Tire Liners - Must have for the commuter?
Old 01-28-09, 06:46 AM
tarwheel's Avatar
Bikes: Waterford RST-22, Bob Jackson World Tour, Ritchey Breakaway Cross, Soma Saga, De Bernardi SL, Specialized Sequoia
Quoted: 196 Post(s)
Liked 6 Times in 4 Posts
A lot depends on where you live and the quality of roads where you ride. I rarely ever get flats, and I commute on 700 x 23 or 25 training/racing tires. I guess the roads must be relatively good in NC. The last flat I had was several days ago on my fast weekend bike. I pulled the tube out expecting to find a hole from some glass or a wire, and it turned out that it had failed at the valve. Probably at least half of the flats that I do get are from valve failures rather than road debris.
Another issue is how you ride. If you keep your tires pumped up to the correct pressure all the time, it greatly decreases your odds of getting pinch flats. You also can avoid a lot of flats by not riding in the crap that tends to collect along the sides of the road. Take some of the lane, where the pavement is usually better and cleaner.
tarwheel is offline
Old 01-28-09, 10:23 AM
cowboy, steel horse, etc
LesterOfPuppets's Avatar
Bikes: everywhere
Quoted: 13052 Post(s)
Liked 7,980 Times in 4,248 Posts
Originally Posted by devianb
Every bicycle I have had in the past 6 years has had tire liners. On my old Diamond Back the nipples stuck out a little bit so if I ran a really high tire pressure without a liner the inner tube would occasionally pinch the sharp edge of the nipple and get develop a small hole. On the newer wheel sets I have the nipples are either much smoother or recessed a bit so that it is not a problem. I use the tire liner for a little extra security though.
I think you're confusing tire liners with rim tape.
Rim tape fits between the rim and the inner tube.
Tire liners fit between the inner tube and the tire.
No matter how smooth your nipples are, every spoked bike rim with an innertube should have a rim strip, regardless of pressure.
LesterOfPuppets is online now
Old 01-28-09, 06:31 PM
Bikes: 02 Jamis Coda
Man, I have been running with Gator Ultra's and have had very few flats until the last few months...and get this, I have had a flat three days in a row. So I don't know, I think I am going to try the Armadillo Elite's.
blueeyedme is offline
Old 01-28-09, 07:53 PM
nkfrench's Avatar
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 8 Post(s)
Liked 14 Times in 5 Posts
I had all sorts of flats on "Rusty Schwinn" until I put the thorn-resistant tubes and Mr Tuffys in. After that, no punctures for a long time. I've learned to never ride off-pavement here due to the goats head burrs that caused so many punctures. I actually wore one TIRE out and the thorn-resistant tube was exposed through the tire belting for about 12 miles and still didn't flat it (no liner in that tire).
The new bike "Ruby" I rode about a month on the same routes and got punctured. I replaced the tube with a pre-slimed tube and have gotten two more punctures within weeks, but it still holds air. It is hard to get the tire pumped full though and I wonder if the slime is ****ering up the floor pump.
The guys at the LBS kind of shamed me into not putting slow tubes/tires on my fast new bike Ruby, and encouraged me to just learn how to deal with flats on the road. They can change a tire in a couple of minutes; last time I tried, it took me over an hour in good conditions. That means - safe place to work, light so I can see what I'm doing, temperatures so I can work barehanded. I am just going to see how it goes.
nkfrench is offline
Old 01-29-09, 01:56 AM
devianb's Avatar
Bikes: 2008 Dawes Haymaker 20XX Leader LD515 TotoCycling Road Bike
Quoted: 27 Post(s)
Liked 32 Times in 19 Posts
Shoot you are right. In that case I never use tire liners, don't feel they are necessary.
devianb is offline
Old 01-29-09, 07:48 AM
Quoted: 119 Post(s)
Liked 96 Times in 65 Posts
Marathon Plus(summer) and Nokian Hakapillita winter) with Mr Tuffy liners here. My bike criterion is that, since it gets used for the same function, it should equal my car in flat protection.
Paul
PaulH is offline
Old 01-29-09, 09:04 AM
acroy's Avatar
Quoted: 9 Post(s)
Liked 9 Times in 5 Posts
Tubeless Rules All
my commute has no bike lanes and goes through a college area (lots of glass) and an industrial area (lots of scrap, tire wire, glass, dead animals).
Averaged 1 flat per week on good weeks
I tried liners, slime tubes, kevlar belted tires, etc etc.
Switched to tubeless about 7,000 miles ago and have not looked back. One flat due to a key (a friggin HOUSE KEY) that magically punctured the rear tire... otherwise, perfection.
I pick glass, tire wire, metal shards, etc out of my tires 1/wk and refill with sealant every 3 mo. I got 5k out of a set of Schwalbe Marathons and just passed 2k on the current Continental Sport Contact.
Tubeless Rules All
acroy is offline
Old 01-29-09, 09:24 AM
Lamplight's Avatar
Quoted: 7 Post(s)
Liked 13 Times in 12 Posts
No tire liners, but I use puncture-resistant tires on all of my bikes. Last time I used regular tires I got 3 puncture flats in two days.
Lamplight is offline
Old 01-29-09, 09:57 AM
hurricane harry's Avatar
Bikes: Novara Randonee/DRZ400S
tire liners rule
hurricane harry is offline
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
