1989 Koga Miyata Randonneur Extra
Bikes: Raleigh Competition GS, Freschi Supreme, Miyata 1000, Trek 520, Marin Pine Mountain, Specialized RockCombo, Soma Smoothie, Surly Cross-Check
Quoted: 99 Post(s)
Liked 269 Times
And in rando mode, middle of a 300k after being chased by 3 different packs of dogs down the road to this old mission. Rack is a Nitto M18 supported by Rene Herse 170mm cantilever post mount struts. Had to work on the struts and rack tang a bit, and use double ended bolts on the brakes, but’s it works really well.
Coronavirus has effectively killed randonneuring and touring for awhile, so I stitched up some new portage, a mini zipper front bag and a tool roll, for closer-to-home adventures.
Likes For fliplap:
Quoted: 838 Post(s)
Liked 1,082 Times
An update on what this bike looks like these days. Currently setup for "comfortably light" touring. Paselas, VO faceted fenders, triple bottle cages. I'm really happy with it as a general rider, and as a tourer. Here it is on a November overnight out at McDowell Mountain northeast of Phoenix. I alos took it on a few day tour in Colorado a couple months ago.
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times
I don't often see threads about Koga-Miyatas, so here's my '92 Exerciser.
Although it's on the lower end of their lineup, it's still a really nice-riding bike.
Overdoing projects
Quoted: 786 Post(s)
Liked 1,269 Times
Come and post it over there.
Likes For Scottybigs:
Bikes: '83 Viner Special Professional, '91 Pinarello Asolo 'spumoni', '93 Trek 930, '94 Giant Cadex CFR3, '97 Giant Atlanta MTB, '99 B1 Weblite Cross , '16 Cube Peloton Race.
Quoted: 92 Post(s)
Liked 376 Times
Here's my 1990 World Traveller. Nearly full Shimano Deore DX group and Wolber rims. I'm still working on the finetuning, as I just got her.
Likes For LucasHartong:
I've wanted to try out an ultra-wide double for randonneuring. I've had this NOS 175mm Sugino PX sitting in the parts box for a bit so I tossed it on with 46 & 28T Sugino chainrings. I'm surprised how well it handles the 18T jump between chainrings. While I was at it, I moved to a 10sp rear by switching out one of the bar ends and the rear cassette
Likes For fliplap:
Quoted: 838 Post(s)
Liked 1,082 Times
I've wanted to try out an ultra-wide double for randonneuring. I've had this NOS 175mm Sugino PX sitting in the parts box for a bit so I tossed it on the Koga Miyata with 46 & 28T Sugino chainrings. I also switched out the right bar end and cassette for a 11-32 10 speed.
Likes For polymorphself:
Overdoing projects
Quoted: 786 Post(s)
Liked 1,269 Times
I want to try the Pro-5-Vis cranks with an 43/26 in the front (17T difference) with an 11-speed in the rear. The chain should fit but there is a risk of it falling in between the chainrings. Some modificitations should make that possible though. But everything up to 10-speed chain should be fine.
P.s. Which reminds me, and you've probably seen them already but, I recently made high-res scans of the 1989 Koga-Miyata Brochure and technical specifications brochure which includes this bike.
Likes For JaccoW:
This bike lives in full touring guise now, I ditched the flexy 50.4 Sugino PX and narrow spaced 10s and went back to the 46-36-24 triple paired to a wide, 11-34, 9s. I also picked up a lightly loved 36h SON28 and built a dynamo wheel for it. I haven't had time to wire a tail light, but I did get the headlight and USB charger done for a recent tour. I'll knock out a post about that later
While the frame has internal routing, the fork isn't designed for a hub dynamo as the bike shipped with a bottom bracket generator. However, for whatever reason, the fork blades have vent holes both at the drop out, and at the crown. With appropriately thin wire I was able to snake 2 leads through the fork.
Here you can see where the wire enters the fork blade. I designed and 3D printed a quick release connector similar to the one used for Shimano hubs, though it's hard to see in this photo. Since newer SON hubs can run in either direction, and the rack's light mount is on the right, I chose to utilize the non-drive-side fork leg. The wiring I used is 22awg "Tefzel" (aka ETFE) wire. This stuff rocks for running through tight spaces as it has a thin, tough, non-stick jacket that won't snag or hang up. Still getting 2 wires through 2 tiny vent holes wasn't easy.
Getting the wire through the fork blade was a multi step process
First I used a length of cleanly cut 4mm shift cable with a 1cm, 90deg kink put in each end. The 90deg kink was key. The cable was inserted at the dropout end and pushed it up the fork blade until I could just see the tip of it glinting off a flashlight pointed into the crown end vent hole. I then twisted the drop out end of the cable, which caused the 90deg kink inside the fork blade to wind up and spin. After a dozen spins or so, the 90deg hook caught in the vent hole and I pulled it through with needle nose pliers
Because the vent holes are so small, the usual method of tying or shrink wrapping the wire to the cable wouldn't work.
Instead I tied a doubled length of strong dental floss to the other kinked cable end and carefully pulled it through. I used a doubled piece so I'd have a backup strand if the first one broke. I tied the floss to a doubled length of wire, and slowly brought it to the top. Here you can see the wire exiting the top of the fork blade, and both going into, and coming out of, the fender.
The end entering the fender, exits at the front and connects to an Edelux II with 2mm banana connectors embedded in a custom 3D printed connector.
The wires routed above the fender and under the fork crown terminates at another copy of that connector that allows a Sinewave Revolution USB charger stored in the rando bag to be quickly disconnected and moved to another bike.
Likes For fliplap:
Quoted: 838 Post(s)
Liked 1,082 Times
Looks perfect. Short tour planned? What size tires does it take with fenders? Up to 35’s I’d guess?
Any specific reason for moving to that rack to accommodate lower riders rather than keeping the rondo rack you had and adding a separate low rider rack?
Was the change back to a triple for the more heavily loaded rides you’re planning? The double wasnt going to cut it or you just didn’t like the feel?
Next time you’re around downtown shoot me a DM so I can see this thing in person!
I went back to these racks because they’re the factory racks, are perfectly fit to the bike, and I like the light mounts. While Blackburn style low riders don’t have a great reputation, the Koga Miyata interpretation is much sturdier, with thicker tubing and extra reinforcements.
The change back to this triple was partially about gearing, but I do have the parts to setup a 50.4 triple. The larger reason for going back to the factory crank was that the Sugino PX, paired with those Sugino rings, was miserably flexy and I didn’t enjoy riding it.
I’d ping you next time I was in downtown PHX, but I actually moved to Colorado earlier this year, so I’m unlikely to find myself there for coffee anytime soon 😉
Likes For fliplap:
As somewhat expected, the original aluminum low rider rack eventually cracked. I replaced the front with a Nitto Campee and moved the M-18 to the rear for a small trunk bag. Here's the (rather dirty) bike on a recent Katy Trail out-and-back tour.
Likes For fliplap:
Quoted: 838 Post(s)
Liked 1,082 Times
Still loving this bike and still obsessed with the bags.
This was probably touched on up thread somewhere- but geometry wise I’m guessing this bike actually lives up to the randonneur name and handles very well if not better with a front load?
EDIT: Went back and looked, you said even the geo is spot on for an M1000.
Quoted: 2333 Post(s)
Liked 2,097 Times
Could have been owned by a military member but could have been owned by an American working locally. I lived and worked in Erlangen then and actually had a bike stolen in front of that exact shop. I owned a Miyata 912 and toured on it, pretty good bike. I wish I had either your model or the Specialized Expedition. Anyway, very nice bike you have there.
Bikes: '72 Raleigh Super Course; '90 Cannondale ST1000; '98/99 Cannondale T700; 2002 Cannondale CAAD5 R700; 2022 Cannondale Topstone 2L
Quoted: 169 Post(s)
Liked 354 Times
I looked through the thread and couldn't find any info, so excuse me if it's already been answered: What are the bags used in the 7/17 post as well as today's?
Quoted: 838 Post(s)
Liked 1,082 Times
I’m almost positive they are all custom made by the OP. I asked in another thread some time back if he was taking orders but he wasn’t .
As noted in the above post, sewing is a hobby of mine and I have a (bad?) habit of making new bags somewhat seasonally.
The green panniers were nice for short trips, but I've wanted to carry more stuff for a more “luxurious” bike camping experience. When the original rack failed, it made for a good excuse to plan an easy tour, and make some new, spacious, front panniers. On this trip I carried all the usual suspects, but also had room for a chair, hammock, and plenty of headroom for food and beer. The panniers hold ~20L each, which is still a bit smaller than the 25L of Gilles Berthoud or Waxwing’s camping panniers.
As to if the bike was is most suited for a front load: Maybe? It doesn't seem to suffer from being heavily front loaded. I've observed considerable shimmy with too much rear load and speeds above 30mph or so. I’ve had the big panniers above 40mph without any shimmy at all.
Likes For fliplap:
Likes For Rooney:
Jedi Master
Do you need a special sewing machine to make bike bags or will a regular one do? I'm asking for my wife who has an old Viking Freesia 415 and wants to know if she can use it to make bike bags for me.
fliplap do you have a Flickr, Instagram or anything else where you showcase your sewing? Also, cool blue lug sticker.
I honestly don't know a ton about sewing machines. I've only owned a couple. Bike bags are usually made of many layers of heavy fabric, thread and binding that traditional dress making machines won't handle. While you don't need anything in particular you'll find some work to be impractical without a heavy duty walking foot setup. Anything will get you started, but it might be frustrating, and might ruin the machine.
Likes For fliplap:
