Order of easy upgrades that get a smoother ride?
Clark W. Griswold
Quoted: 4448 Post(s)
Liked 4,107 Times
Yes but it doesn't go up and down but down and back so it doesn't harm the knees like a pogo post would do. It is isn't perfect but I can say it is comfortable and I really don't notice it under me which is a good thing.
Quoted: 6321 Post(s)
Liked 4,911 Times
Your position on the bike might help too. I find that with the more aero position I've been using that it is easier to un-weight my butt from the saddle as I go over bumps. When I'm sitting more upright, it's a little more difficult to get the weight off the saddle.
I'm not standing up, it's more like I just hover over the saddle slightly with out the effort needed to stand up.
But good tires, which your GP5000's are should go a long way already. So maybe you are just too picky or perhaps need to get a fat tire bike and resolve yourself to a very comfortable but very lackluster for personal performance stat's riding.
https://www.giant-bicycles.com/us/yu...ngfattirebikes
Quoted: 51 Post(s)
Liked 6 Times
I have an aluminum 2017 Tiagra Domane with the rear ISO speed coupling and a carbon fork, running 28c Conti 5000 tires. It's a fine ride, though I'd like to make things a bit smoother for some rough pavement patches in my ride. I only ride this bike on the road, so we're not talking gravel-level comfort.
Wondering about ease and cost of upgrades that could help:
- Seat post - current seat post is round aluminum. Would an upgrade to CF help a lot? Clearly this is the easiest one
- Handlebars - like the seat post, the handlebars are alloy. Would an upgrade to CF help a lot? This would be a bit harder, but I don't mind a project and I've not worked on bikes much before, so this could be fun. This is a non-integrated handlebar with mechanical shifting and rim brakes, so might be the easiest handlebar change? And what about the stem? That's alloy too. Any reason to go CF on the stem?
- Tires - I changed out from the stock 32c Hard Case lite tires to 28c Conti 5000 on the suggestion of my LBS. I gained a +1MPH average, which was greater and the handling improved, too! But, this didn't help the ride. What if I went with a good 28 tubeless? Rims are TLR. Or should I just go back to 32, but a better 32 than the OEM? But with an internal width of 17, I wonder that 32 would impact the current handling.
- Wheels - running the OEM Bontrager wheels (622-17), which are alloy and weigh about 1690g. Would CF wheels help a lot here? I'm a little hesitant to invest in CF wheels for this rim brake bike, though. So unless I would get amazing gains here, I am wondering if I can avoid this and just do the top 3?
1) Reasonable tire pressure for your weight (Search for “Berto Tire Pressure Chart”)
2) Bigger tires (Try Conti 32’s)
3) Latex tubes
4) Thicker bar tape
Sock Puppet
Bikes: 2014 Cannondale Synapse Carbon, 2017 Jamis Renegade Exploit and too many others to mention.
Quoted: 1031 Post(s)
Liked 863 Times
