Caliper vs disc brakes on road bike?
Señor Member
Quoted: 649 Post(s)
Liked 294 Times
The main advantage of discs is the separation of two different duties your rim used to be responsible for. Rims are much more commonly damaged by impacts or spoke breakage, and this can make it necessary to disconnect or loosen your brakes, and effectively reduce their function, for your ride home. Disc brakes don't care how true your rims are - if the tire isn't hitting he frame or fork then you can keep riding.
Also, if you regularly ride with wet and/or dirty rims, rim brake pads will wear though the braking surface over time and possibly cause the rim to fail.
In terms of function, hydraulic discs are superior for stopping in wet conditions, and require less adjustment and maintenance. They are much much easier to set up than cantilever brakes, slightly easier to set up than V brakes, but only marginally easier to set up than caliper brakes.
Cable discs have an advantage in wet conditions, but are more difficult to set up than hydraulics, and require more maintenance.
In dry weather, to which many cyclists limit themselves, there is little functional advantage if your rims are in good shape.
I've spent much of my last two shifts at our local Co-op trying to solve disc brake problems. These included:
I see a time in about 10-20 years from now when most mid-range and above bikes will be essentially unserviceable by Co-ops, due to the current proliferation of weird bottom bracket standards, suspension elements, and hydraulic discs. We will still be servicing 70's and 80's vintage bikes, but these basic commuter warrior bikes will be increasingly hard to find.
- A slightly bent rotor and intermittent rubbing. Very frustrating - hard to eyeball if the rotor was salvageable.
- The misery of removing rotor bolts that are frozen into the hub.
- Hydraulic pistons that are sticky. Will a bleed fix this? How many different types of bleed kits do we need to have in stock? And how many of the dozens of disc brake pad standards should we stock?
- The trial and error of trying to attach new calipers to a frame. We have a bucket of adaptors....
- Someone touched rotors with greasy hands. Cleaning up the rotors to acceptable performance ultimately took 2 hours of work, alternating between scrubbing with white gas and then sanding every square mm of the rotors with sheets of fine fresh sandpaper.
Quoted: 3367 Post(s)
Liked 2,198 Times
V brakes seem to have the spring tension change every time I release the brakes to get a wheel off the bike. I've futzed with V brakes a whole lot more than any others.
Likes For Steve B.:
Bikes: MBK Super Mirage 1991, CAAD10, Yuba Mundo Lux, and a Cannondale Criterium Single Speed
Quoted: 344 Post(s)
Liked 297 Times
So I need to buy new rims now for my wider tires? So pretty much a new wheelset. And a new free hub for my new 12 speed group set. Might as well buy a new bike. And all the new bikes on the market right now have disc brakes, soooo...
Liked 2,198 Times
Are you saying that moving to a 23mm wide rim, vs. a 19, allows a 32 mm tire to magically clear the brake pads ?. I'm sceptical, but occasionally wrong.
Cycleway town
Hydraulic discs only self adjust for pad wear. I'm willing to bet most disc brake adjustment is not for pad wear exactly but due to rubbing. Any slight rubbing is more noticeable a road bike due to less road and tire noise. What I have experienced is that the two pistons never quite extend evenly and thus you've eventually gotta loosen up the adjuster bolts and realign the caliper.
Quality rim brakes with quality pads will brake you hard enough to do an endo if you apply the brakes too aggressively so, no, discs do not stop any faster unless you have low quality pads. Bike stopping distance is limited by tire traction and how hard you can brake without flipping yourself. More clamp from the brakes does not help.
I haven't experienced your alignment issues. I can fit new pads with no tools, I just use my padlock key to bend the retaining pin and push the pistons back. New pads fitted in one minute max. Old pads evenly worn, no adjustment required for the new ones. The caliper is either centre to the disc or it ain't.
Quoted: 4083 Post(s)
Liked 7,668 Times
Wide tires with rim brakes is only a problem when using brake calipers designed specifically for narrow tires. Which is a lot of the brake calipers out there. But not at all a characteristic of rim brakes. If you bought the kool-aid of narrow tires in the first place you get to do at least a complete re-fit and perhaps an entire new bike if you want to jump on bandwagon of wider tires. Such is fashion.
Unmentioned so far is disc brake forks must be stiffer. Tires become the only factor in comfort. The sort of road holding springy forks do is gone. Unless you want to go ahead and get a suspension fork. Basically 120 years of experience with frames is thrown out the window and start over.
Dave Mayer @ 27 is what I hear from mechanics. Most of them phrase it more colorfully. Only a few users imaginably "need" discs, we are all condemned to it. Slower users will never get a disc hot and never get the system broken in. Discs are no service to them.
Biggest problem with rim brakes is they are seldom set up effectively at all. Mafac brakes were introduced 1953. Design is still in production by at least three manufacturers. The new production versions are all expensive and very desirable. They work exactly as the originals. I have never seen a Mafac brake on an old bike that was better than marginal. When I am done adjusting them the owners have to be cautioned and are astounded how strong the brake is. "Why bother with discs?" is a common comment. Then there are the Campy Record OR cantilevers from early 90s which are still stronger and more predictable than many discs. No one is interested in developing rim brakes.
Most rim brakes were designed to accommodate wildly out of true rims. (Dual pivot brakes weren't and don't, that's another discussion.) Disc brakes just stop working if the disc is wobbly. Given that rims and wheels are dramatically straighter and stronger than in the heyday of rim brakes much could be done in way of using the rim as the disc. But that is theory, you can't get such a brake.
Quoted: 344 Post(s)
Liked 297 Times
Quoted: 1588 Post(s)
Liked 1,232 Times
There, you see? Here we are, well into page 2. All it takes is persons of goodwill, willing to post 'points' that have been repeated ad nauseam on here in sundry threads, and 2 pages will quickly become 3, et seq.
Likes For badger1:
Isn't that true of every bike tech ever? “My brakes don’t stop me”, well they’re not set up right. “My press-fit BB creaks” - you haven’t installed it right. “I keep getting flat tires” - your pressure is wrong. “My knee hurts” -your cleats are misaligned. “I’m switching to 1x” - your front derailleur is at the wrong height for your chainrings.
Bikes: Ridley Damocles, Dura Ace 7800
Quoted: 35 Post(s)
I had definitely made up my mind and I wasn't looking for validation or to "stir the pot". I was interested to read what others thought and there was some good info that was added to the original post. The bike manufacturers will get rid of rim brakes sooner than later as it will allow them to streamline their offering and production process, but in my opinion, it's not a great technology advancement and it does make the bikes cost more and increases rolling weight. I am only speaking to road bikes.
Just as an aside, I spoke to three guys from the Aevolo Pro race team at the Cascade Cycling Classic this summer - they were all riding the new Cannondale aero frames, System Six, with discs on the last day, which was a hilly circuit. They (to a man) said that the bikes were great but none of them preferred the discs (alignment issues) and I don't think that frame comes any other way
Quoted: 850 Post(s)
Liked 344 Times
The performance difference between rim and disc brakes is disc’s ability to cut through water and stop in the wet. The “power” and “modulation” are better with hydraulic rim brakes. Most people haven’t even tried compressionless cable housing with their rim brakes. Hydraulic rim brakes are incredibly rare, but there have been a few and those are supposedly better than disc brakes. You could argue that disc brakes have an advantage because the pads sit closer to the rotor, but that causes a lot of rubbing issues. If rubbing were acceptable, you could do the same with rim brakes. Rim brake pads also compress a bit more but you can remedy that by using thinner or harder pads if it really bothers you.
I personally think that the main reason disc brakes came in was because carbon rim brake clinchers were really tough to get right, especially in the rain and long descents. That and maybe wider tires became fashionable and nobody wants 90s era V brakes on their road bike. More cynically, perhaps, bike manufacturers ran out of supposed “innovation” to push on us.
I truly sympathize with the co-op mechanic above. It must be tough, especially with so many people believing that disc brakes are the second coming. I know that, for most people, hydro discs are pain-free, but it also seems that there’s greater scope for things to go wrong. At the very least, it seems harder to get them “perfect”. On a group ride last week, two people had new Specialized disc brake bikes and both were rubbing HARD on steep kickers. Both of my friends on my team who upgraded to road disc last season rub on hill sprints. I’m not even OK with my bike making vague clicking sounds. If that happened to my bike (I sprint up hills frequently), I would demand a refund or warranty.
Quoted: 941 Post(s)
Liked 319 Times
Well, I just have to wonder why other machines of conveyance have switched from mechanical to hydraulic, and from shoe/drum to disc.
![foo](https://www.bikeforums.net/vb/cache/ds.jpg)
Cycleway town
I can’t tell if you believe these things or if you’re pointing out the excuses people make to defend the things they believe in.
Discs still have abundant problems, as you note in your post. Except if you believe the marketing, in which case they have gone beyond perfection. Engineering work and trial and error work continues to be done, and is done with a will. Basically nothing has been done with rim brakes. Unless you count Shimano Direct Mount, which is just digging a deeper hole. Even limiting the investigation to extant brakes it is evident that some rim brakes are much better than others at their ability to cut through water and stop in the wet. They are not all the same. No one is investigating why. Even very simple stuff like braze-on centerpulls is a miniature niche for the Jan Heine crowd. Peugeot did that for a couple seasons with the PY-10CP and any lucky enough to have ridden one knew how well it worked in the wet. But I'd be surprised if there were more than a couple hundred of those and it might have been less. Any lucky enough to ride Campy Record OR knew how well it worked in the wet and again there were likely only a few hundred sets. Half of which are still in the box with Campy collectors. Marketing trumps engineering every time.
Señor Member
Quoted: 649 Post(s)
Liked 294 Times
Someone mentioned that the super tight clearance required for discs could be used to improve rim brakes, if the leverage ratios were changed, but the first pothole you hit would make your brakes rub a whole lot worse than discs do when you are sprinting up a hill.
I'm not sure what your point was about braze-on centre-pulls - these used to be called 'U Brakes' and were standard on MTBs in the late 80s/early 90s. They went away for a reason.
Also I think your timelines are off. In the late 90s and early 2000s, discs were in their infancy and there were some real dogs - Cannondale Coda discs come to mind as the worst of the lot, but the difficult setup and constant rubbing I saw on some other brands were also problematic. But decent quality hydraulic discs from ~2008 and onwards, IME, have been pretty much bolt-on-and-ride. I can see how a lightweight road-racing frame and fork with traditional QR axles could be problematic and less desirable than good calipers, but any modern bike that isn't flirting with the UCI weight limit could be made marginally better, at least, with thru-axles and discs.
Quoted: 18596 Post(s)
Liked 16,096 Times
Disc brakes are a fad and, therefore, unnecessary. They will go the way of the Pet Rock and all of the suckers who bought into them will feel embarrassed riding their bikes in public around serious cyclists.
Likes For indyfabz:
Getting ready to replace my 2009 Ridley Damocles - I am sticking with Ridley as the Damo that I have been riding / racing for 10 years has been fantastic. Probably going to a Fenix SL. I had no intention of going with disc brakes but a couple of my riding partners think I should.
I understand the difference but the extra cost / weight doesn't justify the benefit (to me). I will outfit with HED Ardennes Black wheels (no pads on carbon tracks)
why pay more and add 1/2 pound to wheel weight??
I did one ride up and back down a mountain last year that was extremely challenging. I pretty much reached my limit to climb by the time I reached the top. After a break I headed back down. The road is very steep, narrow and heavily pitted and rutted with little or no useable shoulders in many places. The remote possibility of oncoming traffic around numerous blind turns means picking a path akin to a single-track decent. Brake fade became a serious issue almost immediately. I actually had to slow to a complete stop a couple of times to regain control. No doubt fatigue from the accent was a contributing issue as was the cold wind which caused my eyes to tear to the point that I couldn’t focus, but if I were to ride such roads more often hydraulic disc brakes would be welcome.
There’s another decent I ride more often where I would appreciate the ability to slow down quicker to negotiate several tight turns under control without having to scrub off decent speed so far in advance between turns.
If I ever buy another road bike I’d seriously consider the latest disc brake technologies and associated bike frame designs.
Happy cycling!
The difference between disc brakes and rim brakes is not so much how the calipers work, but that the rim (which is in effect a very large disc brake rotor) goes straight though puddles and potholes, while a separate disc brake rotor at the hub is removed from debris and road hazards. There is no design of rim brake caliper or pad shape that will make up for this difference. Hydraulic rim brakes, which I had for a while in the late 90s, may have been a bit better than cable operated rim brakes, but the rim was still down in the mud and debris, so there was limited improvement possible.
Almost every rider I know who has discs has problem after problem. A few go to the LBS weekly or more often for a year or more before finally getting tolerable function. The other way to handle the problem is to make that bike a garage ornament. Which is already the simple majority of bikes, discs have aggravated that. The exception to constant problems would be very new top end Shimano brakes. Those are getting easier to manage. Or at least often they are largely trouble free. You think it's been bolt on and ride for a decade. How many different systems of bolting on have there been in past decade? Do we have standardization yet? I can't see standardization from here. Nor have I heard that much reduction in constant rubbing.
Simple stuff like parking a bike on a rack is hard on discs. Discs are going on every new bike and they aren't ready. Any bike at all can be damaged parked on a rack, discs are just way more vulnerable.
I know what a U-brake is. Apparently you don't know what brazed CP is. OK, there aren't many of them, not surprising you wouldn't know.
Through axles have only been standard and automatic for what, two years. Also only about two years since sponsors bludgeoned the last CX pro with rim brakes into using beta discs. The CX pros who wanted to stay with rim brakes had reasons, good ones. They saw the majority of the competition on discs and didn't want to go there. It wasn't that they didn't want to win.
The big sales point for discs has always been powerful braking for trivial effort. Most riders don't ride much in rain, few wear out rims. It's the instant gratification that sells the brakes. Is it even a good idea to have that much instant brake? In a panic situation it might just be a good idea to have to work hard to brake. On a long descent discs mean forearms do not get so pumped, hands do not get so tired. Every other part of the body gets worked hard though. Should those with weak hands be encouraged to do long fast descents at all? I don't think so. Sounds more to me like a way for the unprepared to get in over their heads. I am way out of step for thinking it is not always a good idea to make riding easy. And then I see someone who has been trained to believe their brakes are perfect who just got instant and total brake fade.
And most of the discussion of all these points sounds like ad copy. Ad copy does not impress.
Likes For Atlas Shrugged:
Liked 16,096 Times
In the past I was way overboard into audio equipment and discussions similar to this popped up all the time. In due time I figured out that none of it mattered as one man heard what he heard and another heard what he heard. Was there any real difference in what was really heard? Not to the average human being with average hearing.
Disc brakes vs. rim brakes is such a topic of discussion. For the average human with average needs and usage, disc brakes mean nothing other than increased cost. It is the industry driving the change as it keeps the product fresh, just like audio equipment. Let one man ride what he rides, and another man ride what he rides and both are satisfied.
Can it be that JP Penny was decades ahead of the bike geeks with their disc brake bike some 40 or 50 years ago?
