Puncture repair patches glue on or self adhesive?
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1128 Post(s)
Liked 257 Times
For some reason the new polyurethane tubes patch best with stick on patches, and they will stick forever after a light sanding.
Butyl tubes changed their composition about 5 years ago according to Park Tools. Prior to the change I used Park self-sticking patches for over 20 years and they would last the life of the tube. not anymore, the composition change will not allow the self-stick patch to last more than a day or two. I went back to Rema, I don't like to wait for glue to dry but there is no choice.
I'm not racing, so I fix my flats on the side of the road and not replace the tube, then go home and fix it, it's a waste of time.
I don't fix flats the way you all do; I rarely have to remove the wheel from the bike! I first try to locate the offending hole in the tire, once that is found, which is at least 75% of the time, I then remove half of one side of the bead with hole in the middle of the half, then I pull out about a fourth of the tube with the hole in the middle, sand, glue, while the glue is drying, I check to see if there is anything inside the tire that I need to remove, then stuff the tube back into the tire, reseat it, and inflate.
By doing it the way I do it, I'm not spending time taking the wheel off, not spending time undoing the entire side of a tire, pulling the tube out, check for anything inside the tire, put another tube in, reseat the bead and inflate, then roll up the old tube while getting all the air out. Then I have to go home and take the tube out, find the hole, patch the tube, roll it back up and store it again. A huge waste of time in my opinion.
Likes For rekmeyata:
I've used self-adhesive patches in an emergency out on the road, but I don't think they're as good as the glue on ones. Hopefully, now that both of my main rides are tubeless, that will be less of an issue.
Likes For jgwilliams:
Advocatus Diaboli
Quoted: 4795 Post(s)
Liked 1,547 Times
Quoted: 6344 Post(s)
Liked 4,945 Times
Nice! However that $20.00 equates to the cost of about 4 or 5 inner tubes for me. And at the current rate that I flat, that would easily be 10 - 12 years or more before I ran out of inner tubes. Actually probably 16, because I have a couple used tubes that are from tires I wore out without flatting and figured new tire, new tube seemed to sound right.
Advocatus Diaboli
Liked 1,547 Times
Bikes: Litespeed Firenze, Spot Acme, Specialzed S Works Pro Race, Davidson Stiletto, Colnago Superissimo
Quoted: 145 Post(s)
Liked 320 Times
I got an 8 oz can of Slime patch glue for home use, but it doesn't fit well in a pocket. :-)
Liked 257 Times
According to the web search results, the shelf life of Rema vulcanizing glue for tube patches is 1 year from date of manufacture if kept unopened at 64 to 84 F*1. However, some users have reported that the glue can dry out even if it has never been opened2. Therefore, it is advisable to check the glue before using it and replace it if it is hard or sticky. You can buy tubes of Rema vulcanizing glue online or from some bike shops
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
"Wet glue" patches. Because they actually work, thanks to chemical vulcanization. LET THE GLUE DRY!!!! The glue-ons are a waste of time IME.
Instead of buying a hundred tubes of glue that you'll use once (and waste the rest), put your glue tubes in an airtight container. The VOA sample bottle is a perfect option:
Yes, they're glass, so be careful. I actually found a spare chunk of aluminum tubing that fit PERFECTLY around one, so it's no longer prone to being broken in the shop.
Rhapsodic Laviathan
I prefer the stick-ons because I'm kinda lazy and hate patching tubes. They're good enough with prep. It helps to run a lower pressure on a patched tube- took me way too long to have that epiphany.
Liked 257 Times
Back when tube composition was different than it is today I used Park glueless patches for about 30 years and never had one failed for the life of the tube, but about 5 years ago, according to Park because I asked them why their patches were failing after about 2 to 4 days, they changed the composition of tubes, and now the glueless patches will not hold, and I'm not one for dumping a tube because of a single flat, that to me is very wasteful, and a patch cost what? 30 cents? Since I'm not racing what do I care if I'm on the side of the road waiting a minute or two extra for the glue to dry vs a self stick patch! I'm hoping Park is working on a new adhesive for their glueless patches that will stick to the newer composition tubes, but we'll have to wait and see.
Palmer
Quoted: 1702 Post(s)
Liked 1,888 Times
Quoted: 568 Post(s)
Liked 425 Times
After that, if you don't want to swap for a new tube, you need to properly Rema it.
I personally don't ride with patched tubes simply because I am able to get rid of all my patched tubes in the bikes that I sell, and none of them have come back.
climber has-been
Quoted: 3567 Post(s)
Liked 3,745 Times
Here's something I just learned the hard way. TPU patches need to be stuck down as soon as you have applied the glue to the tube, before the glue dries.
Unlike patching a traditional butyl tube, where you must wait for the glue to dry first.
Reading the instructions in the RideNow patch kit makes this difference clear, but who reads patch kit instructions? Not your humble servant.
Liked 257 Times
climber has-been
Liked 3,745 Times
The patches appear to be exactly the same material the tubes are made of, right down to the markings.
Thread Killer
Quoted: 3218 Post(s)
Liked 1,764 Times
I just patched a RideNow 38g two weeks ago with Park self adhesive, doing nothing other than wiping the area with alcohol before applying patch. So far so good. I have Lezyne selfr-ahesive patched Aerothan tubes approaching 2 years without failure.
I have not used traditional cemented patches for over a decade, probably approaching two, as I’ve always had fine luck with self-adhesive, including on butyl. I have not had need to patch roadside since, well, I can’t remember, so I always do proper prep at home.
Insofar as I can tell from my experience, there are only downsides to using cemented patches, particularly in terms of time wasted and not having glue when you need it.
Self adhesive are always ready to go, and vastly superior (assuming one practices proper prep and application).
EDIT: I should add that the thin, supple Lezyne self adhesive are the best I’ve ever used, as I have had failures with Park. I just bought some Pax branded ones off Amazon thinking they might be like the Lezyne, but they are thicker and seem to be different material. I’ve not used yet, so no report on performance. Get Lezyne self-adhesive is my advice.
Liked 257 Times
I never in 30 or so years had a Park self adhesive patch fail either, until about 4 or so years ago, that's when Park told me tube manufactures changed their composition which did not allow their patches to stick for long periods of time any more. I may try the Lezyne, I much prefer glueless over glue on, it's faster, and you won't discover a dried glue tube when you need it.
Cantilever believer
Quoted: 566 Post(s)
Liked 1,956 Times
Where are you sourcing the 5 g tubes for $2 each? I'd be interested, as I have tested and/or patched close to 50 tubes just this week for local nonprofits.
Advocatus Diaboli
Liked 1,547 Times
https://www.ebay.com/itm/385931013006
The other product shot, makes it appear that these really somewhere are packaged in mini cartons of maybe 50? No idea if you can buy them retail though.
Likes For Sy Reene:
20+mph Commuter
Bikes: Surly LHT, Surly Lowside, a folding bike, and a beater.
Quoted: 1445 Post(s)
Liked 337 Times
I've been enjoying self-sticking patches for about 20 years now. I have never had one fail. Furthermore, the little tube of glue won't dry out before the second patch because.....there is NO glue tube. Also the box of patches is TINY in my seat bag.
I would be more concerned with self sticking patches on high pressure road bike tires but I don't own road bikes anymore. 50 psi is my max these days.
As others have said here, glue on patches will last forever. It's NOT GLUE anyway. It's a welding chemical that makes the tube and the patch as one (if you do it right). The patch can NOT come off. That said, my no-glue patches have lasted the life of my tires.
Get the surface of the tube prepped properly and you are golden either way. Just don't stick a glue-on patch onto the "glue" until it is completely "dry". Remember...it's not glue.
Quoted: 568 Post(s)
Liked 425 Times
Glue tubes drying out?
Those days are gone as I use a hot gun gun to seal glue tubes air tight AND put in a glass jar AND refridgerated.
Cheapie glue sticks are not sticky and can be peeled off easily.
Thread Killer
Liked 1,764 Times
