first drop bar tape attempt... how long to live with my ineptitude?!?
Quoted: 3637 Post(s)
Liked 3,062 Times
Quoted: 1286 Post(s)
Liked 1,417 Times
I doubt anyone will notice. Give yourself a break, and ride the bike until you feel like having a re-do.
I recently did my second wrap job on a set of "trekking" bars, and while I think I did an all-right job, I somehow managed to wrap the second side so the "Easton" name doesn't appear on the tape.
I'll live with this...
Both sides started and wrapped the same way, but the brand imprint is covered on the right side. :-(
went for a ride. realized that i did the same thing as you - only one side of the tape has the little oil-slick stars on my tape…. and i wrapped it so it’s only visible on the right. 😂😂😂😂
Quoted: 996 Post(s)
Liked 592 Times
I wonder if there's a "standard" side of the tape for the graphics to be on. Yours are on the right side, while mine are on the left. I started wrapping at the grip, and you started yours at the stem. Hmmm...
Advocatus Diaboli
Quoted: 4795 Post(s)
Liked 1,547 Times
Bikes: Lemond '01 Maillot Jaune, Lemond '02 Victoire, Lemond '03 Poprad, Lemond '03 Wayzata DB conv(Poprad), '79 AcerMex Windsor Carrera Professional(pur new), '88 GT Tequesta(pur new), '01 Bianchi Grizzly, 1993 Trek 970 DB conv, Trek 8900 DB conv
Quoted: 759 Post(s)
Liked 811 Times
Rather than use electrical tape to finish, self-sealing silicone tape yields a better looking and wearing end-wrap-finish.
Likes For fishboat:
Liked 1,417 Times
redid the left side to get the stars out and match the proportions of the right, which of course now is backwards. but getting better - still a bit of a bulge right at the starting transition but two passes before starting at an angle with this thick tape is way too much. much tighter edges though. thanks to all who pointed out that you can redo it once or twice. i didn't think the adhesive would stay tacky.
Likes For mschwett:
Stuck in Toeclips
after viewing a half dozen videos with conflicting "best methods" for doing this, i decided on the top down approach (not too worried about pressure on the bar tops unraveling anything, i'm on the hoods 95% of the time and the drops the rest) because i didn't like the electrical/finishing tape the bike came with. tape was ripping on one side from a minor spill.
ended up with some lumps... some asymmetry (shouldn't have tried to make the second one "better"), one or two little leading edges that aren't sitting flat, and i'm not 100% sure the last bit of tape is going to stay tucked in at the plugs.
live with it until it wears out... or eat the $40 for a second try!?!?
Likes For mschwett:
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
While I hate taping bars in that direction you did a pretty dang good job. I would NEVER leave tape on for more than a few months w/ an alloy bar, especially if you sweat a bunch. You need to check for corrosion under the tape regularly. I know this sounds extreme but if you ignore it it can kill you. Lost a good friend/customer years ago for this exact reason.
Likes For cxwrench:
Liked 1,417 Times
Bikes: lots
Liked 2,932 Times
Not nearly as much of a worry w/ a carbon bar. I change mine often just because I get bored and can't stand when it starts smelling funky. I've always looked at bar tape as a consumable, especially because my background is being a team mechanic. We changed that stuff all the time just to keep it fresh. I also HATE when people leave it on too long and it takes me 30mins to get it completely removed before putting new tape on.
Method to My Madness
Quoted: 2064 Post(s)
Liked 1,557 Times
I think mschwett did OK for the first time.
My first time was slightly more even and in the correct direction, but I left a gap behind the STI lever band and could not get the end plugs in. I tolerated that first wrap for about a month before redoing it with new bar tape. I am not a mechanic and thus don't replace the bar tape often enough to become proficient at it. So every time I replace my bar tape I am pretty much starting from square 2. In hindsight I should have started with cheaper tape, at least for the first 3 or 4 jobs.
Just go slow, take deep breaths, and have a system for tracking whether things are even. My OCD tips include: maintaining the same slight tension throughout, counting the number of loops to reach the STI levers, more tension on the figure 8 around the STI levers, keeping the overlapping distance constant at the top of each loop, and not cutting the first side until you have also finished wrapping the second side and see that the two remaining lengths are about the same. It takes me an hour, with multiple partial unwrapping and re-wrapping per side, to install bar tape.
Depending on whether you are right or left handed and how your brain works, you may get better results from first doing the left side or the right side, then doing the other side to match. For example, I do the left side first because it is harder for me as a right hander, but once it is done, I can do the easier right side and better match it to the left side.
Yes, this is certifiable OCD.
Likes For SoSmellyAir:
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
Liked 1,557 Times
Liked 1,417 Times
redid the right side. pretty happy actually, other than the bit of a thicker part where it starts. not sure there's any way around that with this method and this tape - the square half a wrap doubles up the thicker part of the tape when you start going diagonal.
but stars out on both sides, relatively symmetrical, angled the "right" way. great advice on redoing it with the same tape.
Likes For mschwett:
Advocatus Diaboli
Liked 1,547 Times
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3936 Post(s)
Liked 6,623 Times
Quoted: 7126 Post(s)
Liked 11,294 Times
mschwett : It looks like you did a decent job, but your method is fundamentally flawed: you should roll from the drops on up to the tops, because then the tape edges will be facing downward; wrapping in the opposite direction, as you have done, means that your hands will be pushing against the edges, and causing them to roll back on themselves and just generally look ragged far sooner.
I'll also opine that you started it too far from the stem, but that might be a matter of personal preference.
Likes For Koyote:
Quoted: 1635 Post(s)
Liked 2,725 Times
Not bad. Next time you wrap, leave the spacing on the outside of the curve the same and shorten the inside. I've seen some people use a gauge to keep the wrap even.
Liked 1,557 Times
Liked 1,417 Times
that would work if the pitch/spacing was a little larger in general, i just barely had enough this way! next time.
Bikes: One of each: Road, Hybrid, Trekking
Quoted: 137 Post(s)
Liked 115 Times
When I raced cars and did something like this I’d tell everyone it was the hot setup because it was more aerodynamic or some other bs. If I had a good run in the next race, other guys would start showing up with the same “modification.”
