I need help setting up a car horn for my bike.
Quoted: 4343 Post(s)
Liked 1,413 Times
A loud horn is only noticed after they've done something to warrant getting a horn blasted at them; also, the likelihood of you honking a horn instead of, or while, avoiding whatever bad driving is happening to you, is small.
Finally, how do you feel when someone honks their horn at you? Does it make you happy, or angry? A loud horn is more likely to escalate tension, than to alleviate it.
For a cyclist, a loud horn might make you feel better. But it won't save you in an accident, and it's extremely unlikely to change a bad driver's behavior, or prevent an accident.
On the other hand... a camera, if seen in advance, is likely to change a driver's behavior. If not seen in advance, at least then you have evidence of their bad behavior.
A camera is pretty-much useless for preventing collisions. If drivers don't notice the cyclist, they certainly won't notice a camera.
Liked 1,413 Times
The distance between the horn mounted at the front (a better location) and the button is so short that going wireless adds complication for a minor benefit.
An air compressor, to substitute air for steam , allows a guy in town here to have horns off big ship's stacks,
on his camper shell of his pickup-truck..
Screaming Banshee Motorcycle Horn System Version 4
The next level after Loud Bicycle Loud Classic and Loud Mini is this very compact motorcycle air pressure horn (Screaming Banshee Motorcycle Horn System Version 4).
The ad text already sounds promising: "The Screaming Banshee Shockwave is the loudest and best engineered motorcycle horn you can buy". +130dB for $120:
https://screaming-banshee.com/products/banshee-horn
Quoted: 523 Post(s)
Liked 233 Times
It should be relatively simple and cheap to buy an aftermarket horn meant for a motorcycle and power it using a 12v lithium ion battery pack or even a home built one using four li-ion 18650 batteries. If you order one from China they are as cheap as less than $3 for a 110 decibel, 12V DC, 1.5A horn. All you would need is wire, a momentary contact switch, and a battery to complete the package.
HOWEVER before you do this you might want to think twice because you might be damaging your hearing at the same time. It only takes a short exposure to 100+ decibels to begin the process of destroying your hearing. If you were to mount the horn behind you on the bike, it would be even worse. You are never going to be more than a short distance from the horn no matter where you mount it.
"What Counts as Excessive Noise? Frightening fact: Hearing loss can occur after a one-time noise exposure at 120 decibels, such as gunfire, or continuous noise exposure to dangerous levels of 85 decibels or above over a prolonged period of time. (copied from the Huffington Post article on 10 Common Noises That Can Cause Permanent Hearing Loss) I know from experience having ridden a motorcycle for many years and only started using hearing protection when it was too late.
I tried the Airzounds horn (bought two of them) but abandoned using it because the mounting system is pure crap for a device that costs more than $30. I still have it on an older trike that I no longer ride but had to cobble the mounting with a length of cut up bike tube to keep it from falling off. These days I use an electronic bike horn. Slightly less loud compared to the Airzounds but far cheaper and the mounting is far better. The batteries last more than a year and I don't need to fuss with pumping it up.
You're right, but it's not conveniant for tandems and kid bikes ![Big Grin](https://www.bikeforums.net/images/smilies/biggrin.gif)
So if 113dB are not enough, 120dB could fill the gap:
SoundBomb Horns - DENALI Motorcycle Electronics
I don't think a car horn is loud enough. You need a horn from a locomotive.
https://www.youtube.com/watch?v=_9nonCqesLI
One good blast and a bright light would see another guinness world record broken.
![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
I have this 6-12V horn on my bike. The reason I use this particular one is that all my power on the bike runs off 6V and I found that I could not drive horns with nominal 12V voltage at 6V. The particular one I chose can be actually driven even at 5V USB.
The horn does wonders in the streets in alerting drivers to my presence and negotiating the right of the way. The sound is that of a car alarm and the horn toggles over 6 versions or so of these. In the past I banged the cars and yelled. Now I just push the button and wait. Usually I do not need to wait until the second version of the sound.
The only negative I can think of is the lack of any coating on the PCB inside. After a year of riding with the horn and some very heavy rains, the sounds became muffled and erratic. I took the PCB out and coated it and all is good.
Cycleway town
I have a 17in air horn. I recon it'd go along the top tube without getting in the way. I'm just not sure how to power it. I could use pump and battery but the battery would be heavy. I could use a compressed air can. Or i could use a bike pump - it'd take one second to draw and compress, and that'd be enough of a toot.
Cycleway town
![](https://i.imgur.com/F18HvoB.jpg)
It is neat looking that is for sure.
Too bad it doesn't fit over the front fender.
It would look even cooler.![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
Good luck with your project.
Cycleway town
Shorter ones are available, that'd fit on the fender, but I think I'm gonna go for a conventional car horn if i can find one under 60w.
Well I've got a 48v-12v converter in the post so I'll have endless 12v power for it. It's for the front lamp and only 60w though, so i don't know if it'd power a suitable compressor.
The more recent the model of car,the more likely it is going to be low wattage.
If you don't mind going used a used car parts place or scrapyard will be able
to help you out. A car horn wouldn't go for much as it is rare someone would need one.
Cycleway town
With the caveat that under the hood car horns are not going to be pretty.
I'd like one like this. I could probably find a cover, or make one, for a conventional single-tone open plate. But as you say, these are likely to use a bit more juice - i've seen figures of over 70 watts for this type, but i don't know if that's each, or the 6v version, or...
![](https://dmt-onlineshop.de/images/product_images/popup_images/genuine-bosch-horn-vintage-new-rare-mercedes-benz-w108-w1-2324-0.jpg)
I've got quite a few from my car projects, and i'd wanna use the lower tone one from a pair (and tweak it to just the right note). But those ones are snail-shell style.
You know I bet that would fit underneath the seat.
It would be out of the rain,inconspicuous and
as long as the vibration doesn't cause impotence
You know all you would need is a switch,mercury switch,relay and
it would serve double duty as a crude bike alarm.
aka Phil Jungels
A friend of mine has real train horns on his motorcycle.
BIG and HEAVY!
When he hits the horn button, it really gets exciting!
BIG and HEAVY!
Señior Member
Bikes: Windsor Fens, Giant Seek 0 (2014, Alfine 8 + discs)
Quoted: 446 Post(s)
Liked 8 Times
One thing that I discovered when hooking up a car horn in a stage prop - car horns are ridiculously electrically noisy. They are basically spark gap transmitters and they shove a huge amount of hash back up the power lines. I measured about 80 volts of noise getting crammed back up the 12V lline when I put my scope on it.
If you just have a separate battery for it and use a switch or relay, you'll probably be fine. You should at least put a diode in parallel with it to clamp the flyback voltage, even with a relay, to keep from frying the relay contacts. But if you use a battery that's also used with electronics, I'd be very careful about the noise, perhaps put the horn or the electronics behind a noise filter.
Work: the 8 hours that separates bike rides.
Quoted: 4560 Post(s)
Liked 2,806 Times
Why settle for a mere car or train horn when you can get the Brown Noise?
https://www.youtube.com/watch?v=M9mB0OGWkYE
Dermbrian
18
02-03-14 01:27 PM
