Balancing Cantilever Brakes
Quoted: 1441 Post(s)
Liked 1,999 Times
and if you have first gen 8 speed XTR (M900) shifter/brake assemblies designed for cantilever brakes - a ‘travel agent’ or similar mechanism might be required so the brake pull will work with the linear brakes … later XTR 8 speed (M950 etc) are designed for linear brakes
Liked 1,999 Times
I ran into a problem adjusting the front brake. These are the Shimano Altus CT91 brake. It has an adjustment on one side. I turned the screw too hard and the screw now turns without grabbing. It goes into a plastic housing. I would gladly replace the brakes with a higher end model. As I previously mentioned, the last one I tried did not work out. The pads would not go low enough to reach the rim.
I ride this bike more often than my road bike. Now that I am old, I feel more secure on the wider tires.
I see this as my choices.
1. Buy a new bike.
2. Change the the drive chain to a 1 X. I am happy with the XTR shifters however.
3. Buy another pair of the CT91 brakes
I would like to begin the process soon so that I can be ready to ride in the Spring.
All suggestions are welcomed and appreciated.
1. Buy a new bike.
( you can spot this in the picture above )
if you like the bike / plan to ride it -
I would look for brake calipers that have replaceable pads
I would lean toward replacing the crank with another triple or replacing the chainrings - whatever seems to make more sense and cents
replace the chain and cassette and you will be good to go for years
vintage ATB’s are great versatile bikes
Quoted: 201 Post(s)
Liked 66 Times
one bad / not-so-good thing about the CT91 brake calipers is brake pad replacement will require replacement of the entire brake pad assembly (including post) and therefore will require adjustment etc - as opposed to a brake caliper that has brake pads with removable / replaceable brake pads (with just a small screw / pin) to retain the brake pad on the assembly
Liked 1,999 Times
I am thinking of these brakes though reviews on their stopping power are mixed.https://www.thebikesmiths.com/produc...SABEgIYzfD_BwE
again - I prefer pads that can be replaced without replacing the entire brake pad assembly … the pads equipped with that brake caliper are not that type … just a preference though
for the most part I’m sorta / kinda boring and stick with a brake system that was originally spec’d on the bike or a similar bike of that general era … I have old XT cantilever brakes on my XT bikes, STX brakes on the STX bikes, XTR on the XTR bikes … etc …
cantilever brakes can provide very good stopping power when equipped with good pads and set up well (and rims with good sidewalls etc)
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 906 Post(s)
Liked 1,948 Times
those brakes appear to be good but I’m not familiar with them
Quoted: 4553 Post(s)
Liked 1,695 Times
Stud type cartridge pads:
