C'est fini! -- PX-10 content
Bikes: A few too many
Quoted: 1367 Post(s)
Liked 2,190 Times
I'm not sure what to make of the upper bands here. Was it an attempt at the French colors by someone who is insufficiently skilled at heraldry? Or is it meant to be the Netherlands' colors? The Ireland sticker makes the Netherlands a possibility, I think, if a previous owner was tracking where the bike had been ridden. I've seen the bleu-blanc-rouge in this orientation, but if that's what it's meant to be they're in the wrong order, I think, and the proper French flag would have the colors vertical. I'm not sure my latent OCD will allow this to stay.
Hah, my own OCD kicked in when I saw this, too, but for a different reason: r/w/b bands at the top just looks wrong - the World Championship bands should bracket on both ends. I don't know if that's how it originally left the factory, or if the r/w/b band was added by a PO, but it just looks wrong. Plus, it's foil while the rest of the ensemble appears to be normal water-slide decal.
The bike came out beautifully - one of your best builds in recent memory. If I could be so bold: how about a close-up of that purty rear derailleur?
DD
DD
![Big Grin](https://www.bikeforums.net/images/smilies/biggrin.gif)
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Bikes: Yes
Quoted: 3300 Post(s)
Liked 4,085 Times
The binder bolt I have has a socket on both end, but since the ears on the frame don't have a slot for the key I think it's pushing in the end of the ear and not enough on the side of the post. I'll probably just file the key off of the bolt.
My Bikes
My Bikes
Bikes: Yes
Liked 4,085 Times
No, I just left it bare. I guess eventually it'll need something to prevent rust, but I've got another bike that I left bare like this and it hasn't shown any rust after two or three years.
My Bikes
My Bikes
Bikes: Yes
Liked 4,085 Times
I used a V-O BB. My first attempt was with the 118mm BB that V-O recommends, but it put the big ring so far out that the Simplex FD wouldn't reach it. I had a 107mm V-O BB on the shelf, so I swapped that in. The gap between the crank and the BB fixed cup is miniscule, but otherwise it seems OK. If it doesn't feel too narrow when pedaling I'll leave it like this until the BB inevitably starts unscrewing.
My Bikes
My Bikes
feros ferio
Quoted: 1410 Post(s)
Liked 1,366 Times
PX-10s are gorgeous, and I am all for "sympathetic" builds. I also appreciate a fellow cyclist who sees no need for high gearing, although I do like something around the mid-90s, such as 45 or 46/13 or 49 or 50/14. Skipping the super-high gearing and going with a reduced-size outer chainring solves a lot of problems when you need low gears and don't have a super-long and low-mounted rear derailleur cage.
Likes For John E:
Ce n'est pas la fin. Ça ne fait que commencer.
(It's not the end. It's just starting.)
Likes For Bad Lag:
Liked 2,190 Times
^^^^^ Oh No......What color is Peugeot White? ![Innocent](https://www.bikeforums.net/images/smilies/innocent.gif)
Best, Ben
Best, Ben
Voltaire
Voltaire
Bikes: Yes
Liked 4,085 Times
Probably so, but I'm much more comfortable modifying a $6 binder bolt than cutting into the frame.
My Bikes
My Bikes
Bikes: Yes
Liked 4,085 Times
Don't even get me started. You clearly know how I get. I'm already afraid to wash this because I like the patina. I was very nervous wiping off the dirt that was left around the old shifter clamp. And somewhere it picked up a long scratch along the bottom of the downtube. I might have to accept a slight color mismatch there.
My Bikes
My Bikes
Likes For Andy_K:
Liked 2,190 Times
The bike still looks fantastic and you will only notice the "BIG" scratch when laying resting after the DBL century!
Signing out on this one. Enjoy.
Best, Ben
Voltaire
Voltaire
Likes For xiaoman1:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4719 Post(s)
Liked 5,981 Times
Likes For gugie:
Bikes: Yes
Liked 4,085 Times
Since you mentioned my PH-60, I'll tell you what I went through. The bike came to me from France fairly dirty, so I stripped it down to the bare frame. I carefully removed the grime, but the paint was still fairly oxidized. I carefully removed that layer with rubbing compound, but noticed that the pinstriping and decals would wear down, so I was very careful not to touch them. I think I worked on the paint for several days, it felt like I was touching up the Sistine Chapel.
My Bikes
My Bikes
Edumacator
Quoted: 2544 Post(s)
Liked 3,369 Times
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
