Light Bicycle Wheels
#326
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Anybody else find their web site/order form ( https://www.lightbicycle.com/) to be tricky to navigate? I choose a wheelset (700C Falcon rims, 55 mm deep, etc.) and then as I choose options, wonky things happen (e.g., I choose non-disc brakes, then make some other choices, and the option for non-disc brakes disappears; as I make other selections -spoke type, spoke count, etc, -other, selections I have made vanish, so that I can never complete the form) . Is it a browser issue? I'm using an up to date version of Chrome on a Macbook.
Or is it possible I'm somehow choosing unavailable combinations?
Likely, I'm doing something stupid.
#327
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 407 Times
As always, eamil and ask.
#328
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4452 Post(s)
Liked 3,071 Times
Thanks
#329
Quoted: 4717 Post(s)
Liked 1,882 Times
I think I have it mostly figured out. The form cares about the order in which you make your choices, even if the choices are not connected to one another in terms of available combinations. Making a bunch of selections and then going back to see how the price changes with a different hub choice is not a good idea. I've experimented enough so that I can get off the first screen and onto the second (where spoke choices are made, etc.) and proceed far enough so that I can build a dummy quote and then email them.
Thanks
Thanks
#330
staring at the mountains
Bikes: Obed GVR, Fairdale Goodship, Salsa Timberjack 29
Quoted: 394 Post(s)
Liked 198 Times
If you work top-down, you'll get it. Note you have to hit every option (even there's only one).
#331
Liked 3,071 Times
I'm looking at the Falcon 45 mm or 55 mm deep rims, one or the other of the DT Swiss hubs, Sapim spokes.
I had just convinced myself that I didn't want to spend the coin for name-brand (e.g., HED, Zipp) wheels and also I wasn't so comfortable with going the route of ordering something direct from China via Alibaba. This seems to be a great alternative, both in terms of value and quality and also for knowing what I'm getting. The collective experience of people on this thread has helped a lot.
#333
Liked 3,071 Times
I've got rim brakes (DA 7900), so I can't go too wide. I was thinking that the 25 mm wide rims with 25 mm tires (GP5000?) would be about right. I've noticed on this thread that people have had a hard time mounting the GP5000s, though.... I'm not ashamed to use tire levers, so I'm guessing that the problem is surmountable (no pun intended).
#334
Liked 3,071 Times
I should probably start a new thread for these questions, but there seems to be a fair bit of expertise in this thread, so I have 2 questions for you guys:
I've not had a set of carbon wheels before.
1. Lots of carbon wheels have that characteristic resonant buzz. In my experience, riding with others that have them, it depends on the wheels and, I think, on their depth. Those of you who have got the LB wheels, how loud is the buzz and what depth are your wheels.
2. I am currently riding a standard set of alloy clinchers (HED Ardennes). My idea is that I would likely swap between the alloy and carbon wheels, depending on what ride I'm doing (and the weather). For those of you who make similar swaps and have rim brakes, I assume you just keep the carbon-specific brake pads on for both sets of wheels?
#335
Quoted: 26 Post(s)
Liked 12 Times
I don't have LB wheels, so I can't directly answer your question. On my 45mm Flo's, there is no buzzing. There is maybe a slight whooshing at higher speeds, which I think is just normal road noise echoing in the chamber inside the rim.
On your question about pads, you will want to remove your carbon specific pads if you switch back to aluminum wheels. The carbon specific pads will not work as well, last as long, and they will gather aluminum dust/shards/etc. which will then wear down your carbon brake track when you remount the carbon wheels. For me, it's a little bit of a pain to switch because the brake tracks in the two sets of wheels I have don't line up, so I have to completely reset the pad position, but that still only takes about 5 minutes.
#336
Quoted: 733 Post(s)
Liked 815 Times
I run Swissstop Black Prince pads with the carbon wheels and Koolstop Salmon pads with my alloys, I switch them out with the wheels, I have to adjust the brakes anyway for each wheelset, so might as well run the proper pads.
#337
Liked 1,882 Times
1. Lots of carbon wheels have that characteristic resonant buzz. In my experience, riding with others that have them, it depends on the wheels and, I think, on their depth. Those of you who have got the LB wheels, how loud is the buzz and what depth are your wheels?
#338
Liked 3,071 Times
I have r8000 rim brakes with the 46mm LB wheels, no issues with the 28mm width, even with full size pads. 23mm GP4Ks are a perfect fit, the 25mm GP5Ks stretch to a lil wider than 28mm, still works, just not aero optimized. I had no problem mounting either tire, I lay them in the sun for a bit and then they went right on with no levers.
No buzz with my 46mm LB wheels, as mentioned they do make a bit of a whoosh sound when you're sprinting.
Still thinking of the narrower rims (45-55 mm depth). This is for a roadbike that will seldom see gravel, and though I know everybody loves wide tire profiles these days, it seems to me that going too wide blunts the aero advantage of deep carbon wheels. I will likely experiment - maybe with a 23 mm tire in the front and 25 in the back.
#339
Quoted: 733 Post(s)
Liked 815 Times
Thanks for the info. I run the Koolstop Salmon with my Ardennes. I can see that swapping pads would be pretty easy and why it's advisable.
![Thumbs Up](https://www.bikeforums.net/images/smilies/thumb.gif)
#340
So, my first ride on the 56 wheels. Far better handling in moderate croswinds than I had expected. This is my first ride with a deep section wheel, and it was not at all bad.
Conti 5000s 25mm, measured just over 28, and I rode at about 60 psi. Comfy ride too.
Wheels look great on a black bike![](https://weightweenies.starbike.com/forum/images/smilies/icon_biggrin.gif)
Thanks guys for all the help that I got here.
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20190428_085706_e2fd161edfe4f78f67c230a66e14fdb3d8d6045b.jpg)
![](https://cimg8.ibsrv.net/gimg/bikeforums.net-vbulletin/2000x1504/20190428_101750_9f06bc68b914ccab6835389e6ff594abda8ce022.jpg)
#341
Advocatus Diaboli
Quoted: 4824 Post(s)
Liked 1,558 Times
Nice looking setup! Your PSI choice is one example that I think I see a lot that has me scratching my head sometimes. While I get that the ride is more comfy, and that with sealant you're probably better flat protected, but eg. the data at BRR seems to suggest that performance-wise (rolling resistance) you're worse off than running the tubed GP5ks inflated to normal PSIs returned by various calculators. And the BRR data is based on roughly a 150lb rider fwiw.
#342
Honest enough to admit that it was for the bling value
![lol](https://www.bikeforums.net/images/smilies/lol.gif)
#343
Quoted: 54 Post(s)
Also do a search on rolling impedance; going too high can take all the advantage away. For most uses 80psi is about as high as I'd go (63kg) except if I'll do a TT in smooth roads, which is never. It does feel fast to ride like this.
I used to pump to 100 until I realised that only made my bones shake and made me slower. On the training bike I ride G-One 60mm at 25psi and I can easly ride with road bikes.
#345
Liked 1,882 Times
Light Bicycle released a couple of new rims
38mm deep x 32mm wide(25mm internal)
https://www.lightbicycle.com/700C-ro...available.html
50mm deep x 32mm wide(25mm internal)
#346
Quoted: 20810 Post(s)
Liked 9,456 Times
#348
Liked 9,456 Times
#350
Liked 9,456 Times
I'm sure that the rim can handle that pressure just fine, but that in no way implies that it's a safe pressure for every tire that you might want to mount on them.
