Where can I find an M10 fastener?
LR÷P=HR
Bikes: 1981 Holdsworth Special, 1993 C-dale MT3000 & 1996 F700CAD3, 2018 & 2019 Cervelo R3’s & 2022 R5, JustGo Runt, Ridley Oval, Kickr Bike 8-)
Quoted: 891 Post(s)
Liked 1,242 Times
That bolt has to be at least M50 !
sorry could not resist.
Barry
Barry
Quoted: 915 Post(s)
Liked 516 Times
Look at the stainless steel washers. They always seem to be half the thickness of regular steel ones.
If you need to sleeve the hole to reduce slop they have bronze bushings that might fit or tubing.
Bronze bushings
Bronze bushings
Quoted: 3422 Post(s)
Liked 5,623 Times
I usually use Bolt Depot for replenishing stock when it gets low.
I had used Fastenal in the past, but the last time I tried to order from them, they wanted to charge me an insane shipping charge to the local store.
When I just need a few bolts, I find best price from Chinese sellers on eBay, as long as I am not in a rush.
Bikes: Trek 930, Redline Conquest, Surly LHT, Surly Troll
Quoted: 18 Post(s)
You guys have been a huge help! There's an Ace hardware not too far from me - that's actually the very first place I went looking for the bolt. They had more stainless fasteners than HD and Lowes but just not the right size. I will probably head back there in search of a bronze bushing, tubing or small washer to fix my slop problem.
Bolt depot. On the list for future fastener acquisitions.
Quoted: 431 Post(s)
Liked 727 Times
So I don't have any old axles around; West Marine doesn't have a 10mmx1.0 bolt; I didn't get to Fastenal before they closed for the weekend...however, I searched Home Depot online and found a store in the area that does have an M10x1.0mm bolt - 20mm long! I'll be there tomorrow.
Next question: 20 mm will be too long so I'll have to cut it down. I know from previous experience that cutting with a hack saw mangles the threads at the end. How do I clean up the threads so they will engage well with the eyelet on the frame?
One approach that occurred to me is to cut the bolt while it's screwed into the frame. Then maybe when I back it out, after cutting it to length, the threads in the frame will force any damaged threads on the bolt to the correct shape. This assumes that the steel of the frame is stronger than the steel of the bolt ( I have no idea if this is the case). Otherwise, the damaged threads on the bolt will only ruin the threads in the frame, which, obviously, I don't want. Is there a better way?
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
For the future:
mcmaster.com
grainger.com
mscdirect.com
If you can't find it there, you probably don't need it. Also, in some bigger areas they likely have a local distribution hub with a walk up counter. We have a Grainger local to us.
mcmaster.com
grainger.com
mscdirect.com
Quoted: 18447 Post(s)
Liked 4,559 Times
elcraft
Looking at the picture, it occurred to me that stainless may not be the best application if the drop out is made of aluminum! Stainless fasteners installed into aluminum can initiate a electrolytic reaction causing corrosion. If this is not a bolt in tended to be removed regularly for maintenance, I personally prefer to use never-seize compounds rather than grease or even Loctite.
Bikes: Shmikes
Quoted: 10223 Post(s)
Liked 5,947 Times
Stevoo
Your local auto parts store usually has a selection of metric fasteners too.
Have bern successful in going this route in a pinch.
Quoted: 18 Post(s)
Man, who knew there was so much to consider when faced with a seemingly simple bolt issue! I'm really grateful for all the input though. Next time around this will be a snap.
I haven't been able to find a spacer or tubing of any kind to take up the slop between the bolt and the hitch so I'm going to put it together with the slack in there and see how much it moves. I'm hoping it will stay put if it's well-tightened. I'm expecting my new rear rack to arrive tomorrow and then I'll configure everything on that dropout at the same time: fenders, rack and trailer hitch.
So, this particular bike is a Surly and I'm pretty sure their bikes are all steel from one end to the other. I do have an aluminum cross bike though. Would you recommend treating or replacing all the screws that are used on that frame - or any other aluminum frame?
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
N.B. recommended only for steel spacers; softer materials like aluminum or brass can clog the grinding wheel and make it overheat. You don't want that to happen, as the heat stress can shatter the wheel and send out high velocity shrapnel.
Liked 5,623 Times
Any time you put two different metals in contact, you have a possibility of galvanic corrosion.
The likelihood depends on the difference in the anodic index of each.
Here is an explanation and a table of anodic indexes: https://www.engineersedge.com/galvanic_capatability.htm
That said, I have bikes with aluminum, steel, titanium, and carbon fiber frames
I use stainless bolts on all of them, and use blue Loctite on every bolt.
The Loctite prevents galvanic corrosion, and ensures bolts don't loosen up by themselves.
elcraft
I remember a discussion about di-electric compound. I don't clearly remember if this would be a remedy against galvanic corrosion. Most thread compounds; loctite, grease, or never-seize probably prevent such corrosion. I suspect this is a greater problem in environments where salt is present- either winter salted roads or seashore air or weather. But I tend to err on the side of caution, especially sinceI ride vintage steel, some of it from the Seventies.
Finally found some online: https://www.boltdepot.com/Metric_tap...m_x_1.0mm.aspx I would still prefer to buy locally so I'll probably visit the Fastenal near me. Thanks for the help on this.
The above bolts are not stainless but maybe a good slather of grease would keep them from rusting for the foreseeable future.
That raises another question I've wondered about lately. I recently got an new, steel frame bike and I've added racks, front and rear. While installing the racks I wondered whether it was better to grease the threads of the screws I was using (the ones going into the braze-ons) or apply Loctite. I assume you can;t do both. I went with the grease because that's what I had in the shed, but for future reference, is it better to use thread locker?
Quoted: 996 Post(s)
Liked 592 Times
Titanium M10 bolts HERE.
Perhaps my Burley hitch attachment comes with a different recommendation, but any reason not to attach yours to the hub via the wheel quick release? I haven't looked at the Surly hitch mount specifically, but it does it require removing that hitch mount first whenever you need to remove your wheel?
Dirty Heathen
Quoted: 895 Post(s)
Liked 945 Times
Now, why you would pull a trailer with a Single Speed is beyond me, but Surly riders are weird like that.
