Cycling Pace & Calories Burned
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 599 Times
I use an estimate of 100 calories burned for every 5 km.
So if I cover 5 km in half an hour I burn 200 cal per hour.
If I cover 5 km in 15 min I burn 400 cal per hour.
That fits with what Strava and MFP tell me.
Quoted: 1186 Post(s)
Liked 289 Times
Yes, you're right. I must have been half asleep.
The force needed at twice the speed is four times. I made the mistake of factoring time in work, rather than distance. I should not have considered time unless I were using power, in which case, I would have used the cube, but then divided by the time getting 2x2x2 / 1/2 or 2x2.
Quoted: 6002 Post(s)
Liked 2,940 Times
When I use the tablet, I get distracted by having to keep it from helping me, and stuff like this happens. BTW - you're also catching the same disease but it was a simple typo, not 1/2 or, but 1/2 of, or half of.
OTOH - it might be that the thread is jinxed.
FB
Chain-L site
FB
Chain-L site
Non omnino gravis
Estimating is not guessing.
There is enough scientific data and past history available so that we can get very close estimations based on weight of the rider as well as intensity and duration of the event. Heart rate can be used to gauge intensity very accurately.
-Tim-
-Tim-
In my experience with several hundred rides with HR only, and several hundred more with power + HR, the two are not in any way related.
I also really don't see the reason for insisting on a difference between speed and pace-- a speed of 20mph is a pace of 3min/mi. They're just different ways of stating the same thing, at least for our purposes.
speed: rapidity in moving, going, traveling, proceeding, or performing
pace: a rate of movement, especially in stepping, walking, etc.
Semantics.
Quoted: 27 Post(s)
There are plenty of calories burned estimators you can find on the Interwebs.
E.g.,: https://captaincalculator.com/health...ng-calculator/
How many of them are even remotely accurate is another issue.
Quoted: 27 Post(s)
Quoted: 27 Post(s)
I think your pace (if you do 5k in 1 hour) is 12 minutes per km, so (if you do 5k in 30 minutes) your pace is 6 minutes per km. This is what my OP is about, data that correlated calories to the pace/effort & distance & probably the cyclist weight.
Liked 289 Times
yes, I was thinking half of and translated it wrong.
I just substituted a multiplication sign for your division sign. I left the rest of the phrase as you wrote it.
Quoted: 27 Post(s)
Semantics.
Semantics.
Bikes: One of each: Road, Hybrid, Trekking
Quoted: 137 Post(s)
Liked 115 Times
Based on my totally unscientific calculations of me riding about 15mph and being about 180 pounds: 1 mile of cycling burns about 40 calories.
Uphill = a little more.
Downhill = a little less.
Faster = a little more.
slower = a little less.
You're welcome.
You're welcome.
Quoted: 27 Post(s)
How to estimate based on weight & distance then?
What you explain looks fair to me.
Hack
Bikes: TrueNorth CX bike, 88 Bianchi Strada (currently Sturmey'd), Yess World Cup race BMX, Pure Cruiser race BMX, RSD Mayor v3 Fatbike
Quoted: 352 Post(s)
Liked 199 Times
On a bike, weight only really matters on hills. Unlike running, your body doesn't have a vertical motion component. And once you start going around 20kph, wind resistance dominates other factors, so when going fast (by yourself), it is more burn by going faster, even same distance.
In Real Life
Bikes: Lots
Liked 599 Times
Yes. Very well.
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
don't try this at home.
Quoted: 989 Post(s)
Liked 539 Times
15 mph: 25-30 cal/mile
18 mph: 27-37 cal/mile
Climbing a moderate 4% grade: about 65-70 cal/mile.
downhill is "free" so climbing & descending the hill is around 35 cal/mile.
These numbers use the ballpark calories burned ratios: 24% useful work, 76% waste heat
These numbers "might" be 20% higher, if you are at the low end of converting calories into useful work: 20% useful, 80% heat.
Windy days, very rough roads, or drafting another rider can all affect the power needed. So calories per mile is probably just a ballpark number to get a rough idea of the whole ride's calories. It's interesting how few calories it takes -- bikes are very efficient.
My calculations:
The best estimates of calories are with a power meter. The power produced by a rider can be converted into calories.
This bike speed calculator gives quite good estimates whenever I've tested it, on flats or on climbs.
It says, for a 180 pound rider, flat road: on the hoods: around 120 watts, in the drops: around 100 watts. That seems pretty close to data from my rides.
120 watts for an hour is 432 kilojoules: 120*3600 seconds /1000. And 100 watts is 360 kilojoules.
Kilojoules is quite close to calories burned -- see the "converted into" link above.
So 120 watts is approx 430 calories per hour. (perhaps as high as
and 100 watts is approx 360 cal/hr.
At 15 mph, a mile is 1/15 of an hour. So the calories are in the range of 360/15 = 24 to 430/15 = 29
About 25-30 calories per mile.
18 mph is about 140 watts on the drops, 190 watts on the hoods -- wind resistance goes up fast as speed increases.
That's 140*3.6 = 500 cal/hr. 1/18 is 27 cal/mile
through 190*3.6 = 680 cal/hr. 1/18 is 37 cal/mile.
Hills
A 4% grade:
at 6 mph is 113 watts. 113*3.6 = 406 cal/hr. 1/6 is 68 cal/mile -- the mile takes a lot longer than on the flats.
at 8 mph is 153 watts. 153*3.6 = 550 cal/hr. 1/8 is 69 cal/mile -- the climbing takes a similar amount of energy either way. Interesting.
Quoted: 989 Post(s)
Liked 539 Times
Pace makes a lot of sense for runners.
Quoted: 590 Post(s)
Liked 445 Times
A faster pace (aka speed) over the same course will mean greater wind resistance, which should mean more effort is required to ride the same course, compared to a slower speed/pace.
Quoted: 550 Post(s)
Liked 326 Times
You can always wear a heart rate monitor when riding/exercising. They can either feed real time data to a watch that you wear (Polar or Garmin) common with runners, or with to an app on your phone. This can be helpful if you're trying to train in a specific heart rate, but should be pretty accurate for calorie counting.
Quoted: 550 Post(s)
Liked 326 Times
1 Watt = 1 joule/second, so 100W for 1 hour = 360,000 joules or 360kj. 1 Calorie = 4.2kj although cycling metabolic efficiency is never better than 25% so you can approximate 4 Calories in = 4.2kj out and round to 1 Calorie in = 1 kj out.
On "flat" terrain out-and-back using a power meter with +/-2.5% accuracy riding on my brake hoods I measure about 100W averaging 15 MPH for 360 Calories / hour and 24 / mile; 150W at 17 MPH for 540 Calories / hour and 32 / mile; and 200W at 20 MPH for 720 Calories / hour and 36 / mile.
YMMV.
Weight doesn't make an appreciable difference on flat ground.
An extra 50 pounds rounding to 23kg over 1 mile rounding to 1600 meters would add
23 kg * 9.8 m/s^2 * .004 Crr * 1600 m = 1.4 kj per mile = 1.4 Calories per mile.
10 pounds would be just 0.28 Calories extra.
YMMV.
Quoted: 2953 Post(s)
Liked 3,106 Times
I never see cyclists using pace numbers. I suppose it's because riding has such a wide range of speeds, from 3 mph on a steep climb to 30+ mph on an all-out sprint. And, bike computers always showed speed and average speed, not pace.
Quoted: 185 Post(s)
Liked 38 Times
Not familiar with Garmin Edge 500. Are you saying that system came with a chest strap heart rate monitor, and was still a 100% off based on some other "actual" measured output? If so, how did you determine that the other measured output was more accurate?
Quoted: 989 Post(s)
Liked 539 Times
The heart rate based calorie counters are a rougher estimate of the calories burned.
On moderate to steep hill climbs, wind resistance is a much smaller part of the power -- most is fighting against gravity. So, knowing the bike+rider weight, the grade, and the speed, a fairly good power estimate during the climb is possible.
Quoted: 550 Post(s)
Liked 326 Times
He also had a power meter to measure watts and kilojoules.
Up steep hills, measured power output is about 10% over what you'd calculate on the back of an envelope only accounting for lifting bike+rider weight to the top, ignoring rolling resistance and aerodynamic drag.
Bikes: Colnago Master w/ Campy Record 11-speed road / Colnago Super w/ Campy Chorus 7-speed backup / Colnago CX-50
It all boils down to heart-rate, weight, age, and time. There are a couple of formulas - I use;
Men use the following formula:
Calories Burned = [(Age x 0.2017) — (Weight x 0.09036) + (Heart Rate x 0.6309) — 55.0969] x Time / 4.184.
Women use the following formula:
Calories Burned = [(Age x 0.074) — (Weight x 0.05741) + (Heart Rate x 0.4472) — 20.4022] x Time / 4.184.
There are inherent issues with whatever method you choose.
A power meter, while accurate to a degree is also inaccurate compared to another power meter.
As an example. I have a set of powertap pedals which read 5% higher than the powertap wheel. I had them both on using separate Garmins to record the data during an FTP test.
My Stages power meter ran 8% higher than the powertap wheel, again, running on the same ride with separate Garmins.
Moral of the story for me...
Use the data you get, from the interwebz, fitness tracker, powermeter or whatever and use the data consistently with a program such as myfitnesspal to track the food bits. You'll soon find out if the calories in versus the calories expended is working for you based on your belt. Adjust as needed. YMMV
Ride, Wrench, Swap, Race
Quoted: 1575 Post(s)
Liked 1,324 Times
I don't use sophisticated electronic aids so have not gathered any data myself. My Garmin seems to provide rough data when it comes to altitude so I don't put much weight in it's calorie reporting.
But physiologically, isn't there some sort of efficiency curve that charts changes in metabolic efficiency versus the level of intensity, and what does the curve look like?
I tend to eat like a horse after hammerfest training rides, once my appetite gets going. I force myself to eat a big bowl of microwaved (and seasoned/buttered/salted of course) vegetables early in my binge, a large variety including corn and spinach, etc.
As far as maintaining a desired weight, Chris Carmichael seems adamant about:
1) achieving fitness goals by training, and
2) achieving desired weight by eating "properly" for one's circumstances.
I believe that I have read his columns in Road Bike Action recently and he seems very consistent in what he recommends.
