Campagnolo Record 8 speed history
Bikes: Masi, Olmo, Miele, Masi, Masi
Quoted: 40 Post(s)
Liked 34 Times
I think the tension adjusters models were later. In the catalog pic you can see the axle has only two wrench flats where as the variable tension pedals have 6 wrench flats on the axle. The earlier campy/look pedals had campy axles and bearings with the two flats. Later they just rebranded the Look pedals without using campy parts. I think these in the picture are rebranded Look 286 Multitensor's.
Likes For ltokuno:
Bikes: Yes, probably too many but still have a roving eye...
Quoted: 322 Post(s)
Liked 2,845 Times
I've got a set of the slightly more curvy ones, that also use Delta cleats, that I assume are later?
And these ones have stamp of ignominy that admits Campag had gone the wrong route with their SGR pedals, which seemed to win on being shinier, but were otherwise over complicated, harder to clip into, significantly heavier and more expensive than Look's version. I imagine Campagnolo engineers reacting like vampires do to sunlight upon seeing this mark...
Quoted: 3464 Post(s)
Liked 2,837 Times
<br /><br />
Quoted: 40 Post(s)
Liked 34 Times
<br /><br />
I think SGR came later.
Quoted: 194 Post(s)
Liked 582 Times
Just to add to the photo content a bit, this Denti is equipped (primarily) with 1992 era 8 speed Campagnolo Record. Not visible in a photo is the fact that the shifters and rear derailleur have been modified/converted to 9 speed to simplify the wheel swapping situation at Casa El Chaba. The wheels also have slightly newer Athena hubs as the bike is sporting “winter” wheels.
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1144 Post(s)
Liked 2,034 Times
stunning ride.
Does she have a name? Ladybug?
"Leave the gun. Take the Colnagos."
Quoted: 194 Post(s)
Liked 582 Times
Thank you. No name, but it has been a great bike. I rode it today for the first time in quite a while and so was thinking about our history together. I bought it back in 1987 and was heavily into racing and it became my primary machine for that purpose. One other item about the original Campagnolo Ergopower shifters ( as on this bike) …..I think a very undersold feature of these levers-almost never mentioned, even in advertising- was the adjustable reach of the brake levers. There is a small grub screw between the quick release button and the lever body that can be turned in or out to get the reach that you desired…or need…They were definitely quite different from the plastic bodied Ergopower levers that followed.
Bikes: '92 MX Leader, 84 Colnago Mexico, 85 Recherche, 86 Panasonic ATB Pro, 88 Roberts, 80 moser... ect
Quoted: 68 Post(s)
Liked 136 Times
Where there's a will, there is a way. The lack of a front derailleur braze on helps, though this was the intent when it was built. The frameset is from 1991/92 and built with tange prestige.
Quoted: 1087 Post(s)
Liked 1,917 Times
Which bit? I'm in Melbourne. There appears to be a fair bit of interest in C&V here, but due to lack of retro events it's kind of hidden under the surface.
Liked 1,917 Times
Likes For P!N20:
Quoted: 2588 Post(s)
Liked 4,827 Times
Of course, they are hidden in normal use by the QR button jutting out from the side of the lever.
DD
Likes For Drillium Dude:
Quoted: 2347 Post(s)
Liked 5,231 Times
I got this 8 Speed groupset in today. Listed as Athena but someone said it was C-Record. I keep getting distracted every time I think for a second about figuring what it really is. This may go on a Gianni Motta frame I have coming in.
Steel is real...and comfy.
Likes For jamesdak:
Bikes: Davidson ’81
Quoted: 121 Post(s)
Liked 232 Times
1994 Record. The carbon body Ergos, ramped chainring, and dual pivot brakes were all new that year. In ‘95 everything got printed groupset names. IMO 1994 was the high point for Campy aesthetics in the Ergo era, it’s been downhill since.
outstanding pickup!
outstanding pickup!
Likes For C9H13N:
Liked 5,231 Times
Liked 5,231 Times
As mentioned above, you have a 1994 Record crankset FC-11RE. The 1994 bottom bracket required (cartridge) is BB11-RECART or BB13-RECART (depends on the threading).
I recall that the 1994 spindle length was 111mm, but I'm not certain.
The 102mm spindle is definitely too short. The 102 spindle is suitable for the 1995 - 2006 cranks.
Andrew G.
Andrew G.
Likes For Andrew_G:
Are you still having success with this setup? I just bought a 13-28 Miche cassette and will install it next wee. Any tips?
Le Crocodile
Quoted: 370 Post(s)
Liked 791 Times
I have a bike with Ergo 8- was taught a lesson though, I won an auction for a NOS titanium cassette- Styling... ooops needs the EXA freehub body, I think similar to current just not as wide.
took 18 months of searching to find a NOS EXA freehub- purchased for a decent price.
so now a set of user wheels and coffeehouse bragging rights wheels, tubular of course.
I built it up with a Mavic GP4 rim, then realized the splines were "funny". It collected dust for a little while, so I de-laced it, and put it in the stash.
If I would have known you were looking, I would have let it go decades ago.
Likes For styggno1:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3931 Post(s)
Liked 6,581 Times
I have two 1990/1991 Record rear derailleurs, and they look very similar to that one, but not exact. Similar cable adjuster. Same hanger bolt. They use an old school hex nut for the cable anchor. The wheels have like 14 ball bearings each. Your faceplate appears more curved than mine. And the inner cage plate is different, with mine having no tab for chain routing. Here is one of them:
The limit screws in the '90/'91 Record are different lengths, with the high limit being shorter. Still, the low limit isn't long enough to use with 7-speed friction, so I had to use one from an old Suntour mech.
Cage tension is adjusted from the outside, with the screw highlighted here:
