Most needlessly contentious topics
#252
Expired Member
Quoted: 3815 Post(s)
Liked 5,839 Times
Here's a new one, never imagined cross chaining could be contentious?
#253
climber has-been
Quoted: 3605 Post(s)
Liked 3,793 Times
#254
Klaatu..Verata..Necktie?
Quoted: 10656 Post(s)
Liked 12,319 Times
Alternatively, the lockrings get in the way when you put the valvestem through the rim, so you have to take them off. Then they do nothing useful, so why bother putting them back on? Similarly, you have to take the valve cap off before you can pump up the tube. Then they do nothing useful, so why bother putting THEM back on?
#255
Liked 12,319 Times
Or do what I do - find the colorful logo decal on the rim, and look 180 degrees away.
#256
Liked 12,319 Times
How about if they're cross-chaining AND failed to lube their chain?
#257
Quoted: 2649 Post(s)
Liked 2,005 Times
I knew I was getting old the day we were on tour, and as we started riding, my daughter asked, "Daddy, why is your chain making that racket?" I replied, "What noise? I don't hear anything unusual!" By the end of the day, I heard it and knew I was starting to lose my hearing.
#258
climber has-been
Liked 3,793 Times
#259
Habitual User
Quoted: 5120 Post(s)
Liked 8,456 Times
Likes For Eric F:
#260
Quoted: 1093 Post(s)
Liked 710 Times
When I hear people talk about how much trouble it is to use lockrings and valve caps, it makes me realize that some people change a LOT more tubes than I do. And I'm never in that much of a hurry that I need to save the 2 seconds that it takes.
#261
Quoted: 7733 Post(s)
Liked 3,669 Times
It’s not the weight, it’s the drag. All those knurls create little vortices …..
Well, with the caps it is weight … and since they are on the rim they drastically increase Moment of Inertia.
#262
Liked 12,319 Times
I suppose if I changed a lot of tubes, and if I knew that I'd be changing those tubes in situations where every second mattered, I could see leaving them off. Otherwise, the lockrings secure the stem and make it much easier to attach the pump, and also keep the valve straight. And the cap keeps the valve clean.
Take a hint.
Likes For genejockey:
#263
climber has-been
Liked 3,793 Times
#264
Liked 3,669 Times
Never had this happen. The less air in the tire the more play at the valve. I pump up my tires, tighten down the lock rings, and ride ….. as the tube loses air it shrinks and the lock ring is no longer held taut. I could pull up slightly on the stem but I have never needed to
Likes For Maelochs:
#265
climber has-been
Liked 3,793 Times
#266
Quoted: 2660 Post(s)
Liked 3,226 Times
If nothing else, this thread has revealed the needfully contentious topics.
#268
Quoted: 4227 Post(s)
Liked 2,491 Times
Never ever had a valve stem nut stuck where is was hard to remove.
#269
Liked 2,491 Times
#270
Habitual User
Liked 8,456 Times
I have. However, it was with a tubeless tire, and sealant had gunked things up to the point where it wouldn't budge and I was stuck on the side of the road. I had to make the call of shame to Uber. I pay more attention to the cleanliness and proper operation of my nuts now.
With a tubed tire, I leave the nuts and caps off because the reduced rotating weight allows me to fly up hills way fasterer...but mostly because I find them to be completely unnecessary once the tube is installed.
#271
Happy With My Bikes
Quoted: 888 Post(s)
Liked 2,359 Times
If I'm too hard of hearing to notice and I ride mostly solo, is it really rattling?
Likes For Chuck M:
#272
Quoted: 7163 Post(s)
Liked 11,368 Times
#273
Quoted: 3663 Post(s)
Liked 3,100 Times
#274
climber has-been
Liked 3,793 Times
#275
Liked 3,100 Times
