Cycling and hand signals
Quoted: 6353 Post(s)
Liked 4,956 Times
I'd want to use the hand signals that most every motor vehicle driver should have been taught or should have read if they even opened their states driver manual. Though some do include wording that a cyclist may use and extended right arm to signal a right turn.
So lets just recognize that either is acceptable everywhere that I know of. Except if you are in a motor vehicle. Then common sense should tell you to use the arm that will extend from the vehicle depending on which side of the vehicle the steering wheel is on.
I almost always extend my left arm up to indicate a right turn. I feel that my right hand and arm have better control over my bike than my left. Maybe it's something I should practice in case I have my right arm ripped off by one of those bears that seem to be chasing some lately.
Likes For Iride01:
Thread Killer
Quoted: 3239 Post(s)
Liked 1,798 Times
Signaling in accordance with established and recognized protocol is a good reason to use the left arm. Because we ride with traffic, usually to the right, which puts our left arm in the centerline view for vehicles following, behind, and alongside, is a good reason to use the left.
Making up signals because you can is childish.
Quoted: 5234 Post(s)
Liked 3,609 Times
this is a good point, but insulting me to make a point is not
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
People signal turns on MUPs? I have literally never seen this done once and I ride a lot of MUPs. In the past two weeks, I have ridden on MUPs in 4 different states.
MUPs are not roads. If I need to let someone know what I'm doing on a MUP, I'm generally behind them and I'll use my voice to explain. If I'm going to turn left, I'm going to wait for the guy in the opposite lane to pass by me first, so it's not going to be an issue. On a road, I try to always signal my left turns in case I'm wrong about there being nobody behind me. If I'm FRAP, I rarely bother signaling a right turn.
I don't know what use the information that he was turning to the right was to you, and his signaling it just caused you some confusion.
I know the upward bent left arm means right turn, but it's obscure enough knowledge that I don't know whether the person holding their arm up actually intends to signal a right turn.
Quoted: 20810 Post(s)
Liked 9,456 Times
For some time, I've wanted to hand signal a right turn, in my car, while in the presence of a police officer. I'm betting that it would be lost on most officers and I'd end up getting pulled over.
Tragically Ignorant
Liked 9,099 Times
This is actually wrong in most states. Most states have changed their laws to allow the extended right arm to signal a right turn. We are literally operating the only vehicles commonly found on toads using hand signals, so it makes sense that the "road code" has been adapted to bicycle use. As stated above, the only reason for the left arm bent upwards is because drivers couldn't stick their arms out the right window. It makes absolutely no sense on a bike.
Liked 9,456 Times
Signaling differently because you can is not a good reason.
Likes For WhyFi:
Thread Killer
Liked 1,798 Times
Thread Killer
Liked 1,798 Times
Pointing the direction that you intend to travel is much more intuitive than using an arm, opposite the direction you intend to turn, fist raised upward. It's not a matter of signaling differently because you can - it's a matter of effective communication. Language/communication changes. Do you rail against new additions to the dictionary, too?
Liked 9,456 Times
Completely irrelevant within the scope of discussion. Does reason tell you that fist up, with your left arm, indicates an intent to go right better than pointing right with your right arm?
Thread Killer
Liked 1,798 Times
Motor cycles are motor vehicles with the same ability as cyclists to use both arms, but I believe they’re required to hand signal just as cars are.
Klaatu..Verata..Necktie?
Quoted: 10634 Post(s)
Liked 12,267 Times
"Pointing your arm in the direction you intend to travel is dumb AF! You need to follow an arcane set of rules because any deviation from how I think things should be upsets me! I don't care if the rules have changed!"
That about sum it up?
Likes For genejockey:
Bikes: 2022 Salsa Beargrease, 2020 Seven Evergreen, 2019 Honey Allroads Ti, 2018 Seven Redsky XX, 2017 Trek Boon 7, 2014 Trek 520, 2006 Gary Fisher Montare
Quoted: 697 Post(s)
Liked 911 Times
For some reason I assume that drivers will have no idea what an extended right arm means if they even see it. I assume (yes I know the saying about assuming) they can see an upraised left hand easier.
Tragically Ignorant
Liked 9,099 Times
You're from Michigan, right?
Your legislature thinks differently than you do, and their opinion counts and yours doesn't:
https://www.michiganautolaw.com/blog...an-bicyclists/
Likes For livedarklions:
Thread Killer
Liked 1,798 Times
Thread Killer
Liked 1,798 Times
Tragically Ignorant
Liked 9,099 Times
So are you afraid that if you use the right hand extended signal, you're going to ride off the edge of the earth?
Hate to break it to you, but you're the flat-earther in this discussion. Reason has dictated that a signal that can be understood intuitively is superior to one that was adopted for no longer relevant reasons.
Liked 9,456 Times
Likes For WhyFi:
Tragically Ignorant
Liked 9,099 Times
Liked 12,267 Times
One might say, you have no reason to.
Tragically Ignorant
Liked 9,099 Times
New York State permits right hand extended to the right as a legal alternative for bicycles (to signal a right turn).
Thread Killer
Liked 1,798 Times
As an aside, we gotta start paying teachers more…and bring drivers’ ed. back into the MI public school cirriculum.
Mad bike riding scientist
Quoted: 6284 Post(s)
Liked 4,323 Times
There’s a reason for that which doesn’t apply to bicycles. Frankly, signaling right turns with the left arm on a bicycle is awkward and puts the rider in a bad body position for a smooth right turn. We corner better with pressure put on the pedal and handlebar on the outside of the turn. A raised left arm removes that control.
Stuart Black
Stuart Black
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3130 Post(s)
Liked 6,801 Times
We aren't in cars or on motorcycles with a right hand throttle.
Likes For cb400bill:
