Might have found the bike of my dreams......but it's got a carbon fork!
We have carbon forks on all of our bikes (gravel and road) and they’ve held up without any issues. I wouldn’t worry so much about that to be honest. Get the Ribble, seems like a decently spec’ed bike.
Bikes: Muddyfox Evolve 200, Bicycles4u Paris Explorer, Raleigh Twenty Stowaway, Bickerton California, Saracen Xile, Kona Hoss Deluxe, Vertigo Carnaby, Exodus Havoc, Kona Lanai, Revolution Cuillin Sport, Dawes Kingpin, Bickerton, NSU & Elswick Cosmopolitan
Quoted: 297 Post(s)
Liked 33 Times
Carbon forks are handmade and can have inherent faults that takes time to manifest plus they are brittle and you can damage them with an impact that on face value looks ok but internally a crack is appearing. Worth checking out Luescher Technik on youtube he is a carbon fan and expert but shows the issues with carbon frame and forks.
The reality is the carbon forks will probably be fine but steel can be seen if there is a fault, can be felt that a fault in imminent are of course is robust and can be abused for decades and still be fit for purpose. Given your concerns I would probably replace the fork for steel but why not just try the carbon for a while and see what you think. I wouldn't have a carbon fork on a touring bike but for it sounds like the bike is for more general use.
According to Luescher Technik it is carbon forks that are more likely to fail and cause injury than carbon frames but the sort of forks he mainly see's are exceptional low weight performance carbon forks which are a little more prone to failure. It's amazing how many frames and forks that look fine are actually faulty when he scans them. He also cuts up unrepairable frames and forks up to see the construction and some of it is so rubbish in construction and we are talking seriously expensive carbon too.
I'm overweight so don't even consider carbon myself because I like to have some clue about imminent failure of my frames and forks. I don't want to be going down a steep hill at 35mph when my carbon fibre forks decide to go on their own separate journey away from the rest of the bike. I'm not the sort of weight that will land well at high speed. Being overweight bicycle weight is of only vague concern but admittedly the increased comfort of carbon fibre does appeal.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 763 Post(s)
Liked 556 Times
buy the bike. ride the bike. if later you want to change the fork or anything else do it
Quoted: 7163 Post(s)
Liked 11,368 Times
Good grief. At this point, cf is hardly "new tech."
A cf fork is an upgrade.
But if you're a nervous nellie, by all means, buy an inferior bike.
Quoted: 169 Post(s)
Liked 84 Times
A few years back, I built up a bikepacking/gravel bike on a Lynsky titanium frame. Wanting to keep weight down, I picked up a cheap no name Chinese carbon form with 15-100 through axles. The fork was indestructible. It had a lot of flex on gravel and wasn't too bad. Then I got on some chunky jeep trails with a lot of larger embedded rocks and ruts. The damned thing shook me to death.
I then built up a different frame with a Lauf fork and that became my go to bike for bikepacking or all day gravel riding.
A carbon fork will be fine. My Giant TCR is all carbon and is a great ride.
Quoted: 18596 Post(s)
Liked 16,096 Times
Likes For indyfabz:
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
I will never own a carbon fork for the simple reason that I do not like their failure mode. I've had one fork fail in similar fashion. Once is plenty in one lifetime. But the good new is - any framebuilder can make you a steel fork. With a conservative crown and not superlight blades. a fork with a sweet ride can be made as a retrofit to any bike, will be a very pleasing ride and last a very long time. Plus, any significant damage that happens to it will be very visible.
My two ti bikes each have steel forks. After almost 30,00 miles, I still love their rides. Likewise my old steel frame with almost twice the mileage.
The other part of having a custom fork made - it's fun! The choices - more clearance for tires? Adjust the rake to get the bike to feel a little different. Stiffer? More forgiving on rough roads? Brake choices. The fork crown - biggest style point on the bike. The color? Chrome? Braze-ons - LowRiders, custom racks, lights, water bottles or flasks and so on. Sharp curve down low? High, gentle bend? straight? Tangs on the insides of the blades?
Yes, steel forks have more vibration. Steel is a near perfect elastic material. But done right, that vibration is simply not an issue. Steel forked bicycles have been riding the roads of the day in style and comfort for 130 years. And those early roads were far worse that anything we would call pavement now. (Steel and titanium bike frames also don't dampen vibration at all. Yet many are considered very good bikes for rough roads.)
Ben
Ben
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,543 Times
The 1x Apex version? It appears to check all of your boxes. Carbon fork? Eh, it's likely to last as long as you own the bike. Very likely. And it has the clearance you'll need for wider tires.
As long as they engineered the fork for the forces imparted by disc braking, you'll be fine. I've read of Chinese forks that appeared to lack the engineering design, so when they came out in disc compatible models, they snapped under braking forces. There are reviews and photos on the web. Not to imply that this is the case here, at all.
I have carbon forks of similar quality level on two of my bikes, my daily commuter (disc) and a steel race bike (rim brakes). I never concern myself with their integrity. Of course, I do inspect them whenever I have the bike on the rack for service.
Good luck. I wouldn't hesitate to buy the Ribble 725 CGR for your use.
Advanced Slacker
Quoted: 2769 Post(s)
Liked 2,556 Times
I would not think twice about carbon from a safety perspective. I think there is a lot of misconceptions out there these days about CF.
And if it is really a problem, just swap it for a steel fork.
Quoted: 1572 Post(s)
Liked 644 Times
I think that you worry too much.
Bikes equipped with carbon fiber forks have been common for over 20 years. Everything has a failure rate so I suppose there have been some carbon fork failures during that time just as I'm also sure that some steel forks have failed. If, however, there had been a rash of failures with either material during that period of time, I'm sure I would have heard about it.
There are a lot of bad things that might happen. Most of them won't.
Bikes: 1996 Cannondale R900, 2016 Trek Boone, 2005 Giant Yukon
Quoted: 584 Post(s)
Liked 66 Times
I would stay away from carbon fiber. I once had a bike with just a carbon fiber bottle cage. First ride out, the whole bike took off under me, ran an old lady over crossing the street and then into a bus full of school children which then exploded.
I can only imagine what would have happened had I had more carbon fiber. Never again.
Likes For 86az135i:
Likes For PepeM:
Liked 16,096 Times
Bikes: Masi Giramondo, Trek 830 monstercross build, Raleigh Gran Sport, Lemond Tourmalet
Quoted: 121 Post(s)
Liked 19 Times
Quoted: 741 Post(s)
Liked 819 Times
Carbon, smarbon, no big deal. I bought a Specialized Allez in 2002, aluminum frame and fork. The fork beat up my arms, so I changed it to an Easton carbon fork. Transformed the ride. Besides the Allez, I have two other carbon bikes now, 2007 Roubaix, and a 2013 Culprit with carbon frame, fork, seat post, wheels, bars, even water bottle holders, both road bikes. I have thousands of miles on them, yes, a couple of crashes. I got beat up, but the carbon lived to ride again. Beware the carbon whiners on here. I love my old school steel, but carbon can be every bit as loveable as steel, and its lighter, too. 😉 No worries.
Regarding the durability of carbon fiber and it surviving the crashes (or not), I recommend to watch this video. It's in German, but I think you'll get the gist even if you don't understand a word. Skip forward to 18:00 to see the action.
Likes For subgrade:
Liked 16,096 Times
Thanks for the replies my intention wasn't to open up the carbon v steel debate but it's interesting reading.
I suppose I could change it to a steel fork down the line , the only issue there is I don't think steel forks are available with tapered steerers , I could use a headset adapter but then a straight steerer fork looks kind of odd in a tapered head tube and I'm a sickler for smooth clean lines on a bike , also would I ever be able to match a new fork to the color of the frame ?
Both of my current bikes are steel , one a 1972 Peugeot converted into single speed and an early 80s koga miyata touring bike, so a carbon forked bike will be very new territory.
I'm just after discovering this bike , a ragley trig adventure bike , all steel , bit over budget but might be a contender
https://www.chainreactioncycles.com/mobile/ie/en/ragley-trig-adventure-bike-2019/rp-prod176557?gs=1&sku=sku672219&pgrid=55940684541&ptaid=pla-672782160450&utm_source=google&utm_term=&utm_campaign=PLA+All+Products&utm_medium=base&utm_content=m kwid|s9QCXV3pa_dm|pcrid|294740729972|pkw||pmt||prd|672219IE&gclid=Cj0KCQjwn8_mBRCLARIsAKxi0GKWKIFxxh CfuSrAEJZ-C2NnjgDfaCBedBhvf0ayWmlZBdIBcR-sy4MaAvFtEALw_wcB
