Time for a New Crank
Quoted: 3831 Post(s)
Liked 6,846 Times
So you went with a known failure-prone replacement?
Bikes: Raleigh Super Course, Raleigh International, Raleigh Gran Sport
Quoted: 252 Post(s)
Liked 319 Times
That was my first reaction too, but the truth is that similar breakages occurs in other brands of crankset. If it's aluminum, the fatigue curve is ugly. Replacing with a used part is a crapshoot, since the amount of existing fatigue cycles on it is unknown, but an NO$ Campy crankarm could last another 40 years.
Likes For daka:
Yes. Yes I did. I think that choice is about nostalgia as much as anything. I will check it over carefully before accepting it from the seller.
I could leave the Mighty Comp on, as it is the first cotterless crank I ever had (fall 1973) and was the first crank installed on my Bob Jackson frame after I acquired it (ca. 1974).
I may even work my way back to using NR high flange hubs, despite their needing periodic maintenance. I have the hubs and rims, all I need is spokes.
Likes For Bad Lag:
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
This quote from Ric Hjertberg on the topic always comes to mind:
https://pardo.net/bike/pic/fail-001/FAIL-001.html
Originally Posted by Ric Hjertberg
Campag cranks were the vast majority of failures because they saw the really serious miles. Victims were sure not to stray from Campag for fear of even worse experiences. The more of their cranks you broke the more you recommended to others like yourself to use nothing else.
RUSA #7498
For me, it is the nostalgia. If I break another, I will be very unhappy and will re-mount my trustworthy Sugino Mighty Comp.
Likes For Bad Lag:
Quoted: 3464 Post(s)
Liked 2,837 Times
For the Mechanics here:
I forgot to mention, there was a sizeable difference between where the Campagnolo and Sugino cranks sat on the spindle. The difference was large enough to require a readjustment of the front derailleur.
Otherwise I would give up my two highest gears and the chain falls off when going to the small ring. - the Sugino sits THAT much farther outboard than the Campgnolo. Bottom bracket is a Phil from about 1978.
I love riding this bike.
When installing the Mighty Comp, instead of adjusting the front derailleur (no big deal, really), I could have moved the bottom bracket back to the left.
When I get my hands on the new crank, I need to check the chain line and the frame spacing. If there is room, I would like to move the bottom bracket back to the left a bit. That would be a good thing.
Likes For Atlanta:
aged to perfection
Quoted: 855 Post(s)
Liked 1,286 Times
it's fairly common for Campy cranks to fail at the spider / arm join or at the pedal eye.
The IRD Defender crankset is a nice alternative and offers a 110 BCD so you can run 50/34 chainrings.
this one, custom milled and anodized by the late John "drillium" Williams, looks just about like the campy.
/markp
/markp
I haven't yet fitted it to the spindle, however, everything else about it looks almost new.
The one that broke went from no defects, to cracked and then to broken in half in a span of ~6 months. It all happened after the last inspection.
The new crank is installed.
It looks really nice - almost new. I'll give it the inaugural ride tomorrow.
New crank is just fine.
It located itself on the spindle exactly where the previous one went.
It did not loosen at all during the ride.
I am happy with the purchase. It was expensive but it was a complete crank and had both chain rings installed, the outer of which look unused. The chain ring bolts look new, too.
Quoted: 1842 Post(s)
Liked 3,453 Times
If so, did you file the web that is prone to developing cracks?
I'm assuming that you closely inspected the web for any signs of existing cracks too.
Steve in Peoria
Yes, it's another Campagnolo Record crank. The thing is just this side of brand new. If there's an existing crack, I could not see it.
Here's an image of the crack across the old one. Although you cannot see it in the image, because of the direction I shot it from, the crack is pretty far away from the actual web (transition region). Perhaps note that it cut across the bottom of the deeply engraved Campagnolo badge as an indicator of where it cracked.
Liked 2,837 Times
Appears to me that it propagated from two directions - the “web” crotch and the shield stamping.
note the dark oxide witness near the web acute corner- it was on its way for a long while. Finally let go.
not shown is the face of the crank at the shield logo stamping.
my hunch it would show polishing from ankle and or shoe through the anodizing there on the face.
when these cranks let go near the pedal eye- toe strap/ shoe rub through the anno was almost always present.
one racer we convinced to retire his cranks had rubbed 2mm into the surface ! Aaack!
late in the Record crank production life, besides adding beef, Campagnolo dropped the machining decoration, and moved the shield logo to a laser etching about mid arm.
the forging “grain” appears far from uniform -
it is what it is.
it is what it is.
Likes For repechage:
aged to perfection
Quoted: 855 Post(s)
Liked 1,286 Times
Bad Lag I respectfully suggest that you at least "kiss" that new crank arm with a file or (even) a piece of rolled up emory paper
"Look almost new" can fool you. Those parts are approaching 50 years old now and you have no idea what indignities they've been subjected to.
you want to break and rouind the sharp edge at the web - even if there's no visible crack - rounding off the sharp edge will prevent a crack from forming and (worse) propagating.
Check the pedal eye too
/markp
/markp
Likes For mpetry912:
I'll post some side view photos so you guys can take a look at this failure from other perspectives.
My guess is it got started about 6 months ago, after the last inspection. The black area is probably corrosion and oil from riding all winter. Once it cracked, that last bit went all at once. The light grey section was bright, shiny aluminum when it forst broke but it has gone to grey as it oxidized over the last few weeks.
I've been thinking about how to reshape the edges. Some attempts others have made did not seem quite right. I was thinking about polishing all the sharp edges off, hopefully removing any microcracks in the process.
Thanks for the reminder about the pedal holes. I'd forgotten about those.
Quoted: 4866 Post(s)
Liked 4,015 Times
1977 and 78 I went around riders whose wheels I'd been on as they broke their NR crank at the pedal threads when they stood. First at the bottom of a hill, the second coming out of a criterium corner. I've heard of many more of those crashes since, both at the pedal spindle and the spider base. Now, granted, NRs went forever as the choice gear of funds limited racers. "$25 for NRs with no scratches, just 8 seasons of racing under a very strong rider? I'm in!"
Liked 2,837 Times
the cranks were made for decades, unsure if the same alloy used throughout the production life.
I have always been shy of cranks with rider “polished” arms, the cranks that failed always had some localized anodizing removal.
Also, a pedal strike in a turn can put quite a load on the arm, especially if the rider skips his rear wheel into the air. We saw bent pedal shafts from time to time, often enough to stock replacements.
With bigger, stronger riders, definitely the guys who were stronger than smart, we almost always were able to sell them a replacement crank arm along with the pedal axle, spindle, the term your choice.
spending their money to keep them safe.
Liked 2,837 Times
as to filing away acute edges- I radius the semicircle around the two adjoining surfaces.
scratch removal is a good thing.
if you are extremely worried and wary, aircraft Spruce and specialty sells a crack check dye kit for aluminum.
aged to perfection
Quoted: 855 Post(s)
Liked 1,286 Times
what I'd suggest is - get some emery cloth - 400 grit or finer and cut a narrow strip
lay it in the "web" between the crank arm and spider arm. just do a coujple pulls to round off the sharp edge.
all you really need to do is round off the sharp edge on the forging
Really extreme filing is only required when a crack has developed and propagated far into the "web"
after that it's hard to undo.
Your cranks may be "just the other side of new" or whatever you are telling yourself, so if you want to ride them for years without worry - do this now.
Back in the days when I was doing a lot of work on cars, I had a buddy who did not want to replace the rod bolts with the (very high quality) ARP rod bolts
"the old bolts look new".
dude, you ALWAYS use new rod bolts on a 911 (930) engine rebuild. How many load cycles have those old bolts seen? Millions !
So for want of a $120 set of rod bolts he put it back together.
when the rod let go after about 500 miles it was spectacular. Looked like somebody had dropped a grenade in there. Ruined everything - Case, crank, rods, everything.
suggest you take care of that crank. it's a known failure item. re-assurances of "just like new" will not defeat fracture mechanics.
speaking of which, see pic. I will buy lunch for the 1st person who can identify this part ! Hint: it is a titanium forging.
/markp
/markp
Liked 3,453 Times
I don't suppose it's an infamous failed disc, such as from engine #2 of the DC-10 that crashed at Sioux City, Iowa?
Steve in Peoria
(I've spent too much time watching AgentJayZ's youtube channel on overhauling jet engines)
aged to perfection
Quoted: 855 Post(s)
Liked 1,286 Times
yes, steelbikeguy that's exactly what it is, the turbine disk from United Flight 232, its the fan disk from the #2 GE CF-6 jet engine
I'll email you a gift card !
the point being that even very high quality, inspected and "certified" parts can fail in service
as discussed in this thread
/markp
/markp
Liked 3,453 Times
I even clipped an editorial cartoon... although I'm not certain if this was in reference to UAL 232 or the crash in Chicago when an engine pylon failed. It was not a great era for the DC-10.
Steve in Peoria
Likes For steelbikeguy:
