Mini Mini Mini Pump
I have this one specifically: https://www.amazon.com/Genuine-Innovations-Ultraflate-Plus-Inflater
Pretty sure I didn't pay that much for mine, though!
M.
M.
Bikes: Lola (2012 Schwinn Voyageur 7)
Any of the Lezyne pumps-- Road Drive, Pressure Drive, Drive Lite, Tech Drive, etc.-- are 2" shorter in the Medium size and nearly 4" smaller in the Small size.
I have two Medium sized Road Drives in both carbon and aluminum bodies; excellent hand pumps for 700x23 tires. One is equipped with the optional Pen Gauge hose with integrated pressure gauge, which is awesome, because it takes the guesswork out of mini pump inflating.
Of course, not knowing what you don't like about the Spin Doctor makes it impossible to say if a Lezyne will be better suited, but I've got no doubt that the Lezynes are better tools.
I'm just not a fan of the size. I'd like something smaller I can fit in a tool roll.
Thread Killer
Quoted: 3214 Post(s)
Liked 1,752 Times
Not necessarily. There are several design elements that make some mini pumps much better performing than others. I don't doubt the Road Morph moves a lot of air, but the tradeoff is that it's a big, honking pump. I'd add also quite ugly. The OP asked for small and thin, in fact, smaller and thinner than her Spin Doctor. The poor girl; in 25 posts, she's actually gotten only 3 reccos that directly answer her request!
Anyway, regarding pump efficiency, things like shaft diameter, friction, and rigidity, and material all affect efficiency, but in the end, we really have a decision to make: high volume for quick fills, or high pressure for easier filling at the top end. To illustrate, the Lezyne Pressure Drive will hit higher pressure in 1/2 the strokes it takes the longer Blackburn Airstick (https://www.cyclingactive.com/bikesge...est-mini-pumps).
A clever solution to this quandary is found in the Crank Brothers Sterling mini-pumps, which offer quick switching between high volume and high pressure modes, so the pumping effort stays low throughout the effort while maximizing volume output. The Sterling G, at 7.8", is also shorter than the Spin Doctor, though may not be quite as sleek and slender; I dunno.
Anyway, I think one-- man or woman-- can get very acceptable performance without having to go huge and bulky (which is not to knock the Road Morph's other fine attributes), particularly for only irregular use.
I carry two CO2 cartridges and no pump. I'm not sure why you would need both.
In all the years I've been riding, I've never used both CO2 cartridges. If I had to use three and only had two, out would come the credit card for a cab ride or a phone call for a pick up.
J.
J.
Thread Killer
Liked 1,752 Times
Also, a 700x38 ain't small; is this pump just for decoration, or do you need it to fill a flat in a reasonable amount of time and with a reasonable amount of effort? Are you just needing it to top off periodically, and relying on CO2 on-road?
If you're expecting to fill from flat, you want volume, and may even want to consider abandoning the small size/tool roll prereq in favor of something like the oft mentioned Road Morph.
If you just want quick access to a pump for topping off and will use a floor pump or CO2 for flat filling, then a you want a high pressure pump.
Thread Killer
Liked 1,752 Times
Crank Bros Sterling is auto selecting for presta/schrader, lever lock. Kenshibiker's suggested the tiny Topeak Micro Rocket CB, which is presta only. The others I don't know.
Bikes: 2011 Felt Z85 (road/commuter), 2006 Marin Pine Mountain (utility/commuter E-bike), 1995 KHS Alite 1000 (gravel grinder)
Quoted: 676 Post(s)
Liked 13 Times
dude, you can make phone calls with your credit card?? j/k j/k heh
Quoted: 86 Post(s)
i just bought the Crank Brothers Sterling pump
silver one on the bottom right.
dual volume gimmick works great... very (not an ISO standard, i know) small.
Quoted: 539 Post(s)
Liked 44 Times
Okay, so I currently have the Spin Doctor Rescue HV Mini Pump mounted to Lola, and am not a fan of it, at all! However, I cannot seem to find a mini pump that is any smaller than that. I have my Co2 inflator/cartridges, but got my mini pump upon other posters advice. Now, I am thinking of ditching it altogether in my tool roll (which I have yet to get, let's not go there ... ..., however, I did purchase the PoCampo Logan Trunk Bag ... haven't gotten to ride wth it yet, but it looks promising.) and taking it back or keeping it to use at home. For home, I currently have a Serfas floor pump that I am considering selling as I have never used it.
Anway, any suggestions on a smaller/thinner mini pump?
Thanks!
Thanks!
1. No risk of screwing up threading the cartridge on and losing everything, or getting a bad cartridge.
2. When I had little money, it cost less.
3. No risk of forgetting to replace a spent CO2 cartridge and ending up with nothing when I got a flat.
4. No risk of running out of CO2 cartridges from multiple flats (a lot of times they seem to all come at once)
5. Don't need to use up a cartridge to help someone else
6. Etc etc
All that being said though - an air pump in the size you are talking about is just plain terrible. Seriously they are just awful to use. A pump that small can barely get any air into your tire, and it's a pain in the ass.
I suggest you do one of two things -
1. Use a decent size mini pump, like a Road Morph Mini (that's the mini, not the regular full size version). It's bigger than you're asking for though. But I don't recommend anything smaller than that - anything smaller in a pump is just a pain in the ass to get a tire up to a decent pressure.
2. Use a combination CO2/air pump like this one (this is just a random one I found on amazon) -
https://www.amazon.com/RavX-Master-Mi...words=co2+pump
You'd have the air pump part as backup in case all your CO2 cartridges fail.
The bottom line is that tiny air pumps are a total pain in the ass to use, and why people use CO2. I recommend you either use a decent sized air pump (like the Road Morph Mini), or CO2 with an air pump backup built in.
Dual Head Valve Adaptor mod to my mini pump
sci_femme. I definitely agree that a pump like Topeak Road Morph that has a hose is best. It's really tricky to use those pump that has no clamp lever. Even with the lever, you still have to hold the pump relatively stationary with each pump action, which is pretty hard after, say, 100 strokes.
The one with hose you can pump more freely and cause less wear on the your pump rubber clap. I use an extra , attach a short hose, a Schrader value stem from discarded inner tube. I carry this on longer trips in my tool kit. It is basically and adapter so I don't have to switch pump head.
Cheers
Cheers
Quoted: 83 Post(s)
Liked 64 Times
I carry Blackburns Airstick 2-Stage as my backup to CO2. Good pump, presta only, VERY small, & has switch for low & high pressure. No hose but if you plant the head in your hand against your inner knee when pumping, it works fine. 60 strokes on low & maybe another 160 on high will get you home. If I'm in a hurry I use CO2 but the pump is always there if needed. Blackburn guarantees products for life and stands behind them. They've replaced a floor pump and light for me in the past - no questions. Use a floor pump at home for weekly top offs.
Bikes: Brompton M3L, Tern Verge P20, Citi Bike
Quoted: 85 Post(s)
Liked 9 Times
I use my floor pump at home, much more frequently than I use my seatpost pump, or any other bike mounted pump that I have had.
As for a pump on the bike itself, I started with one that the Evil Empire sells, I think that it was a Bell. It got replaced with a Topeak Mountain Morph pump. I then decided that I liked the idea of my seatpost also being my pump. Now, I have a Biologic Seatpost pump. I still carry the Mountain Morph pump in one of my front panniers, mostly, to help others.
I roll with Schwalbe Marathon Plus tires, so I don't actually use a bike mounted pump often.
Quoted: 4560 Post(s)
Liked 2,804 Times
Topeak Race Rocket. Or the HP or MT variants if more appropriate for your bike. Weighs only 3-4 ounces. I wouldn't want anything smaller or any mini pump that lacked a flexible hose and threaded attachment, rather than those awkward clamp-on attachments and no hose.
It's small and lightweight enough to fit in a pocket without noticing it. It works. While it takes a lot of pumping to get to full pressure it's easy to grip and use. And it's affordable enough that it wouldn't be too painful if it were lost or stolen. I usually take it with me when I can't watch the bike while shopping.
stockae92
Road Cycling
76
09-20-15 08:06 PM
mountainwalker
General Cycling Discussion
2
07-08-14 11:58 AM
partykingwes
5
10-21-13 06:44 AM
