New garage build - storage ideas
If building a garage, why not instead of try to figure out the storage in the area most likely for theft with the rollup door (and necessitating the chains) design a little room with a deadbolt door for valuables? I would imagine a 6' x 8' space with the bikes on the rack on the one wall, center walking space, then a little tool chest with table top on opposite side with a pegboard on the wall.
Then all your nice tools are also stored.
Then you can hang the bikes in there and not deal with a chain or cable every time you go ride.
Just a thought. If they have time to drill out a deadbolt on a door, they'd have time to use your own power in the garage to use a grinder on the cable or the chain.
Thanks for the suggestion!
Likes For Clarinetrox:
Quoted: 798 Post(s)
Liked 1,863 Times
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
At our old house we had something happen where we forgot a key on vacation for a house sitter. And our dog was inside the house needing food, bathroom, walks. Luckily our garage had a keypad. Garage had my tools like drill and bits. House sitter friend knew how to drill out a deadbolt to get to the house part to the dog. However, it still took him about an hour and a few drill bits to do it. So, given that..........I trust a good steel door and deadbolt!
For the shed I built, having a second steel deadbolt door on the other side was so marginal in cost to add that I spent the extra on the studs to make a little room for that door just for the "nasty" shed stuff. Fertilizer, gas can, mower, power washer, nice ladders, etc.... Stuff I don't want mingling with bike stuff. I think it was maybe $250 more for the extra steel deadbolt door, the door handle hardware, and the extra studs for the room.
I feel this was a good move. I use that stuff more rarely but still don't want it stolen. So now it doesn't cause clutter in the main area. Also, ended up being the perfect support downstairs for "structural" use of the loft upstairs in the shed. I pitched the roof super steep so I could walk in the center up there. I dreamed of insulation and a homebrew deal up there, but that hasn't materialized. I ride the bike too much instead.
Look for good discounts on cheapo flooring. I got a killer deal on fully water proof fake wood flooring, the kind you slip lock together but is rubber. So spills wipe up with no worry and sweeps easy. That would be nice in your little room for sweeping, oil spill, etc.... Unless you coat the whole concrete floor. Which is nice.
Good luck! Have fun with it!
PS: if you insulate JUST that bike store room, a little small heat/cool unit would be plenty to also make it your "pain cave".
Likes For burnthesheep:
A separate room in the garage makes the garage less flexible. And in real life you get fed up locking it all the time. You probably don't lock it the day someone breaks in.
Likes For HerrKaLeun:
Bikes: Only my riders left...
Quoted: 351 Post(s)
Liked 789 Times
Consider two levels...each level can be closed up and locked...twice as many bikes in the same area...and more horizontal surfaces...it’s a concept..
SE Wis
Quoted: 2755 Post(s)
Liked 3,427 Times
No matter how big you build it will never be "big enough", have enough outlets, enough lights, or fit all our crap. I'm at the point in life where I need a 800 SF house and 3000 SF garage.
Likes For dedhed:
Quoted: 252 Post(s)
Liked 67 Times
Best Practices and Best Solutions for Hanging Bikes in Garages
You don't need to be some special handyman, never mind genius for this. The bike slots on the pedal axle, so half inch standard plywood should be just right, that round hole is for screw bolt that goes into a stud behind the drywall. I think the distancing wedge might not even need to be a wedge but a simple block just a bit wider than the pedal. The bottom bike could for the wife as it is easy to reach...
Likes For vane171:
Liked 3,130 Times
Sounds about good for a first time buyer/builder. The next would be bigger, better, & more refined. 800SF house & 8K SF garage with 4,000 SF detached structure.
-Oh Hey!
-Oh Hey!
Likes For Troul:
Quoted: 252 Post(s)
Liked 67 Times
How about if you have ceiling high enough to hoist the bikes up by some rope/pulley system.
I once saw new house being built and they had garage ceiling maybe 18-20 feet high, plenty of room for bike hanging although I believe that was not the idea, more likely to create the luxury feeling of open space. Problem was, when the company came in to install the garage doors, they anchored those rails that the doors slide on by long metal strips anchored all the way up there, so what was empty space before looked like a spider net after
I was laughing my head off, probably the house owner didn't foresee that or the architect didn't tell him. What the garage door installers must have thought about it would probably not be fit for this forum.
Quoted: 1956 Post(s)
Liked 2,201 Times
If you put anchors flush with the concrete, you can thread in eye bolts, anchor a bike work stand, etc. I lock my bikes in a garage. It takes 2 seconds to unlock them.
The biggest problem will be allocating space for all the other things you do, and fitting a car in there.
Remote garage door openers pose a greater risk than the type of door. You can make it like Fort Knox and a burglar can just hack the code.
John
John
Quoted: 29 Post(s)
Liked 10 Times
Perhaps some photos showing how our various members have solved this problem in their own spaces. Vane's picture was indeed worth a 1000 words.
Likes For Pratt:
Two lengths of unistrut mounted to the ceiling trusses, threaded hooks (Park tools makes them, the machine threaded kind, not the screw in) some nuts & washers, I can slide the bikes closer to make more room or get to a certain bike. The pully setup on the right is for a heavy fatbike I just got and is a work in progress (both the pully system and the fatbike...). There are spring nuts on each end to keep the sliding hooks from being slid out of the unistrut track.
Likes For Alleytom:
When I had a new garage built I had the builder add eyebolts with large plates when they poured the slab. I hung the bikes using Feedback Sports Velo Hinges (so that they could pivot closer to the wall) and then used a heavy chain between the eye bolts with heavy padlocks for each frame. I live in an area where home and garage break-ins are not uncommon. I'm fully aware that the chain and locks will only slow down a persistent thief, but the peace-of-mind is worth the extra effort to lock and unlock each time I want to ride.
Feedback Sports makes a product called the Velo Hinge - every bit as functional at a more attainable price. They also make the vertical storage you proposed, and several other options for wheels and other equipment. Their stuff lasts forever and they have service parts for everything they make.
Quoted: 3341 Post(s)
Liked 2,184 Times
I tried to look among my history but I think it was a post that was not on a topic in the thread, as often happens, so hard to find. However you are in luck. I recalled I copied the picture of the setup and found it right away among my bike photos. Sometimes I save out the link where I copy pics from but not this time. Another luck is that one of the pics had date when it was copied and I did find the thread by that date and it was even squarely on the topic
Clever indeed - very similar to another commercially available product. Personally, I'd never expose my cranks to that force. It's 90-degree in the opposite direction of the designed application. I'm not saying that anything would result, but bikes are delicate....
I used a pair of sawhorse brackets to hold my six bikes vertically. Think: the racks at race courses that hold bikes by the seat except much cheaper. Mine is outside and on wheels since I need it to be moveable. I cover it with a tarp.
For reference, I’m only 5’1” as well and it’s easy enough to raise the front wheel and place it onto the hook, by leveraging the bike with my hip. The rear wheel is really only 2-3” off the ground. I made mine 6ft wide but I was also cramped for space. I lock my bikes together (it’s NYC) and they’re covered by a tarp.
Pros of this setup: inexpensive, movable, easy to build, sturdy. I’m at work but I can take pictures when I get home later if you’re interested.
Pardon the poor pictures, the tarp is a PITA to fully take on and off. I’m usually only pulling a bike or two out at a time.
I can fit six bikes, 3 on each side pretty easily. It’s basically 1ft per bike plus 1ft on the ends.
Each bike weighs 17-25lbs so it can hold a decent amount. The brackets were $8 for the pair. Used three 2x4x8. Plus screws, casters, and six hooks, the whole thing cost about $40. Plus $10 for the tarp. Thought the tarp system is a work in progress. If anybody knows of a more tent like cover . . .
The whole set up.
A closer up of the bikes hanging by the front wheels, the hooks, and the bracket.
The sawhorse bracket.
With the tarp on.
I got the idea from here: https://bermstyle.com/diy-bike-storage-rack/
The whole set up.
With the tarp on.
Likes For sdimattia:
Bikes: 2020 S-Works Roubaix, Infinity seat
Quoted: 20 Post(s)
Liked 25 Times
How about the Steadyrack's? They allows you store them vertically where they can pivot side to side and reduce the space needed and access to each bike individually and you dont have to lift them. You position them above your floor 1/2 or more. Mine sit about 3/4" off. I have six bikes in my garage this way.
1) multiple Steadyracks
2) Racedeck floorimg
3) Gladiator garage shelving
Functional, affordable and good looking
Except need flooring color orange and blue for this Illini fan :-)
I've used same combination of products in my last 2 homes. 👍
Quoted: 798 Post(s)
Liked 1,863 Times
I will never put down anything on a garage floor if I every move, except this stuff...bloody fantastic product.
Also, I opted for the tri-color Black\Grey\Yellow to mark a line to let my wife know where to pull in and stop her car. It's worked out fantastic.
Brian | 2023 Trek Domane SLR 7 AXS | 2023 Trek CheckPoint SL 7 AXS | 2016 Trek Emonda ALR | 2022 Trek FX Sport 5
Likes For jaxgtr:
