Helix Update?
#2476
Quoted: 8 Post(s)
https://www.aliexpress.com/ buying Rhinowak 24$
Likes For Bym:
#2480
Quoted: 8 Post(s)
I have a Rockbros 1.5l that is a well made tough bag that’s fits quite well, but it’s a little wide. The bike folds ok, it definitely won’t roll along with the bag installed. Hoping to find something thinner.
Likes For paulwongkwan:
#2483
Quoted: 46 Post(s)
Owner reviews?
I've looked! unfortunately (for me) I've been able to locate online only a few, short reviews. I'm interested in the Helix because it appears to have a relatively compact folded size with relatively light weight and "reasonable" diameter wheels. It also appeals to my sense of engineering aesthetics. The problem is that I'm old (73
) with an old man's neck
which requires me to seek out a relatively upright riding position
and I'm wondering how the geometry of the Helix might fit my needs with or without bar +/or stem replacement (if such is even feasible). All thoughts appreciated!
![Roll Eyes (Sarcastic)](https://www.bikeforums.net/images/smilies/rolleyes.gif)
![RenRad](https://www.bikeforums.net/images/smilies/rennrad.gif)
![Backpedal](https://www.bikeforums.net/images/smilies/backpedal.gif)
#2484
Quoted: 8 Post(s)
It will depend a lot on your height. I’m about 5’11” and I like my seat high so my legs are well stretched out due to knee issues. I lean forward a little, but it’s still comfortable for me. I’m definitely not perfectly upright. If my wife rides it her riding position is much more upright, but she’s 5’5” and has the saddle pretty low. Folding bikes I’ve had before the handlebar tube was telescopic and I could get the bars high enough to give me an upright position even with the seat fairly high. I had a cheapo Citizen 20” bike that had a big comfy seat and a huge amount of adjustment in the bars. That bike was like riding an armchair, but it made for a very inefficient and slow ride.
With Helix you don’t have that telescoping adjustment so the stem height is fixed. You should be able to change the stem for one with extra rise, it doesn’t look to be part of the securing mechanism, you’d just have to remove the knob on the top and it should come right off. The handlebar tube that the stem clamps onto seems to be 1-1/8”/28.6mm which I’m pretty sure is a fairly standard size. The problem with adding rise in the stem is that it normally adds reach/effective toptube length also, so you can end up back where you started in terms of being upright.
Adding riser bars is another way to get a more upright position. I have some on mine. They only added about 2” of rise but that made a big difference to me. I have them raked slightly back towards me also, so it may have reduced the effective top tube length by an inch as well as adding 2” to the height. Bars with that extra rise didn’t affect the folded size, but a riser stem would likely add to the width of the folded bike a little, if that matters to you, as it will stick out further as well as up. If you added much more rise I think you’d have to swap out the brake/gear cables for longer. If I remember when I fitted mine I thought that was around about the limit for the cables.
I would look a the helix promotional video and the few other reviews on YouTube to get an idea of the riding position. If you pause it with a side on view you get a pretty decent idea, even though you’re guessing the riders height.
if you want any measurements I’m happy to take them for you.
#2485
Quoted: 840 Post(s)
Liked 255 Times
I agree that l will depend of your height. Helix frame is relatively short and won't fit well for tall people.
I think you should also consider the comfort.
And I doubt that Helix is a comfortable bike.
It has no suspension at all, the lefty fork will be very stiff, the rear triangle will also be stiff and the tires are relatively narrow+ high pressure (no possibility to mount balloon tires like the Big Apple).
I think that even if it has smaller wheels, a Birdy will better fit your needs: full suspension+balloon tire, fully adjustable seatpost and stem (in height + two types with two different tilt to be chosen depending of your height).
#2486
Quoted: 46 Post(s)
Thank you!
#2487
Quoted: 46 Post(s)
Still, I appreciate very much your comments.
#2488
Quoted: 840 Post(s)
Liked 255 Times
Yes, its true that the folded shape of the Birdy cannot compete against the folded shape of the Brompton for instance. Folding the Birdy is also not as easy as folding a Brompton.
But I think that with its full suspension + balloon tires, it is the most comfortable folder on the market.
#2489
Quoted: 8 Post(s)
This has been a very helpful response! You've answered all of my fit questions as capably and completely as anyone might without actually providing me with an opportunity to physically play with the bike. I infer from your apparent enthusiasm that you're pleased with the bike.
Thank you!
Thank you!
Yes, I’m very pleased with mine. Initially I did find it very rigid and bordering on uncomfortable. To some degree it was probably just more noticeable to me by comparison, as I was previously riding a borrowed Townie 21 speed bike which is all about comfort, suspension forks, seat post and very upright riding position. If you’re used to a commuter or road type of bike it’s likely not significantly different.
With the riser bars, a softer padded seat and a little less air in the tires it’s significantly improved. There’s really not much more you can do in terms of comfort as it doesn’t seem possible to add wider tires or any form of suspension, unless anyone makes a suspension seat post that was long enough and the right diameter.
It’s fair to say the bike it pretty rigid. It’s never going to be a beach cruiser, but it’s pretty comfortable as long as the surface is fairly smooth. I just ride for pleasure, nothing competitive or hardcore at all. I can cover decent distances without too much pedaling effort and without being uncomfortable. It’s about the right compromise of speed and comfort for me regardless of being a folder. The ability to fold it and throw it in the trunk of the car or take it with me pretty much anywhere is the icing on the cake.
Likes For mkatz:
#2491
Quoted: 194 Post(s)
Liked 206 Times
So we have arrived at a definition of why a folder: it takes us pretty much everywhere, and when it cannot then we can take it instead.
![Wink](https://www.bikeforums.net/images/smilies/wink.gif)
Likes For Geepig:
#2493
24x1.5
Vee 24 x 1.5 tires.
Some interference occurs when folding.
Due to the narrow helix frame, it is difficult to install various tires.
It would have been nice if there was some space in the spiral frame
![](https://cimg6.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20201109_090936_1__9aeae0a59a0de3f1e43d7c40de7764870dd4a6a0.jpg)
Carbon parts exchange for light weight
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/800x450/externalfile_9191442da5e2cd7a873ff4e6896c915cc76fe83b.jpg)
![](https://cimg1.ibsrv.net/gimg/bikeforums.net-vbulletin/1280x1706/20201014_101322_93e2e78adcb146cb07a6722c35f0547d0f242742.jpg)
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1280x1706/20201014_100543_dfd9e70d46c444dea93e8e01eb35656661c2f31e.jpg)
![](https://cimg5.ibsrv.net/gimg/bikeforums.net-vbulletin/1280x1706/20201014_100528_42e422f3b3e10d56ba9cf15cfbf78d5174d97d6a.jpg)
#2494
Quoted: 840 Post(s)
Liked 255 Times
I do not like carbon seatpost on a folder because the seatpost must be inserted/extracted and decompressed/compressed at each fold unfold.
Carbon doesn't like to be compressed/decompressed too often and dirt on the seatpost make scratches at each fold.
#2495
I don't know if I would say the Helix is the best upright riding folder; certainly, it is probably one of the best all around folders. One thing I like to emphasize is that ride comfort also includes handling, which doesn't get mentioned a lot. Because it is a 24 inch bike, it rides somewhere between my Brompton (16") and my full size 29" Rivendell. So, not as twitchy as the Brompton - but still responsive for urban riding - but not as sikly smooth as my big bike for long hauls. Ultimately, all folding bikes are exercises in compromises - pick the one that best one that compromises towards your preferences, or compromises the least in your mind if you want to view the situation in the negative. The fact that I can fold a 24" wheeled bike with an IGH, disc brakes, and strong frame... and put in the van beside my kids bikes, bike trailer, grocery bins full of non-grocery items, emergency supplies, bags of stuff needed for small kids (are you sure you're going to play with ALL this stuff? Yes dad! Uh-huh) is of course the whole point of a folder. I'm not looking ride a multiday grand tour with my folder (although some do): I'm looking for a good ride on most outings that last a day or less. Or the short trip where I have the peace of mind to take it inside and stow it away instead of leaving it locked up outside in front of thieving eyes.
#2496
Quoted: 840 Post(s)
Liked 255 Times
How comfortable is Helix on bad road like cobbles vs. the Brompton ?
For the handling, wheel size isn't the criterion that define it.
My Birdy with exactly the same wheel size as my Brompton (this is what I have after having changed the original Birdy wheels for ETRTO349 wheels + 35mm wide tires) is not twitchy like the Brompton.
#2499
Quoted: 46 Post(s)
![Geek Geek Nerd Nerd](https://www.bikeforums.net/images/smilies/geek.gif)
#2500
Quoted: 8 Post(s)
Robmac, If I'm lucky
, I will be able to place an order for a helix on Monday, when an order placement opportunity is scheduled to arise (and remain open for 60-90 seconds...
). I'm 5'5 and am likely to install a riser bar, as per your suggestion. Noting your experience with a 2" rise (and, I think, some measure of added sweep), I wonder if you remember the name, model, source (and, perhaps, sweep) of your bar?
No, I’m sorry, I can’t help with the info on the bars. I had several sets left over from previous folding bikes and other projects and I
‘m pretty sure I used a set that I already had. I don’t have the bike with me to check for a brand or model on the bars, and likely won’t be home for several weeks. I don’t think the bars had much or any sweep, but I shortened the reach just by rotating them in the stem slightly towards me. It only brought the bars maybe 3/4” towards me, but in combination with the added rise the overall effect on the riding position feels much more significant.
Good luck with your order slot 🤞🏻
