Stuck Seatpost After "Only" 30 years.
I can get dry ice at my local grocery store, and CO2 at a local tank filler, home brew store, or sporting goods store (paintball supplies).
Edumacator
Quoted: 2544 Post(s)
Liked 3,369 Times
And if you keep the saddle, you can sacrifice it again and again!
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Quoted: 1643 Post(s)
Liked 2,746 Times
Two man job. Used the old seat method and an extra large crescent wrench. I lifted and twisted the seat post while my buddy held the frame and hit up on the wrench with a mallet. Worked fairly quick.
Draino crystals with just enough water to cover. Let simmer for a couple days outside or in a well ventilated area. Check and repeat as necessary. Of course you’ll need to plug some holes if you go this route. I’ve had good luck with this method. It took about a week to fully dissolve and had to removed in shards. It has to be crystals and not gel. This way you can make it more concentrated.
Likes For LBCwanabe:
Super Moderator
Quoted: 1175 Post(s)
Liked 938 Times
Plenty of frames intentionally drill holes in the BB shell. No big deal. Often done with their logo.
^^^^^ there is already a "M" shaped hole in the Masi, not sure about the Pinarello.^^^^^
Liked 2,746 Times
verktyg
Quoted: 1038 Post(s)
Liked 1,243 Times
Tri Bike Idjets and Stuck Seatposts
Back in 2007 I picked up this Ironman dirt cheap sans wheels and saddle:
It came from some Tri rider in SoCal and was rode or at least abused hard and put away wet.
The first thing to go was the radar array bars then I started on the stuck seatpost. After a number of violent mechanical attempts I decided on major surgery.
After amputating the unnecessary top of the post I started cutting a slot in the rear with a jab saw and then a folding buck saw being careful not to cut into the seat tube.
After cutting an 1/8" slot all the way to the bottom of the seatpost I used a 20" pair of Channel Lock pliers to crush the seatpost enough to break it free from the seat tube.
Fortunately the Tange # 1 tubing had a double butted seat tube with a 0.9mm wall thickness at the top. I was able to ream out all of the corrosion in the seat tube and hone it to take a 27.2mm seatpost.
3 hours of work!!!
After a lot of clean up - a nice IM:
I wonder who the idjet at Western States was who came up with the idea to use a deeply fluted Sugino seatpost in a tri bike so water could easily get in???
verktyg
3 hours of work!!!
verktyg
Chas. ;-)
Chas. ;-)
verktyg
Liked 1,243 Times
Tri Bike Idjets and Stuck Seatposts Part 2
Back in December I spotted this 1986 Reynolds 753 Bernard Hinault Look bike at an LBS.
They were planning on restoring it but I talked them in to selling the bike to me as is. I didn't look the horse in the mouth too carefully until I got home.
These were pretty rare, only 250 or 500 of those frames made.
It was my size, 56cm and had an almost complete Mavic gruppo except for a Shimano FD, an SR MTE-100 adjustable setback seatpost a goofy SR bar and stem.
The first thing to go was that SR seatpost - I knew someone who wanted one of those. Not so fast!!! It's become a permanent fixture in the frame!
That's also when I noticed the rusty spokes and other clues that the bike had been abused by a tri ath idjet !
After several attempts to loosen the post by twisting, expanding the lug ears and so on, I tried 3 weeks of Kroil. No joy.
I'm taking it to a friend's shop who has a large vise on a stand bolted to the floor.
Reynolds 753 is pretty thin stuff. One gentle try in the big vise then it's surgery time - see my Ironman post above.
Idjet, Idjet, idjet !!! Just a little grease !!! May he have sand in his Vaseline !!!
verktyg
verktyg
Chas. ;-)
Chas. ;-)
Likes For verktyg:
Quoted: 13 Post(s)
That's a gorgeous bike and those fluted seatposts are the worst...
Your best bet is 1) getting everything as cold as possible, and 2) impact, i.e. a slide hammer setup like RJ the bike guy demonstates on youtube.
The corrosion is very strong but also very brittle. It's very hard to break a glass by squeezing it, but easy to break by tapping it on a hard surface. This is why impact wrenches work so well on corroded fasteners -- the impact breaks the corrosion.
Twisting the frame is dangerous as it puts huge twisting forces on the seat tube, forces that thin tube is not designed to take...
If impact/cold doesn't work I'd try dissolving the seatpost.
verktyg
Liked 1,243 Times
Fluted Seatposts and Idjet Tri Riders
The Kroil has been in there for well over a month. My vise is on a wooden bench that's not very rigid. A few gentle attempts at twisting the frame held by 2 people with the seatpost held in a floor mounted vice may work and even save the seatpost.
Reynolds 753 seat tubes have a wall thickness of 0.5mm at the top. There is no way I'm going to risk dissolving the seatpost with chemicals or using an impact wrench or slide hammer.
If I can't remove the post intact, I'm going to carefully cut it out... A lot of work that I'm not looking forward to.
I don't suffer fools gladly... May the PO suffer many saddle sores if I have to go the surgical route.
verktyg
Chas. ;-)
Chas. ;-)
mycocyclist
Quoted: 916 Post(s)
Liked 871 Times
"Work" Requires Energy
Fluted seatpost are merely decorative and save the weight of maybe one wet crepitu, pet, scoreggia....
verktyg
verktyg
Haven't lost a frame, seat pillar or stem yet.
Super Moderator
Liked 938 Times
Seatpost is OUT !!
No drastic action required. Frame was upside-down for a few weeks with Kroil sprayed down the seattube.
Today, I put the top of the seatpost in the bench vise, grabbed the head tube and rear dropout & twisted. It took moderate force, but nothing crazy and the bond "cracked".
Then it was just a matter of twisting & pulling for 5 minutes. The deepest part of the seatpost was dry, so not sure the kroil did any good, since it didn't seem to have penetrated the bond.
Likes For Homebrew01:
Super Moderator
Liked 938 Times
Are there cutouts in the BB shell ? Maybe my thought of sliding a bar through the BB, up inside the seatpost, then a few whacks with a mallet would break the bond ? It shouldn't stress the seat tube except in tension.
The verktyg cut a slot method is very safe. If the corrosion is real bad cut two slots. Cutting aluminum has a completely different feel from cutting steel. When the saw touches frame metal you know it. The frame doesn't even get scratched, more like a polish mark. Need not take more than 15 minutes. Use a thin hacksaw blade, not some fat thing. Hacksaw blade can be held with fingers, no special handle necessary. First time takes longer from excess of caution. Will not work with super long MTB posts deep inside frames.
Quoted: 1633 Post(s)
Liked 2,256 Times
[/QUOTE} ….Reynolds 753 seat tubes have a wall thickness of 0.5mm at the top. There is no way I'm going to risk dissolving the seatpost with chemicals or using an impact wrench or slide hammer.
verktyg
....[/QUOTE]
I can understand your concern. I used lye on a steel frame with no impact to the steel. The AL all but disappeared in a cloud of H2. The paint is subject to damage, however.
P1030272, on Flickr
P1030290, on Flickr
WP_20160107_001, on Flickr
P1030378, on Flickr
verktyg
....[/QUOTE]
P1030272, on Flickr
P1030290, on Flickr
P1030378, on Flickr
Quoted: 741 Post(s)
Liked 819 Times
Seatpost is OUT !!
As found in scrap pile.
Built into a nice ride. Never give up!
Quoted: 334 Post(s)
Liked 333 Times
Feel the Burn
Sometimes the anodised weld between the ally post and the frame is so complete even quarter portions of a fully divided seatpost won't budge.
A blowtorch flame directed straight down a decapitated post melts the post in around 5 minutes and you just shake it out hi.
You have to repaint the frame's seatpost ofcourse.
