Show us your gravel/cross bike...
#4701
Quoted: 7397 Post(s)
Liked 2,571 Times
Where is this? I love the scenery. Google tells me Idaho.
Likes For Rides4Beer:
#4703
After looking at new bikes for about a month now, I decided to turn one of my vintage 10 speeds into a gravel bike. Couldnt see spending $1000 on a new bike. So got a qt. of gloss enamel, painted my frame, and put on some Kenda tires. Waiting for the paint to dry so not completely built back up.
This is what a lot of cyclists used back in the day for cyclocross racing. No one would use their road racer off road, and no one had the money to buy a dedicated cyclocross bike. So you found a beater bike boom 10 speed and made do.
Likes For big chainring:
#4704
Sunshine
Quoted: 11063 Post(s)
Liked 7,629 Times
^ Perfect for all that North Shore gravel.**
...i guess the Des Plaines trail is crushed stone for much of the way.
#4705
Liked 2,571 Times
@big chainring, I did the same. I like yours very much.
1971 Raleigh Super Course with 2x8 indexed drivetrain
Likes For noglider:
#4706
My converted mid-90s Giant Chaos MTB. Decent frame with double butted tubes including stays and a threadless headset. I used MicroShift / MicroNew 3x7 shifters to match the original Deore LX drivetrain and they work perfectly. All around a great budget gravel build (approx. 130 EUR all in).
Likes For pcons713:
#4708
Quoted: 582 Post(s)
Liked 1,027 Times
Had this Diverge Elite E5 for a day. Picked it up Monday, returned it on Tuesday. BH in Chelsea said rotor rubbing is normal and will wear in. Nice bike, bad QC. This is what I get for trying to buy my first new bike in 28 years.
Likes For DorkDisk:
#4709
Sunshine
Liked 7,629 Times
Whats most impressive is that this looks like a drop bar bike vs an mtb thats coverted to a drop bar bike. Some 26" mtb conversions end up with really wild bar placements and whatnot due to frame geometry. This looks like it belongs.
Likes For mstateglfr:
#4710
Sunshine
Liked 7,629 Times
is the bad QC the rotor rub? If the rotor is not straight, thats an easy fix( i assume the shop checked). If it is straight, then it could just be the brake caliper needs to be aligned(again, I assume the shop checked). Every disc brake bike Ive set up had rotor rub to begin with, and aligning the calipers to the rotor solved the problem. The whole system is meant to be adjustable, just like rim brakes are adjustable.
#4711
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
That is one lazy bike shop. Rotor rub is not normal, and can def be adjusted for. Either the caliper is out of alignment, or the rotor is out of true, or a lil of both. But it's easily fixed.
#4712
Fantastic color! The light tan skinwall tires work great against the frame color.
#4713
Quoted: 582 Post(s)
Liked 1,027 Times
The thing is, overnight I tried to adjust this. The caliper is crooked, so my guess was that the mount needed to be faced. Or the piston was sticking. Something; anything, except nothing.
I'm not the best mechanic, but I have worked in bike shops off and on over 30 years of cycling. My last stint was a few years ago and as an old school MTBer, I am very familiar with hydraulic disk brakes. I have four bikes with hydraulic brakes that I built and none have ever had rotor rub.
Upon return, the manager said there were three people who wanted that bike so it was not a problem for me to return it.
There were some other issues with the bike, the compression cap was not installed correctly, the few threads I saw (stem bolts and rear axle) were dry. I was told that was how they come, and they don't touch that. Not impressed. They tried to blow off the scuffed bar tape, altogether it was too much for me.
Oh, and they charged my card twice. So I had to call the bank. But it got me thinking. I bought in online and was charged. I got an email saying that they'd rather return that bike to S instead of selling it to me. I was maybe charged a second time because I got a different bike.
#4715
Recently tried the 27.5x2.2 Conti SpeedKing Racesport, for mild gravel and sand across flatter gradients and sealed roads. Running tubeless in the back with an S-Tubo up front, as these tyres aren't tubeless from what I understand. Very fast for a 650b (faster than the extralight ReneHerse 48mm slick. Plus, I prefer the larger tyre height/rolling diameter, over those).
Likes For tangerineowl:
#4716
So I bought this:
so I took this:
and turned it into this--Kona Jake the Snake EVOO!!
so I could have a townie/baby trailer puller/commuter bike. The fit is very short with the flat bars, and I might get a set of wider risers to stretch me out and raise me up a pinch. For now it works. The brakes are awful though, I suspect the road calipers with the mtb levers is the source of the issue. I might just have to get some mtb hydraulics to fix that issue!
so I took this:
Likes For Phatman:
Likes For Caber Guy:
#4721
Sunshine
Liked 7,629 Times
Wow, a lot going on here.
Beautiful traditional diameter tube frame with wrap around stays.
Modern enve rims with canti brakes.
Modern crankset with mtb RD and suntour barcons for shifting
Its such a hodgepodge and really cool.
#4722
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Well, I've never raced 'cross (the closest I got was riding the course pre-race one time while all the actual racers either blew past me or got pissed 'cause I was in the way), but I do have a Cross Check that I adore. It's been singlespeed, drop-bar, flat-bar, 1x11, alt bar--you name it. Currently ss flat-bar which is a ton of fun (excuse my saggy chain pls!).
Likes For pbass:
#4723
Anywhere I roam
Surly is the best bike company in the world, and the Cross Check is probably the best bike they make.
#4724
Anywhere I roam
#4725
Mostly Mischief
Likes For jan nikolajsen:
