The pizza cutter strikes again
I must say that while pedaling along I have looked down at the front wheel, thinking to myself that the brake rotor does remind me of a dremmel cutting tool. Thought a number of times if I were to come in contact with someone with my rotor tne results would not be good. True there are a number of dangerous parts on the bike, the rotor is extra scary.
Quoted: 18883 Post(s)
Liked 10,646 Times
I didn't realize how dangerous wheels with spokes are, I'm going full disc to play it safe. Having trouble finding a front one, might have to go with a faring.
Likes For Seattle Forrest:
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
''Questions safety of disc brakes''
I think there are a lot more people crashing because they lost their braking power due rim brake failures or inefficiency than people getting their ears cut by discs during a crash.
Likes For eduskator:
The biggest hazard of rim brakes is the tire or rim or both exploding during long descents in the warmer seasons. Apparently, the current solution to that problem (other than upgrading to disc brake) is minimize braking during long descents. A practice that can be quite problematic for many reasons especially when riding public roads
Bikes: Shmikes
Quoted: 10239 Post(s)
Liked 5,962 Times
Quoted: 8445 Post(s)
Liked 9,400 Times
Mine isn't too bad. I can hardly see it anymore since I now have that old man skin. I have a worse one on my right leg from slipping off the kickstarter on my motorcycle when I tried to start it in work shoes.
Likes For big john:
“Both crashes were pretty minor except the fact that I landed on a hot rotor,” Mannion told CyclingTips. “For one, I needed eight stitches in the front of my knee, and for the other, I needed 12 staples in my hip. The cuts were so clean it was almost like the rotor burned through it.”
Likes For popeye:
Quoted: 10318 Post(s)
Liked 5,298 Times
Bikes should have both rim and disc brakes at the same time. Ultimate stopping power plus redundancy. What could go wrong.
Quoted: 4281 Post(s)
Liked 3,007 Times
Liked 595 Times
True, the injury potential for losing brakes is far higher than getting into contact with hot, spinning disc rotors.
Hot air = increase in pressure = assploding tires!
Quoted: 4077 Post(s)
Liked 7,666 Times
Originally Posted by MoAlpha
One of the more memorable cycling injuries I've seen was what a chainring did to someone's calf in a Wednesday night crit crash.
!!!WARNING!!!! Not for the squeamish, but a chain ring incident suffered by someone I used to ride with:
======> DO NOT CLICK ON THIS LINK IF SERIOUS WOUNDS UPSET YOU <=======
Did you read the above warning??
https://4.bp.blogspot.com/-H45qNo6GC...0/IMG_2742.JPG
Quoted: 9685 Post(s)
Liked 6,421 Times
This sport is dangerous! Lot's of equipment designed to maim and injure people. I think I'll go back to couch surfing.
Liked 9,400 Times
I tried those peel and stick patches at one time and had one blow off on a steep descent when it got too hot.
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,556 Times
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
The EWS lately did a study about what kind of injuries riders were getting and how severe (in terms of days to recovery). Does road cycling have any similar stats?
Genesis 49:16-17
Genesis 49:16-17
And then, the heavier the rider, the higher the tire pressure, the higher chance of blowing out the rim when dragging the brakes in long, hot weather descents. Fortunately, many blowouts seem to happen at the rear wheel which is less dangerous than the front but still very dangerous especially if it happened 40mph downhill.
This is why you hear the advice very often, "do not drag your brakes in long descents". But it doesn't always work for everyone for many reasons and the disc brake is a most welcome tech for that.
Quoted: 3261 Post(s)
Liked 2,583 Times
This thing only weighs 12lbs. Plenty heavy enough to inflict major damage if swung as a weapon. Especially if you're a biscuits and mustard type of person. (that wasn't a rotor, though) Imagine how much damage it or something similar with a thinner blade profile could do attached to a 150lb projectile traveling 20+ mph. That's a lot of ballast with lots of force behind it. It's entirely possible. Not likely, but possible. I still think the chainrings would do more slicing damage. Blunt force, most anything attached to the bike will pack a punch.
Likes For Reflector Guy:
Advanced Slacker
Liked 2,556 Times
Chainrings are FAR more dangerous than discs. The danger could easily be mitigated to near zero with a dead simple and extremely light ring guard (like a bash ring).
I find it amusing that anyone frets over discs while they don’t think twice about the easily solvable issue with chainrings.
To be real, I don’t think either is worth losing sleep over, but to worry about discs before rings is just asinine.
Quoted: 630 Post(s)
Liked 406 Times
Why can't this be tested and put to rest? You could take a dead pig's limb, spin a bike wheel on a stand up to speed, stick limb up to disk and see what happens. Then have barbecue pig limb later. Where's Mythbusters when you need them?
Quoted: 20810 Post(s)
Liked 9,456 Times
Liked 2,583 Times
Yeah, it's all about the impact force, and that rotational speed is a bit of a red herring, but I think that this overstates it. The force behind it isn't going to be the full weight of the bike and rider - we're meat sacks loosely attached to the bike at best. Yeah, discs can cause damage in pileup but, as you say, that's the nature of high-speed collisions and I think it's silly how much they're demonized (by some), relatively speaking.
You also have a wheel there that will probably hit whatever first. I don't see a direct hit head on from the rotor happening.
Likes For seypat:
Disco Infiltrator
Liked 2,116 Times
Rotational speed and how fast it's spinning is absolutely a red herring. When I put my finger on the disk above I was in no danger because it's not really very sharp but if I fell on it, it could cut something. The cheap Tektro rotor isn't that impressively finished, the edges are not rounded at all. The situation is more akin to a hatchet. That's a lot scarier, they should go with that. But in cycling, calling something a hatchet is reserved for saddles, for some reason.
Somehow no one in motorcycle racing or mountain biking ever has this problem.
Genesis 49:16-17
Genesis 49:16-17
Bikes: '23 Devinci Hatchet Carbon Apex1 '19 Norco Bigfoot 6.1 ,'12 Motobecane Turino (killed by dog crash), '12 Trek 3700 Disc
Quoted: 149 Post(s)
Liked 128 Times
Airbags are obviously required. And seat belts to make sure you're positioned properly for the airbags to have maximum safety effect.
