Bike grease recommendations
Bike grease recommendation? Use it. Regularly, and wherever appropriate. ![Smilie](https://www.bikeforums.net/images/smilies/smile.gif)
Seriously: bicycle loads and bearing RPMs are trivial compared to what most greases are designed to withstand. Unless you ride in the Arctic, as others have said above pretty much any high-quality grease should work well enough. (If you regularly ride in extremely harsh winter conditions, you might - and that's might - need a low-temp grease formulated for those conditions during winter riding.)
Two caveats: if you regularly ride where you encounter lots of water (trails crossing streams, deep puddles), maybe consider marine grease (it's more water resistant). And don't put grease where it doesn't belong (freehub and freewheel pawls reputedly don't like thick greases).
Likes For Hondo6:
Bikes: a few that I can't recall
Quoted: 352 Post(s)
Liked 308 Times
I use Phil Wood because it makes me smell like a Bicycle. Everything makes me smell like either a Boat Trailer or a Tractor.
(not much of an exaggeration)
Quoted: 1649 Post(s)
Liked 1,875 Times
Likes For icemilkcoffee:
Quoted: 3855 Post(s)
Liked 6,980 Times
Liked 1,875 Times
Well I have a tube here that separated in less than a year. And I am in San Jose, ostensibly the same climate as Phil Wood. In fact it even says San Jose, CA on the tube of grease if I recall. You want to exchange your non-separated grease with my separated grease?
![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
Quoted: 3663 Post(s)
Liked 3,100 Times
Well I have a tube here that separated in less than a year. And I am in San Jose, ostensibly the same climate as Phil Wood. In fact it even says San Jose, CA on the tube of grease if I recall. You want to exchange your non-separated grease with my separated grease?![Stick Out Tongue](https://www.bikeforums.net/images/smilies/tongue.gif)
Maybe the modern formulation is different?
I bought a tub of waterproof marine grease in the late 1970's. It was bluish-green but has faded to mostly green but is still transparent.
I still have some but you can see the bottom of the tub.
The Phil Wood grease formulation has definitely changed. It 'stinks' more now. I suspect that sulfur has been added to or increased in the mix.
Likes For Jeff Neese:
Palmer
Quoted: 1706 Post(s)
Liked 1,900 Times
What's a good all-purpose grease for parts vs hubs and rims or can I use them interchangeably?
Eeeeeevrybody's got their own thing.
Fuchs Renolit CA-LZ (NLGI 2) for bearings: hubs, BBs, headsets pedals.
Houdini Lock Lube for caliper brake and derailleur pivots.
John Deere Cotton Picker Spindle Grease (NLGI 00) for IGH clockwork.
Don't grease your rims.
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3954 Post(s)
Liked 6,642 Times
![](https://i.imgur.com/ADi6d2G.jpg)
Likes For SurferRosa:
Liked 6,980 Times
Likes For nlerner:
señor miembro
Liked 6,642 Times
Old fart
Quoted: 3619 Post(s)
Liked 3,460 Times
Automobile wheel bearings operate at higher RPM/load/temperature than bicycle wheel bearings. It works fine in bicycle wheel bearings.
Thread derailleur
Bikes: Croll '94 & Cannondale Supersix '15
Quoted: 385 Post(s)
Liked 485 Times
Some of that tubed Phil green lube (from the 80's) kicks around my stash somewhere.
Could not find it, but found a new Dura Ace bottom bracket and chain, while looking.
For that, I owe this thread a great deal of gratitude.
Like an earlier poster said, that Rock n Roll red stuff works exceptionally well.
Always strive for slickness, not thickness.
![fred](https://www.bikeforums.net/images/smilies/fredflintstone.gif)
Quoted: 113 Post(s)
Liked 215 Times
In the early 70's I bought a copy of Eugene Sloane's Complete Book of Bicycling where he recommended Lubriplate 105, so I got a tin from an auto parts store back then.
For the longest time it's been Mobil 1.
Trying out Citgo's Mystik JT6 with 3% moly cuz it was on sale at Farm and Fleet, and Valvoline Palladium, 3% moly.
Or maybe just rendered pork fat.
Likes For streetsurfer:
Likes For P!N20:
Happy With My Bikes
Quoted: 888 Post(s)
Liked 2,359 Times
I have a freezer full of Blue and Gold bacon and sausage (it's an Oklahoma thing) and a recent diagnosis of cardiac arrhythmia. Now I know what to do with my pork investment.
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
Would you use this in the hubs and bearings as well?
Lets say on a pair of Vintage C-Record Hubs with the oil port what's the recommended grease for that application?
I was surprised nothing came up under the search but the search function for "recommended grease" brings up What did you wrench on today and other hits.
grease site:www.bikeforums.net
Quoted: 3471 Post(s)
Liked 2,845 Times
