Why Reinvent the Wheel? (aka another Campagnolo rant)
Quoted: 1533 Post(s)
Liked 725 Times
Hm. What sort of spoke count are we talking on these wheels with the failing spokes?
The current zonda rims are 17mm inside width. Previously 15mm. I have a set on both of my bikes. They work great with 25mm tires, but will easily accommodate 28mm. Weighing in the 135-140 pound range, I don't need 28mm and it's questionable whether the diameter would clear the frame of a Conago C-RS. Tubeless has too many problems to interest me. I've ridden 6200 miles now without a flat, so my tubed tires - michelin power endurance - are working well.
As for the hub design, you can criticize all you want, but they are trouble free and the same free hub works for 9-12 speed. I have all 12 speed. Like usual, shimano will catch up 4 years later, but like with 11 speed, their hubs will be redesigned again (think microspline this time). Your old wheels will be obsolete.
Campy wheels can be had with Shimano 10/11 and the new SRAM XDR free hub. To get the XDR, you either have to buy the Fulcrum brand wheel or a free hub replacement from Fulcrum.
Likes For DaveSSS:
Take a look at the new Shimano microspline hub. The exploded view on page 17 sure reminds me of a Campy hub. The caged ball bearings on the axle are located similarly to a Campy hub - no longer at the right end of the axle. There must be a a cartridge bearing inside the free hub body, that's probably considered to be non-replaceable, just like Campy's free hub. The cartridge bearings in a Campy free hub can actually be replaced, but it's not real easy.
https://si.shimano.com/pdfs/dm/DM-MAHB001-06-ENG.pdf
Criticizing electric motor bearings is interesting. An electric motor is often expected to run 24 hours a day for 5-10 years, with nothing but an occasional squirt of grease, or in some cases with no maintenance at all. I have two 5 hp pump motors that share 24 hour per day operation. They have greased for life bearings, with no grease fittings. They've been running for 7 years now.
Likes For DaveSSS:
Jedi Master
I bought a bike off CL last season that came with SR and two wheelsets, a set of Shamals and a set of old Chorus/Open Pros. When I'm riding the bike I honestly can't tell the difference between those and the other dozen+ other wheelsets I have. People say wheels are one of the best upgrades. I can only assume that's true for people who are more fit than I am. I try not to buy anything shimano because I don't like the way they do business, but I still think the value of their cup and cone hubs is impossible to beat.
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I wish I'd just sucked it up and gone with the Hed H3+ when those were available. Then my spokes could only asplode.
Quoted: 20810 Post(s)
Liked 9,456 Times
For the Phil Wood/WI comment, I don’t see a straightforward way to get a campy hub on its own. Shimano does the same thing, sadly (thankfully, mavic does too). This is why WI, CK, DT and i9 are so popular. They offer standalone hubs.
I personally went DT for my chinese carbon wheels. They were way cheaper than many western brands and I personally know 5 other people who have bought wheels from that exact company. Many other people have bought other chinese carbon or rebadged chinese carbon wheels. If campy cares about being more popular, they should offer hubsets. I actually really wanted a cup and cone rear hub and would have considered campy if they offered a reasonable hub.
I personally think that Campagnolo hamstrings their wheels with their brand name, because when I think Campy, I think “pompous prick with no personality who tries to compensate by buying rare/unique bike parts”. No offense to anyone who actually rides campy, of course. But as a younger cyclist, some people’s fetishism over “italian heritage” or whatever makes me want to puke. Same reason why Bianchi’s inane “Handmade in Italy” stickers make my blood boil. I’d like to flip the question on you (in regards to drivetrains). Why would anyone pick a campy groupset over Shimano?
To be fair, I think americans’ view of european brands is very different from that of europeans’. It’s possible that campy is very popular in europe/italy. I wouldn’t know.
I've used Campy only for over 25 years because they are most often an industry leader when it comes to road bikes. I owned one pre-built Cannondale bike with Shimano 8 speed STI, back when brake/shift levers first came out, but tried Campagnolo ergopower 8 speed, for a new build of a Tommasini Sintesi. I like the way that ergopower lever worked better than Shimano, so I switched and never looked back. I used Campagnolo groupsets on each the many bikes that I've built-up since then. I never bought a factory built bike since the early 90's.
Campy was the first to offer 10, 11 and 12 speed drive trains for road bikes. I made the switch to each of those either in the first year or soon after, while Shimano typically lagged 3-4 years behind. That's one reason to pick Campy.
While the price for Campy groupsets is usually higher than a similar Shimano groupset, the cost of ownership may not be. Used Campy parts sell for relatively high prices. I've sold off a lot of Campy parts on e-bay, each time I moved on to the latest technology.
It pays to search the internet for the lowest prices. For a long time, the lowest prices were usually found from European sources, but not always. I bought two Chorus 12 groups, in July of 2019, as soon as they became available, for $1060 each, from a dealer here in Colorado. The main reason was to get the new 48/32 sub-compact crank and new 11-34 cassette.
Likes For DaveSSS:
Liked 9,456 Times
I haven't looked at Campagnolo wheel offerings in a while, so I checked them out. Hard pass. All of their disc options have those silly looking three-spoke clusters with big stretches of barren rim between them, the weight/dollar isn't terribly impressive, their rim profiles would be on-trend for 2010 and their tubeless compatibility is spotty. Their Fulcrum offerings are more compelling as budget options, though I wouldn't touch them at price points over three or four hundred dollars, either.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Not that there are any tris to train for now anyway.
Quoted: 3261 Post(s)
Liked 2,581 Times
You must be the 41 outlier, then. Most on here say their average speed goes up at least 10mph, can suddenly climb better than Pantani the pirate, and can sprint as fast as Peter Sagan..........after upgrading their wheels to the brand they purchased.
Liked 9,456 Times
Does he have an actual pair of the H3 Plus? They did not make the rears for long, and the pair was $3k when they did. You can still get the fronts fine, but for some reason the rears are gone. If he has the Plusses, he's probably the only person in the country to match them to a Talon.
Bikes: Yes, probably too many but still have a roving eye...
Quoted: 324 Post(s)
Liked 2,877 Times
I've not bothered with the newer expensive Campag wheels as I'm still working my way through my collection of Ebay found wheels in excellent condition I got for a fraction of their original cost. They are more than capable of dealing with anything I can throw at them and I've had 10's of 1000's of trouble free miles so far, and the hubs are beautiful to look at even when stationary.
Currently I have:
1 pair first gen silver chorus hubs, 7 speed screw on freewheel, Campagnolo Omega Strada rims
And all the following are 9/10/11 speed hubs which offer great versatility.
5 pairs of silver chorus hubs built with mavic open pro rims
1 pair of Record silver hubs build to Mavic SUP rims
1 pair of Record silver hubs with Ambrosio excellence rims
1 pair of Record black hubs built to Mavic open pro rims
2 pairs original black Shamals-clincher
1 pair of original black Shamals-tubular
2 pairs of original silver Shamals-tubular
I've have had a couple of pairs Fulcrum's too, which are pretty much Campagnolo.
Obviously I only started with one bike and one set of Campagnolo wheels, and then got a second bike, wanted to keep the interchangability of parts between them, so I was already down the Campagnolo rabbit hole, 8 bikes later and the cycle continues
Currently I have:
Likes For botty kayer:
Liked 9,456 Times
They exaggerate. My average speed only went up 8mph.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Liked 2,581 Times
Liked 2,581 Times
Liked 9,456 Times
Liked 2,581 Times
OT, but you may need this info. James City County is one of the hotspots for COVID-19 in VA. Take that info and use it. It might be a good time for the MIL to take some time away from there. Good luck.
https://www.pilotonline.com/news/hea...qri-story.html
Liked 9,456 Times
I know, thanks. We were supposed to be down there right now and I was just complaining in the other thread that my dumb-ass brother in law recently took my not-exactly-hale mother in law to the hospital for a completely unnecessary annual check-up. Ugh.
serious cyclist
Bikes: S1, R2, P2
Liked 3,679 Times
Likes For Bah Humbug:
Liked 725 Times
Nothing wrong with electric motor bearings in electric motors. There's something wrong with using them for a totally different application, though. Cartridge bearing hubs that employ angular contact bearings and a means to adjust preload, not to mention sealing appropriate to a bike hub, are far less inferior than a typical cartridge bearing hub, but they're rocking horse poo.
I don't believe that any other brand uses the Shimano road hub design, which would mean that no other brand of wheel is worth buying. Whatever patent they may have had on the design should have expired long ago.
Have you checked out the new shimano microspline hub? Look at the location of those axle bearings - same area where Campy bearings have been for a very long time. I don't see any caged balls in the free hub either.
Likes For DaveSSS:
Bikes: 82 Lotus Unique, 86 Lotus Legend, 88 Basso Loto, 88 Basso PR, 89 Basso PR, 96 Bianchi CDI, 2013 Deda Aegis, 2019 Basso Diamante SV
Quoted: 943 Post(s)
Liked 172 Times
The thread title makes it sound like Campagnolo invented the bicycle wheel. Campagnolo didn't start making their own hubs until the 1950's, which may seem like a long time ago, but there were many others building hubs before this time. I don't recall seeing Campagnolo branded rims until the 1990's.
Brent
Brent
Good man...
