View Poll Results: Do you wear any head coverings under your helmet?
Yes
91
72.80%
No
25
20.00%
I like fluffy clouds
9
7.20%
Voters: 125. You may not vote on this poll
Do you wear something on your head, under your helmet?
Should probably buy one, nothing grosser than a peeling sunburned bald spot in the workplace...
just another gosling
Quoted: 3919 Post(s)
Liked 1,982 Times
Yes. When it's cold to stay warm, when it's hot to prevent sunburn. So a black one for cold, a white one for hot. The white one might actually keep my head cooler. I never wear a helmet cover because I depend on airflow to dissipate heat. In rain, a billed cycling is helpful.
Results matter
Results matter
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
"Headsweat" for sweat control. Also seems to make the helmet pads last longer.
Quoted: 1814 Post(s)
Liked 923 Times
Giro Peloton cap.
Giro merino winter cap, but lately
https://www.amazon.com/Giro-Ambient-...ct_top?ie=UTF8
which I really like for the mini-visor. Wish they all came like that as it keeps the sun/rain off but doesn't block the view.
Traditional caps with elastic in the back? Maybe OK for the days before helmets.
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
Always - a thermal cap in winter and beanie or cycling cap to protect from the sun and absorb sweat in the heat.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I have stupidly bad ears, and have learned my lesson: if it's under ~70F, I keep them covered.
Otherwise, just a pile of dark hair. Between that and a Koroyd helmet, I don't worry too much about bees or sunburn. Fluffy clouds are good, too.
Quoted: 1111 Post(s)
Liked 1,830 Times
I haven't, but I probably should being that I am bald balding.
Don't think I've ever seen (or at least not noticed) anyone wearing a cycling cap under their helmet, and trying to think how odd that would look with a bill sticking out from under my helmet, which already has a chintzy clip on plastic visor...
Bikes: Trek 1000, Marin San Rafael, Scott CR 1 Team
Don’t like the tan lines from my Laser helmet so I wear a fresh skull cap with tail every ride.
well hello there
Quoted: 503 Post(s)
Liked 339 Times
cycling cap on every ride.
Never even heard of anyone wearing a painters hat under their helmet.
Liked 1,982 Times
Giro Peloton cap.
Results matter
Results matter
Quoted: 139 Post(s)
Liked 33 Times
Halo headband year round for sweat. Below 40F, a fleece lined skull cap. I was surprised to learn that the old wives tale "you lose heat through your head" is actually true. I was having trouble keeping warm at 37F and the tops of my legs were pink after a 30 minute commute. I tried several variants of layers, but the skull cap was the big winner.
Quoted: 800 Post(s)
Liked 512 Times
I really like the look of the Giro's SPF Ultralight caps that was posted a few post up.
Someone on another thread mentioned Walz Caps and after doing some google searching, I thought their caps looked pretty good too.
In colder temps I wear a toque, which serves two purposes. Keeps my head warm AND keeps my ears warm. Nothing worse - for me - than having cold ears. Summer wise, I still wear a painters hat. Although switching to some kind of wicking material might make sense.
@Nachoman, I thought they were called painters hats. At least that's what I've always called them. Not sure where I gleaned the term TBH.
History of cycling caps
Quoted: 4560 Post(s)
Liked 2,804 Times
Always. Mostly bandanas. I have dozens of 'em, some passed along from my granddad who was a bandana-wearing gardener. There's always a fresh one. Wear 'em year 'round. Handy to cover the mouth/nose in cold dry weather too, or on dusty roads anytime.
For really cold rides I have various hoodies, windbreakers and baselayers with hoods to fit under or over the helmet.
I have a traditional cycling cap but those are mostly useless for my needs now since I always wear a helmet now. Cycling caps were for the no-helmet era when they occasionally needed some protection from sun or cold. I liked 'em in the 1970s when there were no good helmets and hairnets were both useless and dorky. To me cycling caps never feel quite right under a helmet, bill up or down.
Pizzaiolo Americano
I have a Gore skull cap for the winter that I love. I switch between a Gore and a Castelli headband to keep sweat from running in to my eyes or on my sunglasses when it is warm out. I like the Castelli one a bit more as it's slightly lighter...
Farmer tan
This $9 RockBros polyester cap has been perfect in hot and cool temps.
Visor is small enough to not obstruct vision.
Hysenm Tour De France Polyester https://www.amazon.com/dp/B01E2CIIR8..._-pBXCb7PT5QYY
Super Moderator
Quoted: 1175 Post(s)
Liked 937 Times
Same here...Only in cold weather. I have a "winter helmet" with room for a hat.
Kit doesn't match
I always wear a cap -- probably have a dozen.
One of my favorite lightweight caps.
They make nice caps for sure, lots of different styles.
Quoted: 2953 Post(s)
Liked 3,106 Times
Most days I wear a cycling cap under my helmet. On hot days I wear one backwards with the top cut off. It’s basically a sweat band.
Quoted: 590 Post(s)
Liked 445 Times
Does anyone else have no idea what a painters hat is?
Quoted: 20810 Post(s)
Liked 9,456 Times
Quoted: 626 Post(s)
Liked 404 Times
OP talking about the cheap painter's hat they used to give away when you bought some paint? I can't see what good they would do. Nothing to really soak up the sweat and too thin for cold weather.
However, I wear some Nashbar hats I bought years ago for warm weather. The bills were bothering me so I cut them off. I have a cold weather cap as well.
Years ago when I started riding, I wore a painters hat underneath my helmet. I took some ridicule from the people I was riding with, but I didn't care. The hat did some sweat management, and if a bee/bug flew in to the air vents of my helmet, I felt protected from stings.
Now that riding has EXPLODED in popularity, I am seeing more and more people - mainly men - wearing painter hats. Seems like the hats have gone from fringe to trendy. Some people I know wear head sweats or something like that too.
So I figured why not see what the rest of the Bike Forums crew are up to in the headgear dept. Cheers.
In cold weather, obviously you wear something under the helmet to protect your skull / ears from the cold (skullcap / thin knit hat). Common sense.
