Is this stem ruined?
Commuting Fool
Bikes: 1988 Miele Azsora, 2022 State All-Road 4130, 2003 Jamis Coda Comp, 1983 Specialized Expedition, 1994 Norco Monterey
Quoted: 104 Post(s)
Liked 72 Times
Here is another issue that is concerning. There is a spot on the top of the stem that I polished back a bit with some compound. When I run my finger across it, it feels like a flat spot. The question is… did he clamp it to close the clamping area? I don’t see marks on the other side, but who knows. Could be something fell on it and put a dent in it resulting in a slight flat spot.
Quoted: 3596 Post(s)
Liked 3,016 Times
I don't think any amount of assurances or hand-holding are going to assuage your fears here. Just buy a new stem and forget about it.
Likes For smd4:
Commuting Fool
Quoted: 104 Post(s)
Liked 72 Times
😂… probably right. It’s the kind of part I don’t want to gamble with, but it sure looks nice to me… that’s where the conflict comes in I guess. All of the Nitto stuff looks nice to me, I’m sure I’ll have no problem finding a replacement.
Quoted: 409 Post(s)
Liked 431 Times
It's a stem.
To ask the question is to answer it. Otherwise, someday you're going to going to be leaning into a hard downhill corner, after a long straightaway, with your tears running into your ears, and one of the voices in your head will say, "you know, if that stem broke right now, you'd totally die. Just sayin'..." And that voice will be right. And you'll never be able to shut it up.
Take no chances with the front end.
--Shannon
--Shannon
Likes For ShannonM:
Bikes: 1972 Motobecane Grand Record, 2022 Kona Dew+
Quoted: 167 Post(s)
Liked 152 Times
Likes For spclark:
Bikes: Handsome xoxo, Serotta atx, Canyon Endurace CF8
Quoted: 906 Post(s)
Liked 1,949 Times
probably just where the cables were rubbing..mine has a small wear mark from where the cables rubbed.
Liked 3,016 Times
Likes For smd4:
Quoted: 5899 Post(s)
Liked 2,765 Times
It simply boils down to decision about your own obsessiveness, and how much you're willing to spend because of it.
If you're bugged, buy a new one and be happy, but don't lie to yourself that's a safety based decision.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
Good question.
He claims that the LBS swapped the bars and set it up with the thumb shifters and all, but judging from the stem situation I would say that is questionable at best. The cables do look very fresh, so it had to be done fairly recently. He was moving to Italy and decided it wasn’t worth bringing bikes with him, can’t blame him. He was likely in his 70’s, according to him he hadn’t ridden the bike much since they swapped everything over.
He claimed thousands of miles logged on it in his younger days and the bike had the drops on for most of its life.
Likes For dedhed:
SE Wis
Liked 3,412 Times
Likes For dedhed:
Liked 3,016 Times
The clamping bolt (as well as the wedge/cone bolt) is hidden inside the stem. You can see the clamping wedge just inside the stem itself.
It’s an elegant stem from a more civilized time.
Likes For smd4:
Quoted: 1135 Post(s)
Liked 1,234 Times
I agree, having owned both, they were indistinguishable to my eyes, except for the logos. The Dynamic is a beautiful stem and readily available stem usually for $50-70 new. Probably also able to fine a Specialized on Ebay. I sold one there a couple of years ago.
Quoted: 984 Post(s)
Liked 589 Times
jsallen
Ouch! Prudence dictates, replace it! The aluminum has probably been taken beyond its elastic limit. and you would have to bend it again to get a standard 1" diameter handlebar in. Stems are not expensive. Face plants are.
Likes For jsallen:
Liked 3,016 Times
Quoted: 409 Post(s)
Liked 431 Times
While there may be, and even probably is, nothing wrong with it, there is something wrong with me:
Fear.
I have crashed, exactly once, due to a stem failure. Checking out a buddy's newly built BMX bike. He'd forgotten to tighten the stem all the way. So, as I was honking up a hill, the stem pulled out of the fork. The crash was so fast and so violent that I literally didn't know that I'd crashed. Like, "Why is everything sideways??... Owww... Why do I hurt?" Had it happened at any kind of speed, I'd have been seriously injured, if not killed.
Nobody who has experienced a stem / fork / front end failure will risk anything that might create a repeat. Having doubts about your stem does not conduce to pleasant, enjoyable, carefree bicycling.
--Shannon
Fear.
--Shannon
Likes For ShannonM:
I agree with FBinNY. The stem isn't going to break.
But I'd also like to add two thoughts.
One, thanks for posting the hidden-bolt Dura-Ace stem. Those are great. I remember finding one on a SLX tubed bike I owned for a little while. Super cool.
Two, for those who act as if a broken stem results in death/automatic catastrophe, I'd like to offer a few counterexamples. I've had two Thomson stems with face plates that cracked. Neither failed while I was riding. I just approached the bike and said, 'oh, whoa, that stem plate is cracked.' So it failed at some point, but didn't let go of the handlebars. Second, I had a bike shop return a mountain bike to me after servicing the fork, and they forgot to tighten the bolts around the steer tube. I rode off, with the handlebars suddenly offering no control over the front wheel, but it didn't matter -- it was similar to riding no handed. I just coasted for a bit, then gently applied the brake. A bike with a broken stem will still balance and offer the usual gyroscopic steering. It may lead to a devastating crash, but it sure doesn't have to.
Liked 2,765 Times
There's a very fundamental difference between mechanical failure and mechanic failure.
IMO this stem is safe and virtually immune to mechanical failure, however nothing can protect it or you from mechanic failure.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
