What Causes This Type Of Damage?
blahblahblah chrome moly
Quoted: 1231 Post(s)
Liked 2,752 Times
True, they make a perfectly fine replacement for a small enough frame where the bottom of the threads happens to end up in the right place. But on the biggest frame they fit, the quill is definitely going to be tightening on the threaded part. (And the bigger rider on that bigger frame is probably heavier, stresses bike parts more.).
Imagine you're JRA when the whole stem/bars are suddenly no longer attached by anything but the brake cables. It breaks free with the top of the steerer, headset screwed race and top nut still attached. It'll probably happen when you're hitting the brakes hard on a downhill, so your weight is shifted forward, and there ain't no recovering from that. you're goin' down. If it snaps from hitting a big pot hole then at least you have some chance of riding it to a stop. Luckily the brakes still work, but the bike won't steer great with no upper headset anymore, broken end of the steerer rubbing on the inside of the head tube and flopping around <shiver>.
George Hincapie crashed when his steerer broke near the top, and he was a very experienced pro at the time. Most amateurs will be toast.
"OK we get it Mark, it's bad — enough already!"
![Beating a DeadHorse](https://www.bikeforums.net/images/smilies/deadhorse3.gif)
Mark B
Likes For bulgie:
Bikes: 80s Alan Super Record, 79' Somec Special, 90s Rossin(?) Columbus Ego Triathlon, previously: Bianchi SBX Reparto Corse (stolen) and so on...
Quoted: 392 Post(s)
Liked 813 Times
Too bad you are in the states, I could give you a strong(er) period correct Gitane fork (although in peacock blue) from a tandem with intact filing where only the steerer is not like a spaghetti. Must have been hit by a CAT mining machine.
Quoted: 767 Post(s)
Liked 1,898 Times
The immortal words of the BF resident Gitane expert, one Wolfram Verktyg, instantly came to mind as I saw the graphic details - Ham-fisted Hammersmith.
Quoted: 3471 Post(s)
Liked 2,846 Times
Maybe. But that expander/wedge should be below those threads, not completely above where they start. That silly minimum insertion line is there for that reason. Also, the bottom of the stem being there means it is too high, so a larger than intended maximum bending force (that would push back on the stem bottom when you press down on the bars hitting say a pothole). And that greater than intended bending force is resisted by a shorter lever. The force at the bottom of the stem resisting bending is in proportion to the inverse of the lever length. Say this stem was only inserted 2/3s of the way to to the min insertion line. Well, that's 1 1/2 X the bigger than designed for bending force applied at the weakest part of the steerer.
If that crack is not at the back of the steerer (your picture doesn't give any clues), I'll put on my dunce cap and go sit in the corner.
the extra threads below what the headset could use is not helping, but might well have made one fork fit multiple frame sizes.
way back it was a mechanic's judgement to prevent this or a stem failure. 55mm was the amount I typically made sure was min insertion.
on this fork 55 mm would just be beyond the threads.
assigned risk
Quoted: 2588 Post(s)
Liked 4,829 Times
Those forks sold as replacements often had a ridiculous number of threads, trying to fit all frame sizes with one fork. Those sellers should be hung up by their thumbs!
Mark B
Thankfully, I've had the opportunity to put eyeballs on the fork steerer tubes of every bike I own and operate. They all look good, so I've peace of mind in that regard. Overcompensating, yee-hawin' man-boys in lifted trucks, on the other hand, will likely be the death of me if I stay in AZ much longer!
Seriously, I hate those guys.
DD
Likes For Drillium Dude:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,452 Times
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/480x640/img_5333_81080c9d9319f0c5aecdb0e78c7908e1009bff07.jpg)
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/640x480/img_5334_078fa8cea5489200c3948d0045c33f40c30043c9.jpg)
Likes For thumpism:
Liked 2,752 Times
At the max size, with all those threads intact, well let's just say you don't need to worry about your Death Stem, the steerer will kill you before the stem can.
OK I'm deliberately over-stating the likelihood of it breaking. Not all do, but the stakes are very high when one does.
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 125 Post(s)
Liked 265 Times
As others have pointed out, the split is from the stem being installed with too little insertion. French steerers are thinner than BSC or Italian by 0.1 mm which doesn't sound like much, but it's already a thin, threaded part. Most of the French forks I have seen only have the flat near the top, but they seemed to have gotten carried away at the Gitane factory that day. Still, it would not have been a problem if the stem had been correctly installed. Practically speaking, this is not a highly stressed area under normal use, as the stem provides significant reinforcement. I would not do this for a customer, but if it were mine I would insert a French stem, tap the bulge out with a hammer, put it together with the stem inserted properly, and ride it without any fear. Even in the unlikely event that a crack would propagate around the thread, which I believe is highly unlikely, a failure would not cause the loss of control one would get should the steerer separate below the stem. Replacing a steerer takes a lot of heat, or a mill and some expensive time. It is not a trivial task.
Quoted: 4895 Post(s)
Liked 4,067 Times
Those are very high quality forks, would be awesome for whatever frame size results in all but about 20 mm of threads cut off!
www.theheadbadge.com
Quoted: 2451 Post(s)
Liked 4,497 Times
OK, I will drop it now!
Mark B
Mark B
![](https://cimg9.ibsrv.net/gimg/bikeforums.net-vbulletin/413x889/fork_split_8e29b369828bb10c93ee8933015853e708856977.jpg)
Those overthreaded "replacement" forks are worthy of being on the top five list for irresponsible parts sold on the bike aftermarket today.
At this point, if I have to replace a fork with a long enough steerer tube, I'll just get the threadless equivalent, slice it to length, and cut the appropriate amount of threads into it.
-Kurt
Likes For cudak888:
Liked 2,752 Times
Mark, I wish this could be shouted at every aftermarket bike parts importer on this earth.
-Kurt
-Kurt
Likes For bulgie:
Liked 4,497 Times
-Kurt
Quoted: 644 Post(s)
Liked 1,347 Times
This had me concerned as I'm replacing a fork with one very similar to this with about as much threading. Prior to reading this thread it's not something I had given any thought to as the steerer is not slotted and I was under the misguided thinking that positioning the wedge in the slotted portion was the only issue. I'll be trimming some off the OAL but not that much. Then I remembered the threadless stem adapter I was using goes half way down the steerer tube where I have it set so even with the excessive threading the wedge will be well below the threads. It's one of those extra long ones that was on another bike I took in trade and they were using it to raise the handlebars.
Liked 2,752 Times
Old fart
Quoted: 3620 Post(s)
Liked 3,460 Times
If they're going to cut that much thread, do us all a favor and forgo the keyway/flat for the anti-rotation washer. It's not strictly necessary if you use two wrenches when adjusting the headset, and would eliminate the weak spot where these splits occur.
Likes For JohnDThompson:
Liked 4,497 Times
Not so sure I trust a wedge on threads either.
-Kurt
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
What?? Wait!! What is that? I'm agreeing with @panzerwagen that this split is from the stem expander, however, it looks like there are no threads in just that area but are around the rest of the steerer tube. That area also looks to be painted rather than bare metal.
Was this section of the steerer tube indented, which would be why it didn't get threaded and then got painted? Then being indented, cracked when the stem expander was tightened?
Can we get a few more pictures from different angles. This sure is odd.
