39 PM
53-11_alltheway's Avatar
"Great One"
From: Might as well be underwater because I make less drag than a torpedoE (no aero bars here though)
That is a really nice frame from the looks of it.
The superprodigy frame looks pretty racey. What's going to happen that?
53-11_alltheway is offline
Reply
Old 03-25-05 | 10:42 PM
greywolf's Avatar
aka old dog
20 Anniversary
What happened to the Cervelo frame ?
greywolf is offline
Reply
20 Anniversary
Yeah, like I keep saying; I don't know why we don't see more dark blue around.
I'm gunna get the Cervelo repaired
Reply
goldfish's Avatar
the great shark hunt
Bikes: 2005 Cervélo Soloist w/ Campag Chorus (06/07 parts mix), 2001 Cervélo Prodigy w/ Campag Centaur '06, Giant Bowery Fixed-Gear, old steel black '70s bike waiting for FG build, trusty red SS mountain bike waiting for snow-bike build
you probably posted this somewhere else that i missed, but what happened to the Cervelo?
goldfish is offline
Reply
Old 03-25-05 | 10:44 PM
20 Anniversary
Reply
goldfish's Avatar
how?
goldfish is offline
Reply
Old 03-25-05 | 10:45 PM
greywolf's Avatar
aka old dog
20 Anniversary
howd you manage that?
greywolf is offline
Reply
Old 03-25-05 | 10:46 PM
20 Anniversary
Originally Posted by goldfish
how?
I'm really not sure. I had the right size post it there.
Too fat, maybe?
Reply
Old 03-25-05 | 10:47 PM
goldfish's Avatar
does the warranty at least cover it? I hope so, because that is a GORGEOUS bike.
goldfish is offline
Reply
Old 03-25-05 | 10:51 PM
greywolf's Avatar
aka old dog
20 Anniversary
that looks like it could be repaired ok but it may need a gusset around there to re-enforce it .
greywolf is offline
Reply
20 Anniversary
I'm not sure if i'll go the warranty route because they don't make them anymore, and Cervelo intimated that, even if it was covered, tracking down a red 58cm would be very tricky. It looks to me like a simple repair.
Chris at Cervelo has been very helpful
Reply
Old 03-25-05 | 10:52 PM
20 Anniversary
I forgot how thin the tubing was until I took off the seat collar, so I wouldn't mind it being a bit chunkier 'round there.
Reply
sydney's Avatar
20 Anniversary
It all depends. I have old stuff that absolutly would not be worth it. I have old stuff that gives up nothing to some of the newer other than a few ounces. And knowing how to do it and having all the tools makes more sense than if someone is starting on the bottom rung and asking...'can I do dis?'.... One of the best ones I ever did was on an late 70s early 80s possibly custom 531 frame with full high end campy on it. Found it literally brand new in mint condition at a thrift strore for $7.00 About a 60cm frame with a 56 TT. Exact size for someone I knew that needed a custom but couldn't afford it. Sold all the campy stuf off it for about $300. Rebuilt it with good nearly new stuff out of my junk boxes and gave it away.Rebuilt an older but really nice(like new) thrift store Bianchi with better stuff,from junk boxes, and sold it for less than my cost to someone that needed a deccent bike.And upgrading does not have to mean ultegra/chorus or better,like many seem to think.
sydney is offline
Reply
Old 03-25-05 | 10:55 PM
greywolf's Avatar
aka old dog
20 Anniversary
Might stop a repeat failure ,if it is a possible weak spot.
greywolf is offline
Reply
Old 03-26-05 | 01:18 AM
20 Anniversary
Originally Posted by sydney
It all depends. I have old stuff that absolutly would not be worth it. I have old stuff that gives up nothing to some of the newer other than a few ounces. .
oh, I see. You usually recommend other people don't buy expensive carbon forks for their old bikes.
Reply
Old 03-27-05 | 08:35 AM
20 Anniversary
Any suggestions how it could be beefed up in the area?
Reply
Old 03-27-05 | 08:55 AM
sydney's Avatar
20 Anniversary
Makes alot of difference what you are starting with.A CF fork may add nothing to a decent frame. A good CF fork may cost more than many frames are worth. Usually the idea behind a CF fork is based on bling and hype,not necessarily a fundamentally good reason. My old stuff is perfectly happy with their good steel forks.I would not even entertain the thought of switching some of them. Everyone has to set their own priorities. Mine don't necessarily run to expensive CF forks on old steel frames, especially low to mid range ones. If you stick with threaded,you won't save alot of weight,and the ride won't necessarily be better either. I've replaced steel forks on mid 90s quality steel bikes with full CF forks,light bars and stems and saved alot of weight. It can also cost alot of money if you don't buy right. I won't blow smoke in you about astounding improvements in ride,because there was none.
sydney is offline
Reply
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
