Bottom Bracket creaking
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Not to mention, cleats, saddle, and handlebar/stem interface. Probably other possibilities as well.
Bikes: Merlin Extra Light, Orbea Orca, Ritchey Outback,Tomac Revolver Mountain Bike, Cannondale Crit 3.0 now used for time trials.
Quoted: 127 Post(s)
Liked 55 Times
What are people's thoughts on addressing this issue? My bicycle is fairly new. I've only put ~500 miles on it and it's already begun to creak. It's a 2018 Specialized Allez Sprint, which means it's using an "OSBB" aka BB30. Is this common for the bearings to make noise this early? BBinfinite and Hambini seem to have a permanent solution. BBinfinite claim their ceramic bearings won't wear prematurely, like other standard ceramic bearings. Thoughts?
I only use the bike for casual, fitness riding. I'll likely go with the standard ABEC 7 steel bearings since I prioritize reliability over wattage savings.
Quoted: 173 Post(s)
Liked 57 Times
I took the bike to the lbs. I decided to address the issue head-on using money. I installed a Praxisworks BB. Here's to hoping it solved the problem [permanently].
Likes For Princess_Allez:
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Somehow I'm still on the original BB bearings for my Madone, the bike has at least 30,000 miles on it but I've pulled the crank a few times to check them and they're definitely a little rough these days and there is a small amount of play and some creaking, it's just one of those things where I don't want to be without my bike for more than a day so I never take it in. May finally have to do that soon.
Non omnino gravis
I don't think it's so much the bearings as it is the infinite wisdom some frame mfrs. in choosing to insert said bearings into plastic cups, which are in turn pressed into the frame, retained only by tension and high hopes. The bearings outlast the cups. That's what happened with mine-- the bearings still felt smooth, but I pushed the NDS cup out with my fingers.
Quoted: 173 Post(s)
Liked 57 Times
Quoted: 551 Post(s)
Liked 278 Times
It's a good thing you were not using bikes that didn't have squeaky bottom brackets or you would not have gotten better at your pedal strokes
Likes For tagaproject6:
Expired Member
Quoted: 3800 Post(s)
Liked 5,803 Times
That's about all you can do, hopefully it will be enough!
I had this issue once on a BB30 CrankSet
knighty76
Bicycle Mechanics
5
04-06-11 03:49 PM
