Backpacking pack as a viable alternative to panniers
I'm leaving on the next leg of my tour and I've modified the rack to better support my pack. I figured it pertained to the topic,
The white grill is a wire kitchen shelf. I used a vice and did some bending to better secure the pack and keep it from bumping my legs. Cable ties secure the shelf to the rack. Longitudinal and transverse bungees will secure the pack and support the section of shelf hanging off the back of the rack.
That is exactly what I’ve been thinking for other excursions. My concept is: the bike and front wheel will be locked to a tree stashed in large black plastic bags. Plus I’ll take the wheel skewers out and hide them elsewhere (or carry them with me).
Slowpoach
Bikes: Cannondale T800, Northwood tandem, 1970s Gitane fixxed 45x16
I like the look of your pack on rack setup in your initial post.
Maybe find a way to enlarge the platform on your rack - maybe a wire shelf (I'm thinking the same sort of material the Wald baskets are made of) or a cut-down milk crate. Pack the heaviest stuff close to the seat post and use straps or bungee cords to hold it on.
Presumably if you're using a golite pack you don't have too heavy or bulky a load anyway...
edit -----
I actually prefer the look of the previous setup as the white rack you put on forces the bag further back. This might make handling on slopes a bit worse.
edit -----
Cave, I weighed my pack before heading out, it is 28 lb base and 8.5 lb of food. I did concentrate most of the weight forward over the rack.
I prefer the look of my previous setup as well. However, the pack annoyingly hit my legs so it had to be shifted back.
