Is One Flat Pedal Really Any Better Than Another?
My other option is to buy these inserts that will "convert" the existing pedals to be flat on the SPD side. Anyone use those?
Just Pedaling
Bikes: YEP!
Quoted: 352 Post(s)
Liked 570 Times
When I consider how many miles I go per the pennies I spend, it's a cheap sport. It also has the side benefit of keeping me healthy.
Likes For SpedFast:
Quoted: 1076 Post(s)
Liked 1,333 Times
For $26 you can get a pair of Welgo pedals with pins, that would work fine, and would hold up well, and I would get them before resorting to pedals from Walmart. . https://www.amazon.com/Wellgo-Pedals...s%2C81&sr=8-31
Likes For phughes:
What are your thoughts on these? I don't have a pedal wrench so the added wrench is nice. I know it's a cheap wrench but still. Plus I think you can also tighten with a hex key.
Zacro Mountain Bike Pedals with 2 High-Speed DU Sealed Bearings, Bike Pedals of 9/16 Inch, Aluminum Bicycle Flat Pedals, Non-Slip and Durable Pedals for MTB BMX Road City Curiser Bikes with Wrench https://a.co/d/ahrWigy
Quoted: 391 Post(s)
Liked 299 Times
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1251 Post(s)
Liked 338 Times
Those pedals look good on the outside. So did the cheapo $30 version of Vsixty pedals, but they had stupidly useless 1/16" balls that can NOT be set properly.
I have been using the very good $60 Vsixty pedals with one sealed bearing and a bushing on the inner end. The play is automatic by design.
I have another 1/2" thread pair with both sides cup/cone and 11 balls 1/8" or 5/32". They will spin 6 revs easy.
IF it has needed cone adjustment, then most likely they come TIGHT and need loosening.
But in any case, the best ones have a METAL frame.
Clark W. Griswold
Quoted: 4470 Post(s)
Liked 4,133 Times
If you are just going to bottom feed just do it then and buy whatever from wherever but if you want good pedals above are 20 options for decent to excellent pedals in no particular order (but the top 4 would be favorites by happenstance)
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12914 Post(s)
Liked 7,839 Times
No allen wrench on the inside though.
Likes For LesterOfPuppets:
Seems like a pretty good value in the Chinese knockoff sort of way. The wrench is garbage, by the way. You can tighten pedals with a regular wrench, an adjustable wrench, or a multi-tool, or a hex wrench. You can even use your fingers and your pedaling should snug them up.
Quoted: 391 Post(s)
Liked 299 Times
Edit: I don't own a pedal wrench, but I've struggled with enough pedals over the years that I probably should have one.
Clark W. Griswold
Liked 4,133 Times
Get a pedal wrench and get one that is easy and comfortable to use. It will save you a lot of hassle and pain. They are not super expensive tools. The cheap-o Park Tool one is $20 and will do the job and the professional pedal wrench is only $40 and is quite nice to use (I have used both and would rather spend a little more to have the better grip and easier to use head)
Likes For veganbikes:
Quoted: 3619 Post(s)
Liked 3,045 Times
You can get a Unior pedal wrench for $7 bucks, also a pro wrench. I preferred this style over the Park with the grip.
Quoted: 1447 Post(s)
Liked 2,034 Times
Liked 3,045 Times
Liked 3,045 Times
Sure. Bottle opener is a bonus!
Clark W. Griswold
Liked 4,133 Times
I had that pedal wrench (well one purchased through an authorized distributor) traded it to a mechanic was totally fine but it was not full tang and honestly I got his nicer Pedro's wrench and some free labor so it was a no brainer. But it was a fine wrench worked well was comfortable I just want full tang baby!
Bikes: everywhere
Liked 7,839 Times
Liked 2,034 Times
not too common - but some pedals will require a hex (only) - 6mm or 8mm hex
Bikes: 1974 Masi GC, 1982 Trek 728 (aka 720), 1992 Trek Multitrack 750
Quoted: 123 Post(s)
Liked 225 Times
I have two different brand pedal wrenches.
Both were just a smidge too wide to fit on the flats.
I purchased a 15mm cone wrench and fixed that problem.
It turns out MKS does sell a special narrow pedal wrench just for these pedals.
PS Make sure to grease/anti-seize the crank and the pedal threads before installing the pedals.
Bikes: everywhere
Liked 7,839 Times
One of my favorite stupid things to do is just grab a regular 15 end wrench and try to put an unkown pedal on, cinch that pedal down and not be able to get the wrench out. Then complain about how I have to dig out the pedal wrench.
Likes For ofajen:
Deraill this!
Bikes: 18 Cdale Quick 1, 94 S-Works M2, 98 730 Multitrak, and a few others
Quoted: 150 Post(s)
Liked 457 Times
I'm a fan of Raceface Rides (Raceface Chester without the metal pins) on hybrids. They grip the sole of the shoe without tearing it up. Plus, they are available in multiple colors. Shop around and you can get them for $30-35.
ttps://www.raceface.com/products/ride-pedal?variant=31913987276882
If you want something heavier, the Shimano EF202 is a nice option. Maybe a bit less grippy than the Rides but they are solid. I've used these on my Quick for about 4 years then swapped them to the Trek Multitrack. They are also available in multiple colors.
https://www.rei.com/product/184860/s...02-flat-pedals
