Photos of YOUR bicycle near WATER
#2476
Quoted: 3401 Post(s)
Liked 3,751 Times
Lake Michigan:
Likes For abshipp:
#2477
Bikes: Turner 5-Spot Burner converted; IBIS Ripley, Specialized Crave, Tommasini Sintesi, Cinelli Superstar, Tommasini X-Fire Gravel
Quoted: 406 Post(s)
Liked 390 Times
Likes For BenBoozer:
#2479
Quoted: 10320 Post(s)
Liked 5,299 Times
Likes For bampilot06:
#2481
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Wilder Ranch, overlooking Monterey Bay.
Thankfully, this at least didn't burn. (It looks ready to go.)
Likes For Cyclist0108:
Likes For tankist:
#2483
Liked 5,299 Times
Jamestown, Va
Likes For Chubby715:
#2485
Who is Austin Dunbar?
Mississippi River
Likes For ridelikeaturtle:
#2487
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Likes For Unca_Sam:
#2489
The dropped
Liked 1,014 Times
Vernal Pond
Poor drainage and low elevation = critical amphibian nursery (in a few weeks).
Likes For RandomDesign:
Likes For 2cam16:
#2493
Liked 5,299 Times
#2494
The dropped
Liked 1,014 Times
#2495
Quoted: 20810 Post(s)
Liked 9,456 Times
First, ST angle rarely changes (much) within the frame sizes that cover the meaty part of the bell curve, so the setback of the seat post likely wouldn't change, even on the next size up. Next, the stem looks to be 100mm or so, which is pretty much standard fare; I don't think that you're in the neighborhood of a "looooong" stem until you're talking 130mm and longer; conversely, stems shorter than 90mm look stubby and out of place by modern standards. Last, he doesn't have a spacer stack under the stem, which means that he'd likely have to resort to a -17° stem on a larger frame with a taller HT and even that might not get him to where he needs/wants to be.
Likes For WhyFi:
#2496
The dropped
Liked 1,014 Times
Absolutely nothing about his set-up suggests, to me, that he's on a frame that's too small.
Keep in mind that I'm firmly in the dark ages of bicycle geometry here. Road bikes have 'square' frames. I end up making compromises on my own fits because I have a preferred ST of 56cm and a preferred TT of 54 cm. So it's either long seatposts or stubby stems for me.
#2497
Liked 9,456 Times
I didn't say too small! It's probably a complication of the compact geometry and the sloping top tube making the bike appear smaller (and that space from the saddle to the hoods look longer). Also, what's so bad about a +/- 17 degree stem?
Yeah, I kind of figured that you were basing your comments off of older standards. A fist full of seat post is no longer the norm and, hell, at this point, I couldn't even tell you what my preferred ST length would be, because I don't know. Semi/compact geometry has made that mostly irrelevant and I couldn't tell you the ST length on any of my bikes in the last 15 years.
#2498
Bikes: State Bicycle Co. Undefeated Track SS/FG, Lynskey Helix-Bronze
Quoted: 115 Post(s)
Liked 204 Times
WhyFi , the stem length on the Helix is 110mm so you were just about spot on regarding my fit on the Helix. Even on my SBC 6061 which is a 58 (for some strange reason, they skipped 56 and 54 would’ve been way too small), I had to go 0 setback on the Seatpost and -17 on the stem. Luckily, I still had a carbon 0 stack height top bearing cover to get my fit just right on this 58cm frameset.
Beautiful afternoon ride today.
#2499
The dropped
Liked 1,014 Times
#2500
